#15 | ||
IMHO your car is not selling because your asking price is on the high end. You did a great job building it but a race car is usually not a profitable investment. FWIW, I saw your ads before I started building my Spec86 BRZ but figured that I can build one myself and will be exactly how I like it and will be a bit cheaper. Up to this point my build cost is just under $20k including the car and its registered with a rebuilt title. I personally enjoy the process of building the car and I figured that if I build one instead of buying a prepped car there will be one more BRZ/FRS to race with eventually
#16 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
Despite the watchword being "It's cheaper to buy than to build.", most new racers choose to build, and most (all?) find out that it does cost more, but that doesn't change what the new racers that come after them choose to do. |
#17 |
Drives: Sterling BRZ Ltd
I like the car and price is a fair starting point, its not an easy sell as the car isn't wildly known about like a Miata or Boxster. I'd say 90% of cars I see exchange hands are to other local racers so running it with a big honking FOR SALE sign is my suggestion.
I building cages all day long and there are certainly guys out there that see value in an already caged car, as long as it meets there regs. Often new private guys are a little surprised at the scoop of caging a car, not only the cost but the time and process. The what else I could build for the price argument is kinda silly, everyone has there own dream build. OP you mention is car is your low cost maybe "expendable" track car and I think thats exactly how you pitch it. BMW and Porsches are fun to track sure but the consumables cost really adds up.
#18 |
Drives: 13' Scion FRS Track car
2013 Scion Frs Track Car - Sold.
#19 |
#20 |
@sstfnv very cool to see the build sheet.
But I see that you 'repurposed' a couple of parts and missing a couple like wheels. I think a realistic build is $15k in parts, then add the car and labor for what it's worth. Question: you did not upgrade radiator or oil cooling ?
#21 |
We used a WRX/Forester oil cooler and is actually included in the Misc OEM parts in the build sheet. For this power level it is OK and also didn't want to run an external oil cooler in w2w racing as it might get damaged if there is body contact. Last year I ran in TTD with my other car with a forester oil cooler, the oil temp never went above 254F which is pretty safe with good oil.
#22 | |
Drives: 2014 FR-S
If someone makes me ramen noodles, using orphan baby seal tears for water, made in a gold pot, heated by the bare bosoms of virgins, and serves it to me in crystal, it's still a $0.14 meal. Sstfnv has what he wants, for less than what it would cost for him to buy what you built, that maybe isn't completely what he wants. This is the value proposition you are up against. A turnkey-sized-cost salvage car that needs modification$ to do any organized, sanctioned w2w racing, so it's not even actually turn-key. That's what you have. It's nice and shiny, but it's still not a full build for anything other than track days, which buyers see as thousands more that you're costing them.
-Mike
#24 CS/CSR |
#23 |
Drives: 2013 Firestorm FR-S
I'd pay extra for all of that, but I want to be there for the entire process. From baby seal tear harvesting to bosom selection auditions.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#24 | |
His build sheet match closely what I did on my car: +- $15k on parts, then $8-10k on car + labor. So overall a spec 86 should put someone in the $25k to build. I think his build sheet is very interesting for potential Spec86 drivers. FYI here is my build sheet (2 seats, 2 set of rims): cost Description 7000 2013 Scion FRS 13k miles - rebuild title crashed 2130 invoice1-repair 1630 invoice2-repair 400 Rims 7x9 rims xxr527 1100 Tires BFG R1 245-40x17 405 Carbotech XP12 brake pads front / rear 100 motul brake race fluid 500 mishimoto oil cooler 350 mishimoto radiator 600 APR brake ducts with carbon fiber bump inserts. 3000 full cage with daytona bars. 1500 interior repainted same as outside color. 600 one momo daytona seat with side mount and fixed mounting plate 500 6 point harness Enduro Scrotch 600 one momo daytona seat with side mount and fixed mounting plate 500 6 point harness Enduro Scrotch 1200 Rims Enkei RPF1 17x8 +45 700 Tires adv08r - rain 500 hub adpator + quick release steering + momo rev 07 23315 Total for a runnning car 2459 RCE Tarmac2 2099 AP Racing Endurance from essex 800 Ground control camber plates with truss 300 raceseng rear cambe plate 495 open flash tablet 200 Carbotech XP12 front pads 200 subaru nuts and bolts + under carriage aero 155 oil pressure and temp gauge - innovate mtx dual gauge 155 0W20 oil 120 perrin inlet hose 100 braided brake line kit frotn and back with essex kit 100 motul 300 transmission 100 cage foam pads 100 spot trace gps 100 tow hook front and back 95 perrin brake master cylinder brace 60 gauge pod 55 whiteline differntial mount bushing insert KDT925 50 motul 300ls differential 50 horn upgrade 50 alcon caliper temperature sticker 40 perrin rear shifter bushin 40 whiteline crossmember bushing insert KDT922 30 Mtec clutch line 30 whiteline gearbox bushing KDT926 25 CL 6E pads (discoutned while buying bbk) 20 HKS oil filter 20 toyota obd2 cable 8048 Total improvements 31363 Total car as it sits
#25 |
Drives: 2015 BRZ
I don't see a mention of a logbook in this thread anywhere. If you're going to sell it as a racecar, a logbook will be worth it's weight in gold. Take it to a NASA weekend and get a logbook issued as a PT car. You don't even have to run anything, but that answers a LOT of questions for buyers about whether it's race-able.
Jake |
#26 |
FWIW, if I wanted to build a solid track-day car, or a racing twin, and I chose your car to start the process, the absolute most I would offer would be $15K. That assumes that a careful inspection by a race shop has determined the condition of all the significant parts, and that they've been found to be in new & unused condition. My experience is that after the inspection the offer would be in the range of $12-13.5K, and the offer would depend totally upon what the inspection revealed.
Note that since it would be my car, a number of parts would come off to be sold for 40-60% or less than what you paid for them. See here:
#27 |
I have the SCCA logbook, I assume i should go get the NASA book as well, I think I am missing the ignition cutoff switch, that may be worth installing...but I was waiting for @GSpeed to start selling theirs
#28 | |
Drives: 2014 FR-S
See also: Veyron, LF-A. Awesome cars that sell for well below their cost of manufacture.
-Mike
#24 CS/CSR |
| TopSpeed.com - Scion FRS race car build | philooo | Member's Car Journals | 67 | 12-11-2016 03:20 AM |
| DatApex | GrippyType Race Build | DatApex | Member's Car Journals | 26 | 11-03-2015 09:51 PM |
| Looking to sell my track build car | glamcem | Tracking / Autocross / HPDE / Drifting | 0 | 03-01-2015 01:37 PM |
| Car 986 Scion FR-S NASA PTD Race Car Build | phastafrican | Member's Car Journals | 70 | 01-03-2015 09:32 PM |
| Good place to sell a FR-S? | icarus | Northern California | 7 | 07-16-2014 08:21 PM |
