Old 05-29-2016, 12:00 AM   #3487
dj2020
Originally Posted by canyons View Post
Sorry, not a mechanic....Could you explain this further? Because I'm thinking I want the PCV valve to continue doing its job. Are you saying the slight vacuum created by the intake restriction is necessary ? Can you say for what?
This question directed at me?
dj2020 is offline   Reply With Quote
Old 05-29-2016, 01:31 AM   #3488
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
Nope, I was hoping GsxrMe would answer since it's his suggestion... however more research seems to indicate that the slight draw created by air moving through the CAI is useful to pull gasses out of the crank case. I found a decent explanatory video here ( supercharged lotus, but same logic applies):
Jump to the 3 minute mark for a Pros/ Cons on atmospeheric vs closed system. I think this is steering me towards a closed system catch can:
-- [ame="https://www.youtube.com/watch?v=Zo4SltHUGd4"]Sector111 Educational Video: PCV System Part 2 - YouTube[/ame]
canyons is offline   Reply With Quote
The Following 4 Users Say Thank You to canyons For This Useful Post:
Calum (05-29-2016), dj2020 (05-29-2016), menikmati (06-03-2016), SoCalArgento (05-29-2016)
Old 05-29-2016, 09:53 AM   #3489
dj2020
@canyons: great video. For a street driven car, running a CCV can back into intake piping before the throttle body seems to be the better solution according this video. I might have to reconsider.
Old 05-29-2016, 10:49 AM   #3490
SoCalArgento
Drives: 2014 Argento FRS
Quick side question: I have the PCV side radium catch can without the JR "check valve" installed.
Is there any detriment to the car if I don't use it?
SoCalArgento is offline   Reply With Quote
Old 05-29-2016, 11:08 AM   #3491
dj2020
It's my understanding that the stock PCV check valve was not made for boost, so if you don't have the JRSC check valve installed with your catch can, your crank case maybe getting pressurized as the intake manifold pressure builds (assuming the stock PCV valve was not designed for boost).
Due to the larger diameter of my catch can tubing, I ended up not using the check valve that came with the JRSC kit and used a 1/2" Boomba unit instead that runs inline between the catch can and intake manifold.
The Following User Says Thank You to dj2020 For This Useful Post:
Old 05-29-2016, 11:35 AM   #3492
byun
byun's Avatar
Drives: 2015 BRZ CWP
Originally Posted by porsche550s View Post
Mine did the same thing. Ended up having to install a quick release system on the bumper. My car is DGM so it looks pretty good but they make the kit in many colors and it was a generally easy install just lots of patience.
Yup I did the same too
byun is offline   Reply With Quote
The Following 3 Users Say Thank You to byun For This Useful Post:
dp1 (05-31-2016), Jmonty (05-29-2016), PMok (05-29-2016)
Old 05-31-2016, 06:36 PM   #3493
twag4
Drives: frs
I was just wondering: I remember back, but cant find, a couple of threads where people were down on power with this system. It seems I am the most recent receiver of this problem. Does anybody remember any of the issues that caused the problems? My charge pipes and hoses are all in tact, so please don't provide that as a fix. Are there vacuum lines or anything that could cause this? CSG has gotten some and will receive more data logs from me, but in the mean time I was hoping to find something mechanical that might cause the problem. Thanks in advance
twag4 is offline   Reply With Quote
Old 05-31-2016, 07:30 PM   #3494
Hicklinc
Drives: N/a
It was something to do with not getting full boost because of a malfunctioning bypass valve i think it was called or something
Sent from my SM-N910T using Tapatalk
Hicklinc is offline   Reply With Quote
Old 06-01-2016, 10:43 AM   #3495
86Tony
Drives: 2015 AOZORA EDITION
finally got my JR c38 kit, now waitin on ACE 350 headers to get here so i can install. pretty damn excited
86Tony is offline   Reply With Quote
The Following 3 Users Say Thank You to 86Tony For This Useful Post:
cgjeff (06-01-2016), CSG Mike (06-01-2016), ScionOfHorus (06-01-2016)
Old 06-01-2016, 12:08 PM   #3496
porsche550s
Drives: 2015 Subaru BRZ
I'll be looking into the same thing I haven't dynoed mine but I do know that the car is not performing nearly as well as it should be with this kit.
porsche550s is offline   Reply With Quote
Old 06-01-2016, 01:05 PM   #3497
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
That bypass valve was sent in for inspection, and was working properly. So that was not the issue.
Remember now that summer is approaching and ambient temperatures start getting close to triple digits that the car will feel like it has less power, supercharged or not. This is when having a engine oil cooler helps tremendously to help keep power up on those scorching hot days.
-Jackson Racing Staff
Jackson Racing is offline   Reply With Quote
The Following 3 Users Say Thank You to Jackson Racing For This Useful Post:
cgjeff (06-01-2016), Hicklinc (06-01-2016), SuperDave (06-05-2016)
Old 06-01-2016, 01:57 PM   #3498
CSG Mike
CSG Mike's Avatar
@twag4's car is pulling a massive amount of timing. The cause is unknown at this time. A few diagnostic procedures have been recommended, and I am waiting for more logs.
twag4 (06-01-2016)
Old 06-02-2016, 12:18 PM   #3499
CSG Mike
CSG Mike's Avatar
@twag4: Check for a possible vacuum leak, and also clean your MAF sensor with MAF cleaner. Your fuel trims at lower RPMs, part throttle, are pretty wild.
Old 06-02-2016, 08:46 PM   #3500
enivid
enivid's Avatar
Drives: WRB JR BRZED
Who's tune are you using?
enivid is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
