Old 03-22-2016, 10:13 AM   #113
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Originally Posted by DustinS View Post
7psi on a TD05-20G on pump gas is ~250whp. 10 psi is around ~280whp on pump Gas (where I am at right now). 12 psi on E85 is ~345whp on a conservative tune. Not all FI is the same. Very Happy with my purchase and the power output. I have room to make 400whp if necessary.
Oh had missed the 7 psi part I'm well aware not all fi are the same I just failed to understand how you had so little gain, 7psi explains it.
fumanchu1 is offline   Reply With Quote
Old 03-22-2016, 10:30 AM   #114
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Originally Posted by CamFrs View Post
Speed By Design V2 Turbo Kit, 93 Octane, Motiv Concepts over pipe, Invidia resonated front pipe, stock midpipe, and a Borla Axle back. Competition stage 2 clutch.
wow i hope mine puts this down.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 03-24-2016, 06:02 AM   #115
Northwest86
Drives: Velocity Orange 86 GT
Thane/Northwest86
Coyoda Turbo Preproduction running a GTX3067R w/ Stainless manifolds unfortunately but it does the job.
95 RON or 90/91 In Imperial
8Psi
Q300 with 2.5" Front (catted) and overpipe. Clutch, Synapse BOV, Plex PBC and other supporting mods for the track.
- Other Notes/Conditions, Tuner, etc. (include link to other thread where people can go comment/ask questions if desired) Tuned by Coyote. This is on a dyno that posts 105kw for a stock car but numbers don't mean Jack really. The same dyno on the same tune has read 10-15kw different from a number of small things. It gives a good idea of the delivery though. For a rough estimate compared to most dynos you'll see in America add 10-25% to the numbers.
Northwest86 is offline   Reply With Quote
Old 03-24-2016, 10:41 PM   #116
Rapiddan45
Rapiddan45's Avatar
Drives: 2013 FR-S M/T Ultramarine
Jackson Racing C38
Delicious tune/ 91 oct
OFH, Invidia OP/N1, Spencer Fab HFC Front pipe
240whp/182tq
Side note on this dyno, it was the baseline tune and I have since had a handful of revisions, and will dyno again with the finalized one.
Also I'm at high elevation so only seeing 7.5psi at red line, opposed to the 9.5 you would see at sea level.
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2.
OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1
C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can
Rapiddan45 is offline   Reply With Quote
Old 03-29-2016, 07:42 PM   #117
jmh128
Drives: 2016 BRZ Hyper Blue
Jeff/jmh128
Edelbrock SC
Delicious tune
93 Octane Fuel
12 psi Boost
225 A/S tires
Everything else is stock
jmh128 is offline   Reply With Quote
Old 03-29-2016, 08:56 PM   #118
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Originally Posted by jmh128 View Post
Jeff/jmh128
Edelbrock SC
Delicious tune
93 Octane Fuel
12 psi Boost
225 A/S tires
Jeff,
Thanks for sharing. Prior to the Edlebrock SC, I was set on a turbo. But with your performance, the simplified maintenance and operation of a SC, and the great appearance of the package, it's hard to argue against anything else in the ~300whp category.
Btw, it looks like you'd get quite a bit more HP (300whp) with a 3" exhaust, if your TQ didn't drop off due to flow constraints.
Build Thread: Breaking-Bad SWP Build
OFFICIAL NM.FT86CLUB Facebook Page
mwjcyber is offline   Reply With Quote
Old 05-11-2016, 11:30 AM   #119
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
Before: Moto-East e-tune
After: DBW motorsports dyno-tune
Relevant Mods:
Automatic trans (According to Doug @ DBW, they run about 8-10% less on his dyno than a manual)
Jackson Racing supercharger
High boost pulley
Flex fuel with E72 in the tank
Full catless exhaust
This is hitting 12 psi at the very top with the high boost pulley.
xsnapshot is offline   Reply With Quote
Old 05-11-2016, 12:40 PM   #120
kanundrum
Drives: 2013 Whiteout FR-S
My E85 Tune from @ptuning
Old 05-23-2016, 10:11 AM   #121
Jhood
Jhood's Avatar
Drives: 2014 BRZ Limited [6MT/SWP]
- Josh / Jhood
- Full Blown Stage 1 Turbo Kit - GTX2867R
- E85 by Moto-East Flex Fuel Kit
- 9psi
- Perrin 2.5" Catback
- Dyno tuned at Moto-East (At max power output on E85 due to stock clutch)
- Build thread in sig below
7psi on 93 = 257whp/205tq
9psi on E65 = 302whp/234tq
|FBM Stage 1 Build|GTX2867R|
|Moto-East Flex Fuel & Dyno Tune|
|360whp / 265tq (E81 @ 12psi)|
Jhood is offline   Reply With Quote
Old 05-23-2016, 02:00 PM   #122
Frs909
Drives: 2013 Turbo FR-S Java Pearl
Gabe / Frs909
- Full blown motorsports kit
- E85 ptuning kit
- 8 psi
- tomei overpipe, blitz front pipe, perrin exhaust
- dyno tuned at church dyno tuning
93 - 303WHP
e85 - 368WHP
Frs909 is offline   Reply With Quote
Old 06-09-2016, 02:20 PM   #123
MattHoffman
Drives: BRZ Limited
[QUOTE=nelsmar;1331234]I didn't realize this existed!
Nelsmar
Kit: Vortech Supercharger w/ upgraded 3.125" pulley
Fuel: Flex, dyno on E80-E85
Boost: 11.5PSI @ 1,100FT
Fuel upgrades were done, everything else was stock. I took the muffler & OEM intake snorekel off out of curiosity a few days before. Tuned by FA20club on the dyno (flew him in to do it). Hood open was 360WHP, hood closed was 357 with slightly warmer engine temps. Nearly identical between
Wow so you hit 357 with a catted exhaust? That's awesome. How many miles have you put on the car? Still running strong? I am about to make the jump to e85 with a similar setup you have. Pretty stoked after seeing this
MattHoffman is offline   Reply With Quote
Old 07-14-2016, 06:39 PM   #124
lee1rbc
lee1rbc's Avatar
SBD turbo kit
Invidia over pipe
Invidia catted down pipe
Stock exhaust
OFT tuner
10.5 psi
93 oct
2013 BRZ Limited current mods: TD05 20g turbo - Invidia over pipe and catted down pipe - Magnaflow catback - Enkei Fujin wheels. BFG comp 2 A/S 225-45-17.
lee1rbc is offline   Reply With Quote
Old 08-17-2016, 12:53 PM   #125
Jhood
Jhood's Avatar
Originally Posted by Jhood View Post
- Josh / Jhood
- E85 & 93 with Moto-East Flex Fuel Kit
- 9psi
Attachment 137453
Since the last post, I dug a little deeper in the ol pockets and installed a new Exedy Stage 1 clutch, finished 2.5" full exhaust, and went back to Moto-East with E81 instead of E62 to hit the dyno one last time (I say that for now lol) Don't think I'm gonna get much more out of it safely.
*Updated
- 11psi
- FBM 3" Downpipe, Motiv 2.5" Overpipe, Motiv 2.5" Frontpipe (200 cell HFC), & Perrin 2.5" Resonated Catback
- Dyno tuned by Moto-East
7psi on 93 = 257whp/205wtq
9psi on E62 = 302whp/234wtq
11psi on E81 = 340whp/255wtq (+38hp/+21tq)
Old 08-22-2016, 01:14 PM   #126
TRACE_on
TRACE_on's Avatar
Drives: 2023 GR86 - Track BRed Premium 6M
- Greg / TRACE_on
- GReddy T620Z Tuner Kit
- 93 octane
- 10 psi
- Omni 3 Bar MAP Sensor
- Tial Sport Q 50mm Blow-off-valve
- Stock Injectors
- Stock Fuel Pump
- Motiv Concepts Over Pipe 2.5"
- Motiv Concepts Test Pipe 2.5"
- GReddy Supreme SP Catback 2.5"
- ACT HD Performance Street Clutch
- ACT Prolite Flywheel
- 306hp / 245tq - tuned by Hal @ Dynosty (https://www.facebook.com/Dynosty/vid...0060979342634/)
STR also-ran
TRACE_on is offline   Reply With Quote
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Bolt-ons dyno comparisons thread? seven Engine, Exhaust, Transmission 6 11-25-2012 10:28 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 08:06 AM
