#29 |
Here you can see that when VVT is not activated Intake angle 2 is more retarded. It evens out when VVT becomes active. Shortly after, the exhaust VVT becomes active. This causes a slight delay in intake VVT, as to be expected. However, intake angle 1 recovers nicely. Intake angle 2 oscillates quite a bit longer and slowly recovers. Either oil is being impeded to the cam phaser or the cam phaser is sticky.
http://www.datazap.me/u/osudoc11/tim...log=0&data=0-1 This really is a nice graph. |
#30 |
Drives: 2017 BRZ Limited PP
osudoc11, did you get any further? Im interested as to what the final fix is.
#31 |
Drives: 2014 Subaru BRZ WRB
@osudoc11 is correct. I've had this code twice. The fist time it happened I the dealer replace the cam sensor. The second time I had a considerable oil leak from a banjo bolt on my oil cooler. Apparently I lost enough oil that the intake cam was delayed at one point. Just filled the car with oil, wiped the code and everything was working fine.
#32 |
Regional Moderator
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
I had issues with the p0016 code and they ended up replacing my VVTI gears, and gave me a new ECU. Less then a 1000 miles later. I got rod knock. This is what I'm dealing with now.
#33 |
Rod knock? That sucks. Dealer is going to replace cam sprocket and ecu. You sure you're getting rod knock? Can you log and see that the knock sensors are picking it up.
| The Following User Says Thank You to osudoc11 For This Useful Post: | steve99 (05-19-2016) |
#34 |
Drives: Black (Raven) 2 door coupe
This sucks I have the same code P0018 and I'm hoping there's a solid fix for this. I've been limping around for over a month and half now
#35 | |
When In Doubt...
Drives: Slowww
How strange. I also got P0018 immediately after Moto East installed my JDL UEL/tune. I started discussing this in post #6. It was a hellish time. I've driven my car 2,870 miles since October 11th 2015. That's something around 230 days. http://www.ft86club.com/forums/showthread.php?t=97944
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#36 |
Hey Laika, I just read your issue with the p000d now. That sucks. Did you get it fixed? Did you put the tune back on after the initial cam sprocket fix? It really seems like some engines just have this failure recurrently and subaru really has no clue what is causing it. After this subaru it is going to be something without variable valve timing for me.
#37 | ||
Drives: FT86
yes its weird, I suspect that a lot of aftermarket tunes "push" the vvt system harder ie ask for a greater rate of change of cam timing than the stock tune. Hence this may uncover latent defects in the vvt system in some cars |
#38 | |
When In Doubt...
Drives: Slowww
I don't claim to know anything about tuning but I'd venture a solid bet that this is exactly right. Any thoughts on my oil light issue described above?
#39 | |
Drives: FT86
might be as per posts here , the oil pressure switch in these cars is set to about 3psi, basicly total oil pressure loss to trigger http://www.ft86club.com/forums/showthread.php?p=1789776 |
#40 |
Well I can only speculate as to your oil issue. The simplest and hopeful explanation is a failing oil pressure switch. The most detrimental explanation would be that when you were having your issues earlier your rod journals weren't getting enough oil. This could cause wear (spun journal). Now it may be a little to big and allowing oil pressure to escape. I would think if it were this issue you would have a little bit of knock. I honestly feel like a lot of these OCV issues could be solved by checking the OCV filters. Unfortunately they put them in the freaking camshaft housing assembly. So essentially you have to take it down to the cams to get to them. You think they would have learned with the EJ series engines. Eventually Subaru was telling the dealers to just take the filters out on the EJ's.
#41 |
Drives: 2016 BRZ Limited
So I just had something similar happen to me a little over a week ago.
P000B fault code comes up for me. I have a 2016 BRZ. Happened 6 days after installing JDL UEL catless headers with OFT stage tune UEL 93 Oct tune. Reverted ECU back to stock and still had the issue show up. My car is at the dealership now and even though my OFT had said it flashed the ECU back to stock, the dealership is saying that the ECU is showing it's been modified (something about an ignition count of 20 or w/e, not fully sure). I checked with OFT before taking the car in and it showed the stock tune as being loaded. Really wish I would have taken pictures before hand. Were you ever able to figure out if this is caused by the header or the tune. I would think it would be the tune and don't really know how it could be caused by just the header. This is something I've been trying to figure out for a while now, but just can't seem to get a straight answer. From what I'm reading it definitely seems like it's the tune that caused a small defect to finally present itself. |
#42 | |
Drives: FT86
What the dealer is talking about with "Ignition count" is the number of starts the ecu has recorded since the ecu was reflashed or RESET. A Reset can be just removing a batter terminal or a flat battery. They have no proof it was reflashed, they have seen header and are trying you on. The oft will have put a byte for byte stock rom back in the car. just say you tried resetting ecu by removing a battery terminal a couple of days ago, or read and reset codes/ecu with a scan tool. either of those will also reset all the counters like start counts, DTC on/off times in ECU. |
| CEL P0018 Cams | woode | Issues | Warranty | Recalls / TSB | 69 | 05-13-2023 02:23 PM |
| P0018 is keeping me from enjoying my car | Astroboy | Issues | Warranty | Recalls / TSB | 11 | 05-18-2017 09:37 AM |
| Buddy Club Race Spec Coilover Problems on Problems on Problems | mpross | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 48 | 09-04-2016 11:18 PM |
| CEL P0018 | brichard0625 | Issues | Warranty | Recalls / TSB | 8 | 02-10-2016 09:44 PM |
| 31k miles and P0018 happens... | MisterSheep | Issues | Warranty | Recalls / TSB | 65 | 01-18-2016 05:33 PM |
