Old 05-20-2016, 02:24 AM   #29
humdizzle
Drives: 2018 GT3 / 2015 M3
you guys do realize the systems are still on even though you press the TCS button for 5 sec right??? Drive hard enough and the light will still flash at you on the dash and you will feel the tcs cut in. personally i've usually only seen it on big drift angles or if a wheel catches air.
The only way to really turn off the systems is the pedal dance.
http://www.ft86club.com/forums/showthread.php?t=25494
Regardless, you as a human cannot beat the ECU when it comes to safety. You cannot individually brake certain wheels like it can.
2018 GT3 6MT
2021 M2 Comp DCT
Past: 458 Italia, R35 GTR, E36/E46/F80 M3, 335i, Scion FRS
humdizzle is offline   Reply With Quote
Old 05-20-2016, 02:38 AM   #30
FX86
i only use vsc sport...don't need to turn it all off on the streets but before i pull into the dealership sometimes i turn it all off to make myself seem like a hot shot driver when the kid gets into to drive my car to the back
Old 05-20-2016, 02:51 AM   #31
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
I only turn on Sport Mode when I gotta accelerate out of a turn quickly. I pretty much never turn off the entire traction control. Probably 95% of my driving is with everything on.
ericmpena is offline   Reply With Quote
Old 05-20-2016, 04:09 AM   #32
pfaffendorn
pfaffendorn's Avatar
Drives: 2014 ssm BRZ Limited 6M
Haven't driven RWD in 30 years until the BRZ, and it's been interesting to reacquaint with the idiosyncracies of rear drive. Many quick turns at right-on-red traffic lights will blip the traction system as one of the rear tires lifts, where FWD would pull you around that corner fast and flawlessly. So I leave the systems on all the time, but I often wonder about the gray area and whether on or off would be better. I have experienced being left high and dry with no power for a second only once, but I wouldn't call the middle of a busy intersection "fun."
Anyway, I guess I'm glad the car is equipped. It is a Subaru, after all.
There are worse things to worry over.
pfaffendorn is offline   Reply With Quote
The Following User Says Thank You to pfaffendorn For This Useful Post:
Tcoat (05-20-2016)
Old 05-20-2016, 09:05 AM   #33
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I drive in the street with all the nannies on. I only turn off TCS when i experiment with the car in a relatively safe environment (parking lot etc). i'm not on stock tires, so i have to lose grip on purpose to break them loose, or drive faster than i should in the street, for the nannies to kick in.
shiumai is offline   Reply With Quote
Old 05-20-2016, 10:26 AM   #34
cjd
cjd's Avatar
Drives: 2017 BRZ
I very much doubt you're getting lift... more likely you're slipping the entire rear end a little. Unless you've screwed up your suspension...
Old 05-20-2016, 11:36 AM   #35
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
I turned mine off once two years ago when it snowed a 1/2 inch on the way to work.
Had melted by the time for the the drive home.
Old 05-21-2016, 05:17 AM   #36
NMBRzer
Drives: 2014 BRZ
http://www.beastronix.com/shop/86nanny-speed-academy/.
As a human I'm more predictable than the ECU. On a track I don't want surprises and faster lap times are possible with the system off.
NMBRzer is offline   Reply With Quote
The Following User Says Thank You to NMBRzer For This Useful Post:
Beastronix (05-22-2016)
Old 05-21-2016, 08:56 AM   #37
s0sl0w
Proud of Boxer
On the street I put the car in sport mode as part of start up because the full nanny mode is intolerably intrusive but I leave the system on. There is really absolutely no reason to turn it full off on a public road and I very rarely do. It's a safety net and my ego isn't larger than the 25k check I'd have to write to replace the car. Occasionally I I'll tap the TC button to turn the system off until ~32mph some wheel slip to get out a bit faster.
Off for autocrossing, I've never used the pedal dance and doubt I ever will although the OFT makes it easy to do so.
s0sl0w is offline   Reply With Quote
Old 05-21-2016, 09:42 AM   #38
softgrip
Drives: 2017 BRZ - Dark Grey Metallic
It's super easy.
2x brake and hold, 2x handbrake and hold, 2x brake.
About 5 seconds to turn it off.
It's so easy, I wonder why people bother having a special box to do it. The install time alone, you could have pedal danced a few hundred times.
softgrip is offline   Reply With Quote
Old 05-21-2016, 02:22 PM   #39
kberkel
kberkel's Avatar
Lately I do it every day.
My snow tires are dead.. so I'm just eating up the tread on them for fun. Sliding everywhere
Rain is bad though.. I'll just do sport.
kberkel is offline   Reply With Quote
Old 05-21-2016, 03:43 PM   #40
Originally Posted by brandonblt2 View Post
I would keep it on in the rain especially if you're on stock tires. I nearly hit a curb taking a turn at speed in a light drizzle, the car started hydroplaning mid turn.
My wife and I began our first cross-country trip home from the Bay Area in heavy rain. It stayed with us the entire trip North. I immediately realized that at highway speed, I either reacted more quickly to hydroplane, or had greater tolerance for it than the nannies did. I tried patiently for an hour to work with it both in and out of cruise mode but inevitably, we both ended up correcting for the same thing and the argument actually made things worse. It really messes with my rhythm. The 5-second push does not help. It still interferes with me in many situations.
My wife is super comfortable with my driving. Even in twisties, she just kicks back and does her thing so when I pulled off of the highway and pedal danced, she barely looked up. I noticed the improvement right away but a few minutes in, she looked up from knitting and said something like "Man, that makes a big difference."
So, yeah, I pretty much hate the nannies.
softgrip (05-22-2016)
Old 05-21-2016, 07:36 PM   #41
s0sl0w
Proud of Boxer
Originally Posted by softgrip View Post
It's super easy.
What's your point? I know how to do the dance, and my oft would make it foolproof even if I didn't, I just don't see a need for doing it with driving I'm doing. I've maybe seen the TC light up once when I'm axing with the TC off and it was when things were going very sideways. In other words it wasn't slowing me down.
Old 05-22-2016, 06:19 AM   #42
softgrip
You said OFT makes it easy, and my point is that it's easy anyway.
Turn signals don't always automatically turn off one2onejackpot Issues | Warranty | Recalls / TSB 6 04-18-2016 07:35 AM
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 10:40 PM
Steering wheel issue---left turn lighter than right turn!!! xingxingtjf Issues | Warranty | Recalls / TSB 12 10-14-2015 06:47 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
