Old 06-02-2016, 04:26 PM   #813
goldenfri
goldenfri's Avatar
Drives: 2017 BRZ Limited PP
Send a message via AIM to goldenfri
The performance pack also adds 20lbs to the Limited, seems like a lot for a BBK and 0.5" on each wheel.
goldenfri is offline   Reply With Quote
Old 06-02-2016, 05:16 PM   #814
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Funny IIRC there is a Brembo Brakes ad in Grassroot Motorsports magazine and the rating chart only lists the OEM Brembos barely for light duty track work, more dedicated for street use. Then again they are trying to sell people heavier duty brakes.
It's basically the standard grade Brembos that come with an older Porsche isn't it (4 pot/2 pot fixed caliper)? The WRX STI world seems to think their Brembos need better pads and rotors to stop probably in very wet / cold conditions.
krayzie is offline   Reply With Quote
Old 06-02-2016, 07:05 PM   #815
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
Since I have WRX STI brembos on my BRZ I have to admit that more aggressive pads and lightweight 2 piece rotors would make more of a difference. The setup also noticeably shifts brake bias forward. Serious track guys seem to run the stock calipers on the rear to keep the bias down.
kuczynskika is offline   Reply With Quote
The Following User Says Thank You to kuczynskika For This Useful Post:
churchx (06-03-2016)
Old 06-02-2016, 10:43 PM   #816
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
Originally Posted by Freude am Fahren View Post
Hmm, so no change to the gear ratios, just the final. So it's going to be screaming on the highway.
Not really. A 4.3 final drive versus a 4.1 only bumps the RPM by 5%. So if you are at 3000RPM at highway speed, you will be 3150RPM at highway speeds.
Quentin is offline   Reply With Quote
The Following User Says Thank You to Quentin For This Useful Post:
DAEMANO (06-03-2016)
Old 06-02-2016, 11:08 PM   #817
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
Excuse my lack of knowledge but...does the changed final drive mean it just affects the last gear while the rest stays the same? Not really sure how final drive works.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Oxyg3n is offline   Reply With Quote
Old 06-02-2016, 11:16 PM   #818
mike2100
mike2100's Avatar
Drives: 23 BRZ
Final drive is the ratio in the differential. It affects all gears.
mike2100 is offline   Reply With Quote
Old 06-02-2016, 11:17 PM   #819
nico_rsx
Drives: BRZ 2017 Pure Red, MT
The final gear ratio affect all 6 speed. It's the gear in the diferential, so it will affect all the gears by the same percentage.
nico_rsx is offline   Reply With Quote
Old 06-02-2016, 11:20 PM   #820
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Originally Posted by Poodles View Post
You're either trolling or straight up lying... You also missed the point about the Japanese improving the area under the curve. It's the whole reason sequential turbos were used...
But whatever, you apparently can't keep your facts or points straight so I don't know why I even bother replying.
Why would I need to lie though? What am I gaining from lying? A member in a local group in Atlanta(86 ATL) let me and another 86 member drive his car because we wanted to go pure N/A bolt ons + e85 and make 35-40whp. A guy name Adam got a Tomei EL from my buddy and he got it tuned from a shop in ATL named DBW Motorsport. The car just didn't impress us and I even suggested we turn off the A/C to see if the car would perform better. All I'm saying is if you can feel 10hp to the crank then you have amazing feel for small power. It's funny how you are getting angry over some stuff I'm clearly not lying about.
SUB-FT86 is offline   Reply With Quote
Old 06-02-2016, 11:24 PM   #821
Bman117
Drives: Waiting on 2nd Gen!
Final Drive relates to how many times the drive shaft needs to rotate to spin the wheels.
See this video at the 1:45 min mark to get a fairly good understanding of exactly what I mean:
Bman117 is offline   Reply With Quote
Old 06-02-2016, 11:27 PM   #822
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
True, but it's already yelling at 80. Yellingx1.05=screaming
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
The Following 2 Users Say Thank You to Freude am Fahren For This Useful Post:
raven1231 (06-03-2016), Summerwolf (06-03-2016)
Old 06-03-2016, 05:31 AM   #823
SStratos
SStratos's Avatar
Drives: 2017 WRB Subaru BRZ
After watching the infomercial video of all the changes at Subaru.com, I'm soooo SOOOO happy I waited for the 2017 BRZ!!!
SStratos is offline   Reply With Quote
The Following User Says Thank You to SStratos For This Useful Post:
Old 06-03-2016, 05:40 AM   #824
raven1231
But just think if you wait until 2020my you can get the second generation!
The Following 2 Users Say Thank You to raven1231 For This Useful Post:
GT86_PRAGUE (06-03-2016), SStratos (09-09-2016)
Old 06-03-2016, 05:52 AM   #825
SStratos
SStratos's Avatar
Ha ha :-) I can't wait that long...and by then I would have made more upgrades and not need the 2020model. :-)
Old 06-03-2016, 07:31 AM   #826
churchx
churchx's Avatar
Drives: 2014 GT86
Originally Posted by kuczynskika View Post
.. Serious track guys seem to run the stock calipers on the rear to keep the bias down.
Serious track guys understand importance of brakes and don't do brake swap from different car for bling/branding purpose only.
krayzie (06-03-2016), SuperDave (06-03-2016)
-20hp heavy body kit, 10/10 do want, 2017, better than the 86, facelift, more drag same hp, update, would bang (gears), zaku goes to ct
2017 FRS Official Facelift Pics Zhangy Scion FR-S / Toyota 86 GT86 General Forum 2 03-17-2016 06:06 PM
When will we see the facelift revealed? airjonny Scion FR-S / Toyota 86 GT86 General Forum 48 03-17-2016 05:04 PM
2017 Toyota 86 facelift TMXSTAR Scion FR-S / Toyota 86 GT86 General Forum 11 03-17-2016 12:06 PM
Were they not going to debut the 2017 facelift end October??? gt8613 BRZ First-Gen (2012+) — General Topics 10 11-16-2015 10:21 AM
FR-S/86 Facelift render JW89225 Scion FR-S / Toyota 86 GT86 General Forum 20 11-04-2015 07:43 PM
