Old 05-10-2016, 02:21 AM   #7155
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Oh shit that looks horrible. This makes me wonder if a high flow cat is necessary
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 05-10-2016, 08:14 AM   #7156
walletsr
Drives: 2014
Stock exhaust running stock pulley on 335 with e85 we are still trying to find out cause but clogged header is part of it.
Originally Posted by Rifle View Post
If I'm looking at this correctly... hole in the block. Cat in the overpipe.. which leads me to believe you had a catted header. Pushing more PSI than stock pulley? Bad idea to begin with. That back pressure would have been unreal... if not, then just pushing too much to begin with.
walletsr is offline   Reply With Quote
Old 05-10-2016, 11:21 AM   #7157
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
If I remember correctly, the stock pulley on the 335 pushes more boost than the smaller pulley on the 210. Which means you were trying to force 12+psi through a Stock Catted header at that. You basically tried to double the amount of air the exhaust would take, and left the brick wall in place.
My assumptions of what happened, based on what I know about the system.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 05-11-2016, 04:49 AM   #7158
Rich196
Drives: GT86
New to superchargers with the 86, and bought mine already done. I miss pops and bangs on over run from the exhaust, is this just the nature of a super charged 86? My BMW 135i did it loads and I love it.
The car is running sprintex with OEM header, and hayward and scott exhaust system, no second cat. It sounds great but I would like the pops and bangs on over run.
Older mini cooper S that are supercharged do it loads...
Rich196 is offline   Reply With Quote
Old 05-11-2016, 06:41 AM   #7159
Kodename47
Kodename47's Avatar
Drives: UK GT86
You could possibly try and tune it in, it's just getting the timing and fueling correct to do it.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-11-2016, 11:38 AM   #7160
stockysnail
Just the tip
stockysnail's Avatar
My tune from Moto-East has a map specifically to do this.
Old 05-11-2016, 11:48 AM   #7161
Rifle
Rifle's Avatar
My catless car does this plenty. Get rid of that cat.
295WHP/220TQ
Old 05-11-2016, 11:24 PM   #7162
Rifle
Rifle's Avatar
My blower is leaking oil out of the bottom side of the charger, behind the pulley.. No idea where.. but wth?
295WHP/220TQ
Old 05-12-2016, 12:33 AM   #7163
riboyster
riboyster's Avatar
There has been speculation that excessive pressure builds in the gearbox at temperature and pushes oil beyond the gaskets.
I went ahead and vented the pressure while it was at temp by loosening the dipstick and tightening it again. Presumably it runs at in equilibrium now at temp, and under vacuum cold.
Old 05-13-2016, 01:30 AM   #7164
Arcade_West
Drives: Subaru BRZ
this has probably been asked before, but do you have to read the dipstick level with the supercharger unit parallel to the ground? Because it sits like 10 degrees crooked. Also where does the oil have to be on the dipstick? At the line?
Arcade_West is offline   Reply With Quote
Old 05-13-2016, 02:24 AM   #7165
stockysnail
Just the tip
Yes and Yes. Put a level on top of the supercharger and jack up the rear until it's level or put your car on a slope.
The Following User Says Thank You to stockysnail For This Useful Post:
Arcade_West (05-13-2016)
Old 05-13-2016, 09:49 AM   #7166
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Out of curiosity - how many here have installed post IC temp sensors on the Sprintex 335? We have one we have been messing with one for a while and this thing is a heat monster. Have seen up to 110C intake air temps by the end of a single 4th gear pull. And this is with two massive 4000 CFM squirrel cage fans on the heat exchanger. Sprintex has been refusing to tell me what temps I SHOULD be seeing post IC, and they also are unable or unwilling to provide compressor maps so we can try to figure out what efficiency we are at.
Boosted2.0 is offline   Reply With Quote
Old 05-13-2016, 02:30 PM   #7167
stockysnail
Just the tip
^ is one of the two reasons I'm weary of upgrading to the 335 from 210. The other reason is cost + power supporting mods like clutch. Too many people have posted that they've blown their engines. Yes I know Moto-East ran it fine even on the track, but I'm still weary.
Old 05-13-2016, 02:59 PM   #7168
chargedup
Drives: SC BRZ
Does anyone have a sprintex kit w/ an invidia n1? sound clips?
Also figured out why my setup wasn't running right. Dealer advertised the car w/ a nameless axelback and that's what the tune was set up for, turns out they swapped it for full stock exhaust. Picking up an n1 this weekend!
chargedup is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
