go_a_way1
Old 05-17-2016, 03:09 PM   #183
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by VeloxEric View Post
Constructive thoughts and comments always appreciated.
I went with SPL because of the lower mounting hole so I can get the ride height down and retain more travel in the rear.
The GC coilovers I purchased used really need a 1" shorter spring. But I needed an LCA anyway.
OkieSnuffBox is offline
Old 05-17-2016, 03:11 PM   #184
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
We cannot do this, not enough meat, they'd crack.
Originally Posted by churchx View Post
I recently ordered LCAs with PB .. my only suggestion would be - adding separate purchase option of end with STX legal bushing only, so that if i'd ever decide on STX compatibility, i could order only differing parts in simple fashion.
Just contact us and we can make that happen. It's not worth it to create another part number and have a sales page for just two bushing ends but we'll gladly accommodate if the need arises. Same with spherical rod end replacements when they wear out... just contact us.
VerusEric is offline
Old 05-17-2016, 04:16 PM   #185
OkieSnuffBox
Yeah, we chatted about it on BookFace.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
VerusEric (05-17-2016)
Old 05-17-2016, 11:27 PM   #186
laextreme5
laextreme5's Avatar
Drives: 2014 BRZ
We are nearly out of LCAs from our production run, so grab them quick before FT86 SpeedFactory is out!
We'd like to hear from both the people with the LCAs and without. What are your thoughts on the product and should we do another run? The design will not be changed as we have already done all the R&D we care to for this design.
Thanks,
Eric
I would buy a set if available. Just looked at your site today and saw out of stock then i got sad. Im not to the point of requiring them and would purchase them till i had my other components, but the early purchase would be worth it simply because of the r and d and testing you guys have done.
BUILD ANOTHER BATCH
laextreme5 is offline
Old 05-17-2016, 11:33 PM   #187
k_mono_FRS
k_mono_FRS's Avatar
Drives: 94 EG6 si, 97 DelSol si, 14 Monogra
I'm torn between these LCA's and RacerX. I love the way these look but I like the fact that RacerX makes theirs available in a raw finish. If by any chance I can purchase yours in a raw finish this would seal the deal for me on Velox. (fingers crossed)
k_mono_FRS is offline
Old 05-18-2016, 07:12 AM   #188
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I really want to buy your LCAs but not until I buy coil overs this later this year. So I am in for another production run.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline
Old 05-18-2016, 08:06 AM   #189
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
Same boat.
I'll wait for next batch.
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline
Old 05-18-2016, 10:54 AM   #190
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
BUILD ANOTHER BATCH
Have you tried ft86speedfactory? Says in stock. http://www.ft86speedfactory.com/velo...l#.VzyCEcspBnE
Mad_Mike is offline
Old 05-18-2016, 01:43 PM   #191
VerusEric
VerusEric's Avatar
BUILD ANOTHER BATCH
FT86SF still has some in stock
We can offer it in raw but aluminum does corrode over time.
Sounds good.
Originally Posted by brzzy View Post
Same boat.
We're leaning that way just wanted to ask.
FT86SF wants to offer more colors this go around as well. While we believe hard anodize (black) to offer the best surface protection, blue and red will potentially be available as well.
Thanks,
Eric
Old 05-18-2016, 06:06 PM   #192
churchx
churchx's Avatar
Drives: 2014 GT86
VeloxEric: above practical reasoning imho black color also goes well with rest of your products, eg. aero ones, making it out as some characteristic branding color. And just as there are customers wanting more bling, there are also ones preferring more classic/OEM-ish/less standing out & rice-ish looks.
churchx is offline
VerusEric (06-30-2016)
Old 05-19-2016, 03:40 AM   #193
k_mono_FRS
k_mono_FRS's Avatar
When and how can I order a set in a raw finish? I live in sunny SoCal and I don't drive my FRS in the rain so I'm not to concerned about corrosion. Maybe a anodized clear? Thanks in advance!
Old 06-30-2016, 12:20 PM   #194
FrostedFlakes
Drives: 2013 Raven FRS
Tie rods would be difficult to compete with. Whiteline has that pretty well sorted from a price stand point, I see us being easily 2xs that price. But we could do it and they'd be lighter .
I am gonna renew this comment again. I just found out Whiteline has discontinued their roll centre and bump steer kit. I have no idea why.
Maybe it would be worth considering developing a Velox tie rod?!
FrostedFlakes is offline
Old 06-30-2016, 12:27 PM   #195
VerusEric
VerusEric's Avatar
We'll have some in raw (or if you want clear we can do that) for this run. Clear will be a bit more expensive unless we have a few guys wanting clear.
Front or rear? We have rear toe control link kit with bump steer adjustment. We can look into front for sure.
Thanks,
Eric
Old 06-30-2016, 12:34 PM   #196
FrostedFlakes
Thanks,
Eric
Front. Whiteline KCA435 has been discontinued. Not sure but it would be cool to have something of good quality in design and would last. Including the ball joint replacements for the front control arms.
As you mentioned before that is a kick ass combo which was hard to compete. However, since it has been discontinued.... off to more expensive alternatives and better ~!!
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 09:15 AM
Verus' Shop BRZ - Development Thread VerusEric Member's Car Journals 266 12-19-2019 04:12 PM
FT-86 SpeedFactory Diffuser by Verus - Complete Aero Solution FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 574 09-15-2019 10:10 AM
FT-86 SpeedFactory Turbo Kit - Development and Testing FT-86 SpeedFactory Forced Induction 271 09-19-2017 11:07 PM
Front Wheel Deflectors - FT-86 SpeedFactory by Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 25 09-22-2016 01:41 AM
