Old 05-17-2016, 04:37 PM   #1
SlammedSilly
Drives: 2015 Ultramarine FR-S
coilover/tire question
whats going on guys, im about to order a set of BC BR extreme lows with 10k all the way around, depending on the answer to this question. if not i will be purchasing regular BC BR's with the same spring rates.
ok, so for the winter time i run a 205/55/16 snow tire on 16in forester wheels... now if i buy extreme lows and raise it as far is they go, will that tire size still fit with factory alignment measurements?
im not a dedicated, keep my car low all year type of guy at all, id like to be able to raise it up for winter and down for "show season" ha.
also for "show season" will i be able to fit a 235 in the front and a 255 on a 17x9i wheel? i just want to make my decision easier on the BC BR's and the extreme lows!
any information would be highly apprecitated!
SlammedSilly is offline   Reply With Quote
Old 05-17-2016, 04:54 PM   #2
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
Raising it up for winter should be fine. Which ever bc's you buy get the one with min setting between 0.8-1 and you should be fine. Don't forget to do realignments every time you adjust the height, since it'll change your toe.
235 on 9 might look a bit stretched compared to 255's. But it's doable if you are ok with the look.
You understand that if you plan on dumping your car any more then and inch drop you'll have to get adjustable toe rods, enlinks, and lower control arms for the back right? Adjustable top hats might almost be needed for all that negative camber.
Good luck tho, I'm sure it'll look sick.
jimmillion is offline   Reply With Quote
The Following User Says Thank You to jimmillion For This Useful Post:
SlammedSilly (05-17-2016)
Old 05-17-2016, 05:00 PM   #3
SlammedSilly
Originally Posted by jimmillion View Post
Raising it up for winter should be fine. Which ever bc's you buy get the one with min. Setting between 0.8-1 and you should be fine.
yea man, im set on tire size, a few of my friends run that size on 9.5 all the way around. but the rear i plan on just getting the natural camber for the time being, ill order the rest of my rear suspension next month since im still on stock wheels
Old 05-18-2016, 02:55 PM   #4
SlammedSilly
so no one runs extreme lows and then raises to put a snow tire on in the winter?
Old 05-19-2016, 12:58 AM   #5
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
I would recommend the "stock" 8k/8k bc racing coilovers over the custom 10k/10k. The 10k is very stiff for our cars and you'll be giving up ride quality. You'll only need the 10k if you're planning on dropping the car extremely low, like collars removed and whatnot.
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
SlammedSilly (05-19-2016)
Old 05-19-2016, 03:01 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
.. or consider higher quality dampers. Penskes, AST, Tein SRC .. from their reviews they are comfortable enough with even higher spring rates, so i wouldn't write such rates as in general too unusable/too stiff.
nickmerronesucks (05-19-2016)
Old 05-19-2016, 09:22 AM   #7
SlammedSilly
see ive driven a frs with 10k all the way around and i didnt mind it, mind you i wasnt driving on a shitty rd here in pa, haha. i basically just wanna know if raising the car all the way up on extreme lows will my snow tires fit, haha
another coilover question brz fred Suspension | Chassis | Brakes -- Sponsored by 949 Racing 73 05-11-2016 07:56 PM
Replace Only 1 Tire? / Spare Tire Question chermo12 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-28-2015 01:44 PM
coilover question Sketchi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 09-27-2014 06:00 PM
BC BR Coilover adjustment question. HATED1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 04-12-2013 12:59 PM
To coilover or spring? That is the question... Knightmare Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 01-13-2013 10:34 PM
