Old 05-24-2016, 11:35 AM   #323
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
if you want it to come back on just do a bunch of third gear pulls.
Just found out it doesn't actually matter, since I have over 36,000 miles it won't be covered. Called the dealer and they said that the 60k Powertrain warranty doesn't cover it.
Guess I'll just be ordering one and changing it myself.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
ZionsWrath (05-24-2016)
Old 05-24-2016, 11:37 AM   #324
ZionsWrath
Thanks
ZionsWrath's Avatar
Yea when I had like 37,000 they didn't want to touch my car lol
It's an easy job, i needed to buy a 1/4" flex head ratchet to fit in the space to change it.
Old 05-24-2016, 11:47 AM   #325
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
depends which one as to how easy it is to replace.
p0351 is the easiest, you can just take off the fuel injection ECU and reach it fairly easily.
Considering I'm now replacing my engine, I'm going to make sure I replace all the spark plugs and everything's good before I put the used engine I got in. Then I get to break apart my old engine and start the build up for some serious power.
I lucked out on this used engine $2500 with 35K no core charge...
compression test came out 225 on all 4 cylinders...
Jaden
Jaden is offline   Reply With Quote
Old 05-24-2016, 11:57 AM   #326
ZionsWrath
Thanks
ZionsWrath's Avatar
Jaden
I couldnt fit a 3/8 between the frame rail and coil pack bolt.
Old 05-24-2016, 12:09 PM   #327
Jaden
Road-hole
you couldn't?
hmm, on cylinder 1? that's odd. I did. The only thing that was a little difficult for me was getting the socket off after loosening one of the bolts holding the fuel injection ecu on without taking off the fuse box.
Jaden
Old 05-29-2016, 09:24 AM   #328
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open
I've threw a p0353 code at least 4 times over the past two months. I think it's time to buy some ignition coils.
Just a quick question for all who have already been through the process. I'm looking online and I'm seeing prices ranging all over the place..How much should I actually be paying for one or a set of new coils?
And have you guys been replacing your spark plugs too?
Kronos is offline   Reply With Quote
Old 05-29-2016, 12:21 PM   #329
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
OEM coil packs are about $110 from subaru. Make sure you get the correct one for the model year as they changed in 2015. Plugs are about $22 and I would change them all if you are close to 60k miles and want to get it over with.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
Kronos (06-07-2016)
Old 06-07-2016, 12:24 AM   #330
Kronos
Kronos's Avatar
Thanks for the info
Found them here for a good price for any who is following this thread and needs some
http://www.toyotaonlineparts.com/oe-toyota/su00304713
http://www.toyotaonlineparts.com/oe-toyota/su00304931
The Following User Says Thank You to Kronos For This Useful Post:
phrosty (12-01-2016)
Old 07-10-2016, 04:38 PM   #331
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Looks like my coil took a dump as well, and it happened while just driving normally on my way to a buddy's wedding. Say we replace the coil pack have any of you done any preventative measure to try to prolong the life of the coils? Heat shielding? What about these guys posted earlier in this thread? Are these more robust than the factory units?
http://www.okadaprojects.com/usa/products_direct.htm
Intent > Content
Old 07-10-2016, 08:18 PM   #332
steve99
Drives: FT86
mate I think their was an update to the coil hardware that is better, but I did here that the later cars the actual plug on the coil pack changed, however their was updated coils available for the 2013
I believe the earlier part numbers are check with the parts supplier though all 4 coils same below are revised part numbers
22433AA652
22433AA651
22433AA650
solidONE (07-10-2016)
Old 07-10-2016, 08:22 PM   #333
solidONE
solidONE's Avatar
22433AA652
22433AA651
22433AA650
Sweet! Too bad I cannot get warrantied anymore. So whats the difference between the 3 parts? is the higher digit the newer version?
Intent > Content
Old 07-10-2016, 08:26 PM   #334
steve99
Drives: FT86
I believe so, but im not 100% as I have not had to replace one yet
here seems to indicate they are revisions
http://www.ebay.com/itm/SUBARU-OEM-1...-/121783750070
The Following 2 Users Say Thank You to steve99 For This Useful Post:
solidONE (07-10-2016), Teseo (07-10-2016)
Old 07-10-2016, 08:59 PM   #335
Teseo
Drives: frs
Can fit on 2012 year made?
Old 07-10-2016, 09:15 PM   #336
steve99
Drives: FT86
id check with local Subaru or Toyotas parts department to be sure
Teseo (07-10-2016)
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 05:29 PM
