Old 05-28-2016, 12:19 PM   #11915
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
In florida for the weekend, seeing so many s550 mustangs but only 3 twins so far. 1 ultramarine frs, 1 wrb brz, and 1 asphalt frs.
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline
Old 05-28-2016, 01:05 PM   #11916
..........and then you set the timing using a 6V light bulb and two pieces of wire .......??
No, just listened for the spark.
Ultramaroon is offline
humfrz (05-28-2016)
Old 05-28-2016, 01:58 PM   #11917
p1l0t
p1l0t's Avatar
Originally Posted by gramicci101 View Post
Lego Technics are awesome
p1l0t is offline
gramicci101 (05-28-2016)
Old 05-28-2016, 02:31 PM   #11918
OHHHHH you had a light? well aren't you Mr. Hightech Fancypants.
"Nope (turn) nope (turn)nope (turn) Ahhhh there we go (tighten)"
Tcoat is offline
humfrz (05-28-2016), themadscientist (05-28-2016), Ultramaroon (05-28-2016)
Old 05-28-2016, 03:57 PM   #11919
lol
Turn in your man card, humfrz.
humfrz (05-28-2016)
Old 05-28-2016, 04:09 PM   #11920
Bear Grylls is such a poser...
soulreapersteve (05-28-2016)
Old 05-28-2016, 04:15 PM   #11921
He is not. It is all real. Now go drink your own piss like a good boy.
Tcoat is offline
Sarlacc (05-28-2016), themadscientist (05-28-2016), Ultramaroon (05-28-2016)
Old 05-28-2016, 04:19 PM   #11922
Reminds me of the time (back in about 1970) I had acquired a store bought el cheapo timing light. I was timing my 1970 MGB (of course the British put the timing plate underneath the front of the engine .....) when I figured I had it at 7 degrees TDC and took the car out for a spin.
I was pleased with how it ran ........ but I heard this strange noise coming from under the car. I stopped to take a look and discovered (who would like to guess ...... I don't wanna talk about it ...... ).
humfrz is offline
Old 05-28-2016, 04:22 PM   #11923
gramicci101
Off Topic
A kitten?
gramicci101 is offline
Old 05-28-2016, 04:40 PM   #11924
A kitten?
Old 05-28-2016, 04:42 PM   #11925
babydriver
Hit the road and I'm gone
babydriver's Avatar
Uh, you forgot to put the plate back?
Slip, slidin' away.
babydriver is offline
Old 05-28-2016, 04:49 PM   #11926
babydriver
babydriver's Avatar
Got my first tuning file back from Shiv at OFT last evening and mapped it into the ignition today. Basically, he took the E-85 Stage 2 tune for CAI and aftermarket headers and leaned it out a bit. (I have the CAI and a snorkel, but also the stock header; aftermarket ones typically run leaner. Ergo, I was running a bit rich.) He also fiddled with the advance curve at the highest RPM's.
Obviously the big change was the A/F mixture being optimised. I would classify it as a definitely noticeable if not earth-shattering increase in both power and torque in the "midrange" of the gears. The torque dip did not seem to be so bad. This is only the first iteration. He wants another data file and will continue to tweak it some more based on that new information.
Haven't had a chance to run it flat out yet, due to the traffic. I may go out to the toll road later and have a run at max accel and see what the top is like now.
BTW, the idle is now spectacular. It's pretty warm today, so I won't know for a while if the cold start situation is improved, since this is Texas and it's late May and it isn't going to get cool again for a while!
Slip, slidin' away.
The Following 2 Users Say Thank You to babydriver For This Useful Post:
Tectoniic (05-31-2016), Ultramaroon (05-28-2016)
Old 05-28-2016, 04:56 PM   #11927
Well, no ....... hint:
To use the timing light on an MG, one would snake the wires down in the engine compartment so the light was under the car so as you could shoot up at the timing mark on the pulley that is attached to the crankshaft.
Now, what on earth could be dragging to make all that racket during my test drive .. ??
OF course, I did my best tune-ups after a couple of bloody Marys .......
humfrz is offline
Old 05-28-2016, 05:45 PM   #11928
Haha... oops! That's why, in navair at least, we did a tool inventory afterward.
I heard air force has contractors for that.
humfrz (05-28-2016)
