Old 03-31-2016, 11:50 PM   #211
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Pictures just don't give it the credit it deserves. Y'all have to see it in person.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 04-08-2016, 10:36 AM   #212
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Final part before tuning. Custom fx725 twin disk for the tremec
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
MaximeT (04-08-2016)
Old 04-08-2016, 02:11 PM   #213
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Wow looks really good!!!
Sent from my SM-G935T using Tapatalk
SoCal80six is offline   Reply With Quote
The Following User Says Thank You to SoCal80six For This Useful Post:
L3P47 (04-08-2016)
Old 04-19-2016, 10:07 AM   #214
spitfire481
Drives: 2JZ FRS
Faceplated tko600, oem console and shift boot
MoTeC
Build Thread
@spitfire481
The Following 5 Users Say Thank You to spitfire481 For This Useful Post:
Enalband24 (04-19-2016), haimichaeltran (06-06-2016), hmong337 (04-24-2016), M1K3 (04-19-2016), Sportsguy83 (11-30-2016)
Old 04-22-2016, 02:58 PM   #215
spitfire481
Drives: 2JZ FRS
Aaaaaaaand we have gone Motec. Shouldn't be too much longer
MoTeC
Build Thread
@spitfire481
The Following 3 Users Say Thank You to spitfire481 For This Useful Post:
new2subaru (07-01-2016), Summerwolf (04-22-2016), Tectoniic (04-22-2016)
Old 04-23-2016, 06:48 PM   #216
spitfire481
Drives: 2JZ FRS
Final buff and first wax
MoTeC
Build Thread
@spitfire481
The Following 6 Users Say Thank You to spitfire481 For This Useful Post:
#maverick# (05-09-2016), hmong337 (04-24-2016), Kiske (05-07-2016), MaximeT (04-24-2016), midnight23 (04-24-2016), Pure Automotive (04-26-2016)
Old 06-01-2016, 08:18 PM   #217
spitfire481
Drives: 2JZ FRS
Finally got the motec in and started tuning today. Ran out of injector at 28psi of boost. Going to swap those out and continue hopefully next week. Also have to wire in the anti lag switch and configure the motec shift light module
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
djdnz (06-02-2016), SkAsphalt (06-02-2016)
Old 06-01-2016, 09:23 PM   #218
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Think the anti lag will put alot of stress on the motor??
Old 06-01-2016, 10:36 PM   #219
spitfire481
Drives: 2JZ FRS
We are using it for launch, paired with the ebrake to preload the drivetrain. It'll be activated with the ebrake switch. The motec anti lag and launch controls are about as good as they can get. After today I'm not too worried about this motor at all, we made quite a few pulls and had zero issues
MoTeC
Build Thread
@spitfire481
SoCal80six (06-01-2016)
Old 06-01-2016, 10:51 PM   #220
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Wow ahah get any good numberso on the dyno? And I've been wanting to do motec on mine but damn it's pricey aha it's about 5k correct?
Old 06-01-2016, 10:54 PM   #221
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Never mind just looked at it damn 666whp how's that trans doing? And is that a sequential!!?
Old 06-02-2016, 10:53 AM   #222
spitfire481
Drives: 2JZ FRS
666 at 28 psi. the turbo will probably start to run out of steam around 38ish from what he could see. new injectors are going in and hopefully he can swing by next week to finish up. the control and drive ability of m150 ecu is amazing. the fuel trim controls are so quick to respond the afr is dead on with commanded afr the whole time. the high pressure di pump started oscillating fuel pressure after 8k rpm from 600 psi to 2000psi until redline. im assuming with ecutek people just leave it be but with the m150 it corrected the duty cycle for the di's so fast the afr had zero deviations from commanded after 8k.
trans is fine. it is faceplated (basically dogbox) H pattern 5 speed. its rated for 600 continuous ft lbs in stock form from tremec. mine has heat treated gears so they have a tad more give from shock load. we might setup a strain gauge for clutchless shifting at the track seeing how the trans will take it with the control the m150 has over clutchless shifting loads.
MoTeC
Build Thread
@spitfire481
SkAsphalt (06-02-2016), SoCal80six (06-02-2016)
Old 06-02-2016, 11:45 AM   #223
MooKz
MooKz's Avatar
Drives: 2013 Scion FR-S Firestorm Red
I really hope there is ample video for us to see this beast in action because this thread is awesome! Lmao thanks for putting all this time, effort, and money into pushing our cars to the limit
MooKz is offline   Reply With Quote
Old 06-02-2016, 12:41 PM   #224
spitfire481
Drives: 2JZ FRS
i have one dyno video, but it was towards the beginning of tuning around 500ish hp and shut down around 7000rpm but ill upload it anyway. should be able to get to the track later this month if everything goes well with finishing up.
my mph calculations were pretty much spot on. 155mph at 8300rpm in 4th gear. should work out well at the track
MoTeC
Build Thread
@spitfire481
God's Build GodSays Member's Car Journals 13 04-17-2013 01:31 PM
My build... well some of it cruzinbill Electronics | Audio | NAV | Infotainment 41 04-01-2013 04:02 PM
STX build Evil86 Tracking / Autocross / HPDE / Drifting 2 01-08-2013 03:40 PM
My BRZ build brztj Mid-Atlantic 3 09-08-2012 05:52 PM
