#113 | |
Drives: Asphalt 2015 FRS
How did you get all the brake lights to be on without anyone pressing the pedal? Please enlighten me, as I am a car noob Thanks! |
#114 |
Old Mechanic
Drives: 2013 Limited BRZ
Brick, or I use a windshield scrubber (like the ones at the gas station) put it on the pedal. Wedge it in front of the seat and move seat fwd to push on the brakes.
Sent from my SAMSUNG-SM-G930A using Tapatalk |
#115 | |
Memphis
Drives: 1989 MR2 S/C, 2014 Scion FR-S
"It's ok... It's not structural."- Mikey
#116 | |
Wasn't sure if I was missing something and there was some way to enable all the brake lights without the pedal being depressed..which would definitely come in handy if I want to, say, check to make sure none of the lights are burnt out. Guess I will stick to having a friend help out! |
#117 |
Memphis
Basically done. Figured I would snap a few pics and show you guys can get some closure and I can stop feeling like there are guys dying to see what it looks like :P hope you guys enjoy it. I will post more pictures when it gets wrapped and fully installed.
| The Following User Says Thank You to MemphisR For This Useful Post: | zeal86 (02-20-2017) |
#118 |
Drives: GTS 86 auto
People interested in brake lights may be interested in a recent project in "Silicon Chip" magazine. The project causes the brake lights to come on sooner if it detects your foot coming off the gas pedal hastily i.e. before your foot hits the brake pedal.
GTS86 Auto (Australia)
#119 |
Drives: 14 FR-S
#120 |
Drives: 2015 Subaru BRZ
@MemphisR it looks awesome!!! what did you use to make it? was it wood and how thick and did you paint it or wrap it in the carpet stuff or did you what did you use to secure it to the headliner?
I'm so exited about this, I can't wait to find a junk yard that has one of these to just pull out for cheap. |
#121 | ||
Memphis
As for wrapping, I bought some nice, fake, but nice faux Alcantara. I plan on wrapping more, so thus my use of it on the brake light. I also used that to wrap my rear deck and cover the holes of the old brake light. I mounted/centered it using the three clips at the back of the headliner and some double sided tape to fix it to the rear window. Hope this helps, MemphisR Quote:
Sent from my E6883 using Tapatalk
#122 | |
Drives: Grrrr
So the brake light will flash every time you change gear? |
#123 |
Drives: GTS 86 auto
How simple would it be if you attached one of those l.e.d.s-on-tape strips across the top of the window? It could possibly have a 30mm strip of black plastic stuck on the underside OR be tucked just inside the roof lining for neatness and from inside you wouldn't see it when lit up.
Patent pending
#124 |
Drives: GTS 86 auto
I guess you are right come to think of it . I didn't see that mentioned in the article. It would soon bother the driver behind. Maybe it assumed auto-transmissions. Maybe, just changing gears, you don't come off the gas pedal suddenly as you would when emergency braking.
| The Following User Says Thank You to notout86 For This Useful Post: | Scrappydoo (03-07-2017) |
#125 | |
Memphis
-MemphisR Sent from my E6883 using Tapatalk
#126 | |
Drives: GTS 86 auto
| The Following User Says Thank You to notout86 For This Useful Post: | MemphisR (03-07-2017) |
| ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD! | ZILLA | DIY (Do-It-Yourself) Guides | 117 | 09-19-2017 10:17 AM |
| **PHASTEK** Rear Fog Light/Brake Light Kit for the Scion FR-S and Subaru BRZ | PhastekSport | Exterior Parts - Lighting | 57 | 07-10-2017 08:14 PM |
| 4th Brake Light/Rear Fog Light Kit FRS/BRZ/GT86 - $59.95! | Vicious LED | Groupbuys | 58 | 01-05-2014 05:13 PM |
| For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! | Vicious LED | Exterior Parts (Aero, Lighting, Etc.) | 9 | 08-25-2013 07:26 PM |
| 4th Brake Light Mod | boredom.is.me | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 12-29-2012 01:46 AM |
