go_a_way1
Old 05-18-2016, 09:08 AM   #3445
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
That's how mine is. That's why you check the level while revving to 3k.
Sent from my MotoE2(4G-LTE) using Tapatalk
ScionOfHorus is offline   Reply With Quote
The Following User Says Thank You to ScionOfHorus For This Useful Post:
CSG Mike (05-18-2016)
Old 05-18-2016, 03:03 PM   #3446
SoCalArgento
Drives: 2014 Argento FRS
This may be a stupid question,
So when we check rotrex oil level do we have to be holding at 3K rpm ( needing 2 ppl) or can I rev it that high then go and check?
SoCalArgento is offline   Reply With Quote
Old 05-18-2016, 03:15 PM   #3447
CSG Mike
CSG Mike's Avatar
Rev it, and then go check.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
cgjeff (05-18-2016), Jmonty (05-19-2016), SoCalArgento (05-18-2016)
Old 05-18-2016, 06:37 PM   #3448
cgjeff
Drives: 2015 Scion FRS
Originally Posted by zkahle View Post
Hey guys, i have had the c38 kit installed and running smoothly for about 5 days now. Im still waiting to break in the supercharger sufficiently before doing any WOT. With regards to the rotrex oil level ive checked the level while revving between 2-3k rpm and it appears just fine, when the car is off the oil level is right at the min. I all i used about 780ml of oil and was just wondering how much all of you used when filling up the system.
Is there a break-in period for the SC? I ask because I finished mine on Monday and did not see anything noted in the install manual.
cgjeff is offline   Reply With Quote
Old 05-18-2016, 06:46 PM   #3449
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Around 300-500 miles break-in period.
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
cgjeff (05-18-2016)
Old 05-18-2016, 08:39 PM   #3450
cgjeff
Well, I guess mine is getting broke in hard then... lol. I will be a bit nicer for the next few days.
Old 05-18-2016, 09:08 PM   #3451
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
Rotrex recommends a "run-in" period of 100km (65 miles). This can be found on page 10 of the Rotrex maintenance booklet.
If you did your initial test drives around your city as suggested at the end of the JR manual, you will be fine.
Jackson Racing is offline   Reply With Quote
The Following 3 Users Say Thank You to Jackson Racing For This Useful Post:
cgjeff (05-20-2016), Jmonty (05-19-2016), zkahle (05-19-2016)
Old 05-19-2016, 10:39 AM   #3452
CounterSpace Garage
Well looks like Rotrex has stated a far lower number, which is great for everyone. We tend to ease into things quite nicely. Gotta warm up the oven before you bake right?
cgjeff (05-20-2016)
Old 05-19-2016, 02:41 PM   #3453
dp1
driving smoother faster
Drives: Sold
Jackson Racing Supercharger Owners Thread
Two days at Pocono Raceway with recently broken in C38 and @DeliciousTuning Flash and Go (FNG) tune and other mods...just what the doctor ordered.
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
CSG Mike (05-19-2016)
Old 05-19-2016, 04:52 PM   #3454
Hicklinc
Drives: N/a
Im interested in more info on this like mods, dyno numbers, lap times
Sent from my SM-N910T using Tapatalk
Hicklinc is offline   Reply With Quote
Old 05-19-2016, 04:55 PM   #3455
zkahle
zkahle's Avatar
Drives: 2013 Scion FRS Asphalt
Also have a c38 and flash n go tune but no track days for me.... So after driving around for the past couple of days with my OFT plugged in I noticed that no matter how long I've had the car on for my oil temp has never exceeded 190 degrees. I know the optimal engine oil temp range is slightly above 200. Is there any reason why I've been fluctuating around 175-185? I know the thermostatic plate kicks in at 185. Also I live in Texas so it's far from cold here. Last night it was 75 degrees out and asides from when I attempted a 3rd gear pull I never got over 180 degrees... Should I be concerned?
Hook Em'
zkahle is offline   Reply With Quote
The Following User Says Thank You to zkahle For This Useful Post:
Hicklinc (05-19-2016)
Old 05-19-2016, 05:17 PM   #3456
CSG Mike
CSG Mike's Avatar
Oil temp is read post-cooler, not pre-cooler. You're totally okay.
Water boils at 212F, but it'll evaporate off at a much lower temperature.
Old 05-19-2016, 06:12 PM   #3457
dp1
Drives: Sold
Mods - link is in my sig.
Dyno - Don't care for it so don't have it. My car works very well due to advice from my favorite suppliers (i.e., CSG) and work by my mechanics (i.e., EFI Logics) and tune from my tuners (i.e., Delicious Tuning), and because of some valuable contributors to this forum.
Lap times - I am on the slow side of fast - an instructor and a TT driver with twins, both without SC, usually have few or several seconds on me per 1.5 - 2 min lap. I could run faster laps but I usually focus on certain parts of the track and techniques, and letting faster drivers by. Some track videos are on youtube under dpsend1.
To me, JRSC is worth every penny spent.
The Following 5 Users Say Thank You to dp1 For This Useful Post:
Bramick (05-21-2016), cgjeff (05-20-2016), CSG Mike (05-19-2016), Hicklinc (05-19-2016), Jackson Racing (05-19-2016)
Old 05-19-2016, 07:01 PM   #3458
kch
Senior Misanthrope
kch's Avatar
My understanding is that thermostatic plates will always let a little bit of oil through, even under temp. It's not just a trickle, either. I have a 180* thermostat connected to a setrab 619 and my oil doesn't go above 170 on the highway.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
