Old 06-18-2012, 07:22 PM   #71
Asterisked Accolade
Pedals over Paddles.
Asterisked Accolade's Avatar
Drives: Celica GT-S | 89 Supra | 07' Accent
Exactly.
2002 Celica GT-S Track Car | 1989 Supra Track Car | 2007 Hyundai Accent AutoX | 2003 Cadillac CTS Daily
Asterisked Accolade is offline   Reply With Quote
Old 06-18-2012, 07:31 PM   #72
Jason@Nameless
Jason@Nameless's Avatar
Drives: '88 BMW 535is Turbo
Originally Posted by celica73 View Post
I'd really like to see that exhaust with a single muffler and single tip. It seems rather tortured to put the Y in there. It should be lighter and cheaper that way (and not suffer performance in the least).
We can easily put a tip and single 4" or 5" muffler into this:
Subaru BRZ Single Exit Track Axleback Muffler Delete
It's $99 as pictured and saves 23lbs. There is no performance loss to the Y from our experience comparing our STi Hatch vs. Sedan exhausts. We will verify this on the BRZ when we head back to the dyno this week running the track single exit axleback vs. the street dual exit. We do a stepped Y to minimize division loss at the Y and bias torque. On our WRX & STi catback, we make ~32ftlb of torque over a baseline of a Stage1 off the shelf tune. 19-22whp.
One other note regarding the layout of that Y on the BRZ & WRX/STi Hatch: we did a lot of testing on this and adding the additional bend required to run the Y vertically instead of horizontally certainly makes more of a beneficial difference than it does a detriment as it splits flow evenly between the two circuits rather than having the exhaust gas pile up in the outside of the preceding bend and bias the majority of flow into one of the two secondary circuits. Makes a major difference in the sound as well as the performance.
Dimman, I completely understand re: the dyno graph data. My goal usually is to post dynos that any customer can digest and understand, but like I said originally I have no problem sharing any and all data that we have. I probably was more irked than I should have been. I'd rather share as much data as possible rather than have a single person have questions.
Jason Griffith
Engineering Director
Nameless Performance, Inc.
Jason@Nameless is offline   Reply With Quote
Old 06-18-2012, 07:42 PM   #73
Jason@Nameless
Originally Posted by Tainen View Post
yeah not a bad idea. They love to do custom setups with lots of options... so maybe stepped stages that get more aggressive/less DD friendly.
Our configurability is our secret weapon against overseas produced high inventory designs. It's impossible to do if you have to buy 50-100 units at a time from Taiwan/China/Korea. I think our 2011-2012 WRX/STi TurboBack exhaust has over 5184 possible configurations. And that's not counting recirculated vs. non recirculated external wastegate options.
Jason
Old 06-18-2012, 08:19 PM   #74
UncleFester
The race pipe looks good. I'm curious how loud the car will be. Looking forward to the video and dyno results.
UncleFester is offline   Reply With Quote
Old 06-20-2012, 02:40 PM   #75
Jason@Nameless
Back to back dynos between the race pipe and the street axleback resulted in the same power up top and about 1ft lb loss at the bottom end but at that level I'd chalk it up to simple variation in pulls. I do have a video of this exhaust and need to post it asap. It's surprisingly quiet. If you want an example, just pull your factory axleback off and take a spin around the block on an open midpipe. Granted, putting the exhaust out the back reduces drone a bit in the cabin though.
J
Old 06-20-2012, 02:42 PM   #76
Jason@Nameless
I did the math on this, and including the EWG recirculation options we have
20412 available configurations of our 2011-2012 WRX/STi Sedan TurboBack Exhaust.
Old 06-21-2012, 03:38 PM   #77
Jason@Nameless
Scott
We tested a single 2.5" straight pipe vs. that 'tortured' exhaust and the dual exhaust w/ twin 1.75" pipes made ~1hp/ft lb more than the straight pipe at peak rpm, but at that level we're talking standard deviation. Either way, the dual exhaust makes great power and there's not more to be had by changing the flow path.
Jason
Old 06-21-2012, 06:04 PM   #78
milenko11
Drives: no
How safe is it to run the over pipe and axle back setup without a proper tune? I know ecu's can typically learn but I'm just hesitant on new platform. Ideally I'd like to have a tuning solution in place before mods but the sound of the nameless exhaust is very tempting.
milenko11 is offline   Reply With Quote
Old 06-21-2012, 06:22 PM   #79
Tainen
Drives: First SWP BRZ-L
we ran it on the dyno, it maintained fairly safe AFRs. I drove the car in that form for a few weeks as well, felt solid, no CELs, no knocking. The 2nd cat is AFTER the last o2 sensor, so really, it doesn't change what the first and 2nd o2 sensor are seeing. I think it's safe, and I've bet my 30k car on it.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 06-22-2012, 12:47 AM   #80
Agnostik
Drives: 2013 Whiteout FR-S
Do you guys test decibels on your designs and configurations? Would be good to get a general idea on the sound level to expect from something like this.
I am curious because, where I live, they are beginning to impose enforced decibel limits. Would be good to get something that sounds good and enriches that nice boxer growl but won't put me out of those specified limits.
Agnostik is offline   Reply With Quote
T1R exhaust for the FRS/BRZ ! AJ PwR Engine, Exhaust, Transmission 57 06-22-2013 10:39 PM
What kinds of gains do you expect with E / I and tune? Partial Stall Engine, Exhaust, Transmission 66 05-10-2012 11:56 AM
What kind of gains without Turbo Surge101 Engine, Exhaust, Transmission 18 01-25-2012 09:23 PM
Estimated HP gains - bolt on mods and reflash? ahausheer Engine, Exhaust, Transmission 207 01-14-2012 06:14 AM
ft 86 exhaust dalli Scion FR-S / Toyota 86 GT86 General Forum 11 09-08-2010 10:16 PM
