go_a_way1
Old 05-12-2016, 03:53 PM   #3431
asnatlas
Drives: 2013 - BRZ - SWP
Post
Originally Posted by _Se7en_ View Post
FWIW...
I was recommended DW700CC injectors and DW300C pump with C30 and FF kit.
I will be running full exhaust setup. Will be seeing about 320whp.
1000cc seems like overkill but I guess depends on your hp target....
Sent from my SM-N920T using Tapatalk
I have JDL UEL headers that are going on the car soon along with an front pipe, over pipe, and full exhaust.
I was thinking that the ID1000cc seemed overkill but those were recommended as being better / easier to tune then the DW700cc.
This is the one reason I wanted to post what setup I am looking at before jumping in.
asnatlas is offline   Reply With Quote
Old 05-12-2016, 03:59 PM   #3432
CSG Mike
CSG Mike's Avatar
Originally Posted by asnatlas View Post
I'm looking at the following items:
JRSC C38 SuperCharger Kit
JR Oil Cooler Kit (JRSC version)
Radium Dual Oil Catch Can Kit
DW300c Fuel pump
ID1000cc Injectors
Anyone see anything wrong with this setup? Am I missing anything other then a EcuTek license and tune (still researching and debating).
I picked up the following items gently used:
ACT-XTSS clutch kit
EcuTek cable and dongle
Delicious Tuning Flex Fuel kit
We're missing your order!
ID/DW injectors all use Bosch cores, but we don't see the need to spend extra money on huge injectors unless you think you'll actually need it. 1000CC injectors on this platform with E85 is 600whp...
Originally Posted by Hicklinc View Post
I dont think you need injectors or a pump to run e85 unless your going high boost pulley which it is suggested to build the motor if you have the c38 but i could be wrong
Sent from my SM-N910T using Tapatalk
It's not mandatory but you'll run out of fuel up top if you don't, even on a C30 with standard pulley.
Hicklinc (05-12-2016), _Se7en_ (05-12-2016)
Old 05-12-2016, 04:00 PM   #3433
SoCalArgento
Drives: 2014 Argento FRS
I have very simple setup to you with E85 and was too recommended to run upgraded Fuel Pump and Injectors.
You're gonna enjoy the E85 ^_^
SoCalArgento is offline   Reply With Quote
The Following User Says Thank You to SoCalArgento For This Useful Post:
Old 05-12-2016, 04:11 PM   #3434
_Se7en_
Drives: Whiteout Scion FR-S
Damn. Just curious what whp are you getting with you particular setup?
I'm getting antsy on all parts to come in! Last item are my Ace headers.
Want to experience the E85 goodness.
_Se7en_ is offline   Reply With Quote
Old 05-12-2016, 04:13 PM   #3435
SoCalArgento
Funny thing is I'm curious as well, I haven't had the chance to dyno to see what I'm getting at the wheels but e85 over 91 is definitely noticeable.
Old 05-16-2016, 12:58 AM   #3436
asnatlas
I am debating between these two engine mounts...
Perrin (read about some melting with FI setups)
Cusco (stiffer and seem to cause more NVH then Perrin)
Those who upgraded their engine mounts, what did you go with ?
Old 05-16-2016, 01:17 AM   #3437
byun
byun's Avatar
Drives: 2015 BRZ CWP
I went with the sti motor and tranny mounts. Made a nice difference with no increase in nvh that I've noticed. Things just feel tightened up.
byun is offline   Reply With Quote
The Following User Says Thank You to byun For This Useful Post:
CSG Mike (05-16-2016)
Old 05-16-2016, 11:33 AM   #3438
uRBAN_Metal
Drives: '13 BRZ
Hmm, I spoke with a few people who stated that if I was going to run E85 I would need to upgrade the fuel pump and injectors. I am not planning on going with the high boost pulley until later once I build up the engine down the road.
Injectors, yes. Fuel pump, no.
I ran e85 on a c30 with DW 700cc injectors with no issues for a year. I only upgraded my fuel pump when I went to the HBP this weekend. Upgrading the pump won't hurt anything, though. If you want to go high boost at some point it may just be worth getting it out of the way, but your clutch would be a bigger deal at that point.
uRBAN_Metal is offline   Reply With Quote
Old 05-16-2016, 01:11 PM   #3439
axelthrasher
Drives: BRZ, 2 WRXs, 818S, motorcycles, etc
Just wanted to throw this out there to make it known for others that may hear this noise/sound...
This morning while driving my JR SC BRZ I noticed my Kayser (part # 3.023.348) BPV/diverter valve was making a fluttering noise - more-so than the normal "pshwoosh" sound that it would make. Decided to search for possible leaks and I found the vacuum hose (on the small nipple) had a split about halfway through the hose - this was causing the leak and the fluttering noise.
Hopefully this can help someone out in the future if needed.
axelthrasher is offline   Reply With Quote
Old 05-16-2016, 04:55 PM   #3440
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
At least is sounded sexy(;
Alltezza is offline   Reply With Quote
Old 05-16-2016, 05:08 PM   #3441
CSG Mike
CSG Mike's Avatar
You will need a Fuel pump with FI and E85 (on anything that makes more power than an InnovatE).
Log your fuel pressures and/or watch the amount of time the PI stays open up top, and you'll see why. Without a fuel pump, your power will nose over and while you won't blow up your car with a safe tune, you'll be missing out on a lot of power.
Old 05-16-2016, 05:09 PM   #3442
CSG Mike
CSG Mike's Avatar
Make sure the vacuum hose is routed away from sharp edges and/or heat sources
Old 05-16-2016, 05:42 PM   #3443
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
DW300c Fuel pump
ID1000cc Injectors
ACT-XTSS clutch kit
If you're planning e85 a pump and injectors definitely aren't a bad idea, that being said I doubt you'll be needing 1000cc (major overkill I think), 700-750cc should be more than plenty.
fumanchu1 is offline   Reply With Quote
Old 05-18-2016, 12:01 AM   #3444
zkahle
zkahle's Avatar
Drives: 2013 Scion FRS Asphalt
Hey guys, i have had the c38 kit installed and running smoothly for about 5 days now. Im still waiting to break in the supercharger sufficiently before doing any WOT. With regards to the rotrex oil level ive checked the level while revving between 2-3k rpm and it appears just fine, when the car is off the oil level is right at the min. I all i used about 780ml of oil and was just wondering how much all of you used when filling up the system.
Hook Em'
zkahle is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
