Old 05-26-2016, 03:07 AM   #7225
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Originally Posted by Dream20b View Post
possibly adding cams to my build since I've managed to wreck my driver's side head.
Anyone have experience with cams? I'm going to buy (if needed) Fullblown's Stage one cams.
You using the 210? What pulley?
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 05-26-2016, 07:44 AM   #7226
Dream20b
Y u do dis?
Sprintex 335 Supercharger upgrade kit
75mm drive pulley
Sprintex Intercooler
ID1000 Fuel Injectors
DW 300c Fuel Pump
ACT Heavy duty clutch
ACT Streetlite flywheel
Tomei Equal length header
Perrin 2.5" Resonated catback exhaust
Tanabe 60mm Overpipe
Tanabe 60mm Catless Frontpipe
Manley I beam rods
Wiseco Forged Pistons 9:1 Compression with Armor Coating
Custom Wrist Pins
Race Engine Bearings (Mains and rods)
Killer B oil pick up tube
ARP FA20 Head studs
In the future:
600 HP Axles
Custom AZ6 Gear set
FBM Stage 1 cams
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
The Following User Says Thank You to Dream20b For This Useful Post:
riboyster (05-26-2016)
Old 05-26-2016, 12:29 PM   #7227
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by camelflage View Post
i'm thinking JDL uncatted with the ultra quiet front/over pipe combo, and an act street clutch to keep it all headed to the wheels. depending on how loud that is might get a vibrant resonator put into the un-resonated mid-pipe i have.
Check my build thread for what I've done to my exhaust if you'd like. I have JDL uncatted and went through a couple setups before settling on the resonated Q300 with resonated front pipe with hi flow cat.
The Following User Says Thank You to stockysnail For This Useful Post:
CarzCarzCarz (05-26-2016)
Old 05-26-2016, 03:32 PM   #7228
riboyster
riboyster's Avatar
75mm drive pulley
DW 300c Fuel Pump
Manley I beam rods
Custom Wrist Pins
ARP FA20 Head studs
In the future:
600 HP Axles
Custom AZ6 Gear set
FBM Stage 1 cams
Wow man you put a lot of work into it. I'm actually surprised you had a malfunction with that sort of build
The Following User Says Thank You to riboyster For This Useful Post:
Dream20b (05-26-2016)
Old 05-26-2016, 04:06 PM   #7229
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
What front pipe are you running that has a resonator and hi-flow cat? I'm running the JDL UEL catless header, their Ultra-quiet front pipe with cat, and stock catback exhaust and I'm not digging the sound on start up, and low RPMs. Does the Q300 make it any quieter than stock exhaust, or give a different tone?
CarzCarzCarz is offline   Reply With Quote
Old 05-26-2016, 07:56 PM   #7230
Dream20b
Y u do dis?
dropped a bolt into the head.
Dat Hot Lava Doe
Old 05-26-2016, 09:16 PM   #7231
stockysnail
Just the tip
It's in my build thread, but I have the Nameless front/overpipe with high flow car and resonator.
The Q300 won't make it quieter, but it will sound much nicer. To make it quieter than what you have, you'll need to get a catted header instead. Startups are a bit rough as far as loudness for the catless cars.
CarzCarzCarz (05-27-2016)
Old 05-27-2016, 12:34 AM   #7232
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Exclamation
I will be selling my 3" JDL exhaust if you are interested.
overpipe frontpipe with cat and resonator
catback with Magnaflow resonators
Chad86 is offline   Reply With Quote
Old 05-27-2016, 02:09 AM   #7233
riboyster
riboyster's Avatar
Fuuuuck. If there's one thing everybody dreads doing....
On the bright side, you won't make that mistake twice!
If it's any consolation, I once sucked a wad of electrical tape into my vacuum port.
Dream20b (05-27-2016)
Old 05-27-2016, 07:24 PM   #7234
camelflage
Drives: pinto power
In trying to find the quietest route. Lol
Sent from my HTC6500LVW using Tapatalk
camelflage is offline   Reply With Quote
Old 05-28-2016, 01:36 AM   #7235
brianhj
Drives: 2017 Camaro 1SS
Dumb question: I installed a DW65 fuel pump. I was sitting at a red light just now with the ac on and my break pedal started sinking... Then a few moments later it raised back up.
I know this has nothing to do with a fuel pump but I mentioned it because that's all I changed. I've felt the break pedal sink before when stopped bit never raise back up like that. I'm assuming it's going up and down due to the change in vacuum pressure? Is it normal?
Sent from my LG-D851 using Tapatalk
brianhj is offline   Reply With Quote
Old 05-28-2016, 05:46 PM   #7236
riboyster
riboyster's Avatar
Engine load / vacuum. You lose vacuum a bit when your ac cooler fan kicks on because of the increase in engine load and opening of your throttle body. Less vacuum means less brake boost, which means pedal is harder to depress. Then your fan turned off again and the opposite happened
brianhj (05-28-2016)
Old 05-28-2016, 05:48 PM   #7237
riboyster
riboyster's Avatar
Also I think there's a thermostat that turns off the compressor once you reach a certain cool temp. That's probably more likely. I've heard it turning on and off multiple times in a minute while sitting at idle with the ac on
Old 05-29-2016, 02:42 PM   #7238
walletsr
Drives: 2014
I have. Squeaky alternator, it just started so I going to replace alternator to be safe
Anyone else ever had a squeaking alternator? It doesn't squeal, just squeak. It's noticeable above 2000 RPM. I took the belt off today and turned it by hand and it squeaks. Bearings?
walletsr is offline   Reply With Quote
The Following User Says Thank You to walletsr For This Useful Post:
brianhj (05-29-2016)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
