Drives: 15' Dark Mettallic Gray BRZ Manual
How to ADD subwoofer to NEX 4200
![]() My car got broken into and they damaged the stock head unit so I installed the pioneer NEX 4200. I had it installed at a shop for insurance purposes so I dont know exactly how they hooked it up. I know the headunit has subwoofer auxillary outputs so I know I would just connect the amp and sub there. My question is how would I stop the factory speakers from punping out the bass? I installed a system in my other car but changed everything so this wasnt an issue when I did it the first time. Sent from my SM-G930V using Tapatalk |
#2 |
just tune it from the headunit. play around with the cross-over.
#3 |
#4 |
Off Topic
In the head unit you can set a low pass filter for the subwoofer and a high pass filter for your mids and highs. Set them both to the same thing, like 100 Hz. The sub will play everything below 100 Hz, the mids and highs will play everything above 100 Hz.
#5 |
Drives: FRS
Depending on your sub, having some gap isn't necessarily bad, I have my sub set at lpf 80 12db and my fronts at hpf 100 12db
#6 |
Drives: 14 BSP Edelbrock BRZ
Pick up the microphone for the unit for $20 bucks. It will set up the equalizer, crossovers and time alignment for you.
#7 |
All good advice Ill play with the frequencies to see what sounds the best with my setup! 100 hz is a good benchmark to start at. Thank you.
#8 | |
#9 |
Just Google auto eq microphone NEX 4200. It is $20 on Amazon. The head unit plays white noise and a series of pulses that the mic pics up and it will set eq, crossover (if you have a sub), speaker levels and balance based on what it measures. More importantly for a good sound stage it will set up time alignment for the speakers. If you are using stock speaker placement and amplification the alignment won't be as good as if each channel were a separate speaker, but it will be better than what you have now.
Sent from my Nexus 6 using Tapatalk |
#10 | |
#11 |
The way things are wired make doing this kind of an all-or-nothing proposition. If you have a 4 channel I would power the dash speakers as a pair (3" and tweets) for 2 of the channels and the door speakers as the other 2 channels provided you have a high pass xover for the dash speakers and a low pass for the doors built into the amp. Set the headunit up to treat the door speakers as rears and the dash as front. That will result in the best time alignment setup and allow the head unit to automatically set the levels for each speaker when doing the autoEQ. If you add a sub just redo the measurement and the head unit will align the sub channel as well. I found that in my car the measurement resulted in the sub channel being set to -8, I raised it to -2 to compensate for road noise and the type of sound I wanted.
#12 | |
#13 |
I don't like rear fill and the speakers back there are garbage, so yes, I would propose you only drive your dash and door speakers. You absolutely could go with a set of components but the time alignment values would be a compromise (would still sound much better than what you currently have) since the distance from each tweeter to your head is different than the distance from each door speaker to your head. Also, if you use active crossovers (in the amp) you don't need the space for the component crossovers and you don't get the phase delay that they add (most come with a phase switch so this part at least is kind of moot).
#14 | |
| Brz subwoofer in an Frs?? | slyder | Electronics | Audio | NAV | Infotainment | 2 | 05-07-2016 11:56 PM |
| Subwoofer box | Bhim | NY / NJ / CT / PA | 5 | 03-13-2015 03:21 PM |
| 4 Subwoofer fit? | Iceblazer | Electronics | Audio | NAV | Infotainment | 19 | 11-27-2013 08:17 PM |
| subwoofer fit | Dsmith1992 | Electronics | Audio | NAV | Infotainment | 7 | 09-26-2013 05:47 PM |
| Subwoofer? | yomchi1989 | AUSTRALIA | 31 | 09-06-2012 09:23 PM |
