Old 05-13-2016, 04:39 PM   #1415
BurnetRhoades
BurnetRhoades's Avatar
Drives: 2013 "Hot Lava"
Originally Posted by tooslow4umayne View Post
Hey man how long did it take you to install that reverse lock out? Looks sick! is it hard to install ?
Thanks! Yeah, I love it. It's got a more positive feel and sound when you go into reverse than the plastic one. And I love the Slammer too. One thing about the pictures is it looks like it might have a rough texture from the brushed metal but it's totally smooth. And the Slammer plus having replaced my fluid with Motul makes for pretty much effortless shifting. I can shift by fingertips.
It should only take a few minutes if you're lucky with the roll pin on your stock RLO. I wasn't so lucky. I started out with trying to use the long end of a 2.5mm (I think that's right) allen key. It wasn't having any of it. Even giving the end of it a good tapping didn't budge the roll pin. Other folks have had their's plop right out without a lot of force but these were not the tools for one being sticky.
So I went to Home Depot and got a rubber hammer and a modular punch with an assortment of sizes (seen on the floorboard of my picture). All of the punches they had were essentially progressive, so the rated size is essentially for the tip but it gets fatter along the shaft of the punch. I don't know, perhaps that's normal, but this made for a lot of effort. I destroyed that stock RLO hammering that punch through. Split it, and had a piece nearly smack me in the face when it broke off.
Hammering on that punch felt so wrong but it worked, and I've seen more than one video where this was necessary. But the shifter itself wasn't damaged at all and the new pin for the new RLO went in like butter. Then it's just a matter of a few tries with the locking adapter and the new shift knob to get it perfectly aligned. So, if you've already got the tools you're looking at a few minutes at the fastest, maybe fifteen if it's being a little stubborn. Main thing that will add time is getting over the feeling you're going to break something (at least for me that was the case).
I will echo one thing I read online though, it's better to pop the ring around your shift boot and lift it off the top, rather than pull it down and away from the RLO. Everything'll go back together quicker and smoother and it gets it out of the way while you work.
2013 Hot Lava FRS :: OFT Stage 2+ :: JDL UEL Catless :: JDL Over-Frontpipe :: GReddy Evolution RS Catback :: Enkei "Tarmac Black" RPF1 :: Tein Flex-Z Coilovers :: 245/35r18 Conti DW :: RS*R R-LCA :: Racer-X Fab R-Toe Arms :: Mishimoto Intake Tube :: Mishimoto Oil Catch Can :: JDL FSTB :: Raceseng "Slammer" + RLO :: Diode Dynamics HID + Tail-as-Turn + DRL :: 5:AD Spoiler ::
BurnetRhoades is offline   Reply With Quote
Old 05-13-2016, 04:47 PM   #1416
Irace86
Drives: BRZ + Ducati M796
Originally Posted by stevemp5 View Post
the part for me the hardest was to find the right diameter punch. Loll but that pin out alone
Even if the punch is right it can be tough to get it in and out. Getting it in can be much easier by freezing the pin and heating the RLO, so the metals contract and widen, respectively. Still terrible.
Irace86 is offline   Reply With Quote
Old 05-13-2016, 10:37 PM   #1417
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
It's coming
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 05-14-2016, 04:45 AM   #1418
churchx
churchx's Avatar
Drives: 2014 GT86
Add crest to that above and one will have Holy Hand Grenade of Antioch shift knob
Old 05-14-2016, 08:09 AM   #1419
Norville Rogers
Drives: Subaru BRZ
What do you need to count to?
Norville Rogers is offline   Reply With Quote
Old 05-16-2016, 09:15 AM   #1420
HunterGreene
Hail Magnet
HunterGreene's Avatar
I think its either 2, 3, or 4. I know 5 is right out. I think there is a book somewhere with the instructions.
It has priests in it?
Old 05-16-2016, 10:03 AM   #1421
Old 05-16-2016, 03:41 PM   #1422
Norville Rogers
Drives: Subaru BRZ
Real men don't read instructions.
Lobeth and go I say..
Old 05-16-2016, 08:23 PM   #1423
Attrm
Drives: 2016 Brz wrb limited
Anybody know how to cover up the rest of the screw?
Attrm is offline   Reply With Quote
Old 05-17-2016, 08:36 AM   #1424
Bamsterman
Drives: 13' Scion FRS
Originally Posted by ShadowReaper View Post
It's coming
Making it yourself, or do you know a company making them? I've seriously been holding out for one!
Bamsterman is offline   Reply With Quote
Old 05-17-2016, 09:38 AM   #1425
Cope
Driver
Cope's Avatar
Drives: Black 2013 BRZ
Originally Posted by Irace86 View Post
The phrase, it's easy to do, never should be uttered with, removing a RLO. Shit is not easy. Sure there are only a few steps but getting that pin out was a bitch.
Totally agreed - started with a punch and all that did was mangle the pin. Took me a six-pack of drill bits (and a few hours) to get that effer out.
Cope is offline   Reply With Quote
Old 05-18-2016, 11:52 AM   #1426
ShadowReaper
Indulgent Tormenter
I just googled "star wars sticks shift knobs" that one came up.. it's by Etsy
Old 05-18-2016, 03:24 PM   #1427
Bamsterman
Yea I've seen that one then. I was hoping someone was making a legit weighted knob
Old 05-18-2016, 07:40 PM   #1428
myasis14
Drives: 2014 Whiteout FRS
http://bloxracing.com/shop/index.php...ath=65_120_161
I have the same shift knob. I used a lockout level adapter. Did the trick.
myasis14 is offline   Reply With Quote
knobs
Shift Knob Jwong FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 29 12-12-2014 01:33 AM
Kartboy Shift knob Spartan65 Interior Parts (Incl. Lighting) 8 10-03-2012 06:18 PM
any other shift knob? oso_25 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-31-2012 01:38 AM
TRd Shift Knob GaN-MaN Cosmetic Modification (Interior/Exterior/Lighting) 1 07-24-2012 01:57 PM
