Old 06-03-2016, 01:21 PM   #29
RedFRS4me
RedFRS4me's Avatar
Drives: Firestorm '13
Originally Posted by theadmiral976 View Post
That is brilliant! Excuse my naivete, but would you anticipate any long-term issues by doing this adjustment?
So far so good. I will be checking for any long term effects but from what I gather some folks have been running like this already. Mostly the ones with secondary o2 delete
'13 Firestorm
RedFRS4me is offline   Reply With Quote
Old 06-03-2016, 03:48 PM   #30
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
Thank you for the reply. I'll try this soon!
theadmiral976 is offline   Reply With Quote
Old 04-19-2017, 11:03 PM   #31
R2
Is this still working for you? I believe I am having the same issue; I plan to try zeroing the AF3 tables and give that a shot.
R2 is offline   Reply With Quote
Old 04-19-2017, 11:26 PM   #32
steve99
Drives: FT86
That fix only works for rear o2 sensor issue. Just make sure you dont have exhaust leak or other issue.
People using rear o2 sensor as input for flex fuel kits disavle rear 02 sensor trims.
It can result in slightly less fuel economy when highway cruising.
Its never a good practice to start masking off stuff in the tune unless your 100% sure
Old 04-21-2017, 07:25 PM   #33
RedFRS4me
RedFRS4me's Avatar
I've been running with the zeroed af3 tables for a while now and it hasn't given me any issues. Car drives normally with the bad sensor still downstream. But Steve is right about making sure its not an exhaust leak.
'13 Firestorm
Old 05-17-2017, 12:02 PM   #34
R2
This has worked for me as well. Finally confirmed it with a 2h drive last weekend.
The Following User Says Thank You to R2 For This Useful Post:
steve99 (05-17-2017)
Old 05-19-2017, 06:30 AM   #35
sato
sato's Avatar
Drives: Dodge Patitas
So, if I read correctly, the solution might be a new O2 sensor or zeroing out for the sensor reading? Please keep us updated on progress checks if you remember to. Much appreciated.
Sent from my E6653 using Tapatalk
sato is offline   Reply With Quote
MAF Scaling - Open/Closed Loop Fueling info steve99 Software Tuning 653 07-10-2024 04:25 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 03:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 05:49 PM
i've been out of the loop! VenomRush Off-Topic Lounge [WARNING: NO POLITICS] 0 02-15-2013 11:25 PM
Who was on the 202 loop SMOKETREES Southwest 5 09-14-2012 11:31 PM
