Old 05-18-2016, 01:53 PM   #1
iggy
Drives: 2014 WRB BRZ Limited 6MT
Differences between BRZ/FRS Stereos
Hi everyone,
I got my car last week and so far my biggest gripe is the factory stereo.
While doing some research for a new headunit I got to thinking.....What are the differences between the factory BRZ/FRS stereo systems?
I know the headunits are not the same, but is there another hard part that is different which accounts for the 120w difference in power?
I'm assuming the FRS has an additional or more powerful amp which is not present in the BRZ....is that correct?
I did some research and wasn't able to find a definitive answer.
iggy is offline   Reply With Quote
Old 05-18-2016, 02:05 PM   #2
Chimera
Drives: FRS
both US spec cars have an amp in the rear for the door speakers. I thought the BRZs HU was generally more featured.. this Q is difficult to answer as different model years have had different units. TBH IMO if you're going to change the unit, just go aftermarket, its super easy in these cars.
Old 05-18-2016, 07:32 PM   #3
iggy
I may go with an aftermarket unit and am already researching a few, but I still want to figure out what the differences between the two systems are.
Does the FRS have a larger/more powerful amp?
Old 05-22-2016, 02:12 PM   #4
Nissanfan
Drives: subaru brz
Negative. Amps are the same for both "twins". Its the head unit. I'm not sure at the current model year, but prior base head unit and "premium" Bespoke units in FRS were both Pioneer, where BRZ came with Fujitsu ten Units (aka watered down eclipse AVN827). Pioneer units are more powerful and base FRS unit comes with RCA out for Sub, while BRZ units didn't have anything as such.
2013 BRZ Limited 6speed Manual
Nissanfan is offline   Reply With Quote
The Following User Says Thank You to Nissanfan For This Useful Post:
iggy (05-22-2016)
Old 05-22-2016, 02:28 PM   #5
iggy
Thanks for confirming!
So, i guess the next question would be is it possible to swap out an FRS touchscreen headunit for the one into a BRZ?
I've looked at a lot of different aftermarket units lately and while I may wind up getting one of them, i wouldn't mind sticking with a more OE look and having physical buttons.
Old 05-22-2016, 06:35 PM   #6
Nissanfan
Drives: subaru brz
Correct, it's Plug`n`Play swap.
brz ,frs differences nickr Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-27-2013 10:12 AM
Are there any good/recommended aftermarket stereos? redwing634 Electronics | Audio | NAV | Infotainment 23 09-30-2012 02:29 AM
Alarms and Stereos Wally Simmonds AUSTRALIA 6 07-12-2012 02:29 AM
Are FR-S stereos bus based? speedrye Electronics | Audio | NAV | Infotainment 2 04-29-2012 11:19 PM
Sony MirrorLink Stereos ZetaVI Electronics | Audio | NAV | Infotainment 1 02-27-2012 01:58 AM
