Old 05-10-2016, 10:14 PM   #239
Ro_Ja
Drives: TOYOTA
Originally Posted by SG02WRX View Post
Any one have any suggestion for front camber plates, besides Raceseng. Although the Raceseng plates are nice. They're quiet pricey.
Thanks in advance
If you want a non-raising camber plate, Velox will be your only other choice. HVT used to be an option, but AFAIK they are no longer in business, although you might be able to pick up a used set.
Ro_Ja is offline
The Following User Says Thank You to Ro_Ja For This Useful Post:
SG02WRX (05-11-2016)
Old 05-10-2016, 11:49 PM   #240
churchx
churchx's Avatar
Drives: 2014 GT86
Velox's, RCE's?
churchx is offline
Old 05-11-2016, 12:38 AM   #241
SG02WRX
SG02WRX's Avatar
Drives: SWP WRX HATCHBACK
Originally Posted by churchx View Post
Velox's, RCE's?
RCE? released a set ?
SG02WRX is offline
Old 05-11-2016, 02:57 AM   #242
churchx
churchx's Avatar
Drives: 2014 GT86
Two of them. #1 & #2. Though if you mentioned price, i guess that leaves just Velox's or if your coilovers comes with own.
churchx is offline
Old 05-11-2016, 04:04 AM   #243
10Tim
Here for the fun
10Tim's Avatar
Drives: 10 Series FR-S #2478
Thanks in advance
I'm using the Hotchkis camber plates. Quality parts. They are working well.
I have the B16 coilovers, but if I'm not mistaken, they should work fine with the B14's as well
There's just Not Enough Hours in The Day
On Flickr http://www.flickr.com/photos/24663968@N00/
On Instagram XLTimbo
10Tim is offline
The Following 2 Users Say Thank You to 10Tim For This Useful Post:
Nitro22 (05-12-2016), SG02WRX (05-11-2016)
Old 05-19-2016, 01:25 PM   #244
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Just wanted to follow up the popping noise I was hearing. Turns out it happens when the front springs get caught on the locking collars, since the end of the spring is sharp on the inside. There are clear wear marks and when I spin the spring and hold the collar by hand when everything is apart, I an see grooves being made in the collar. Considering no one else I can find has had this issue, I must be the only one who has had the plastic casing of the spring wear off in the corner. While they haven't offered to replace anything, bilstein customer service has been excellent, and the suspension rides better than a friend's kW v3s. For a daily, these are excellent.
xxBrun0xx is offline
The Following 2 Users Say Thank You to xxBrun0xx For This Useful Post:
7c8 (05-19-2016), kevaughan (04-16-2024)
Old 03-09-2019, 12:49 PM   #245
Pinoy_FRS
Drives: Ultramarine
Hey guys sorry to bring back a dead thread but after doing my research I think I’m going to go with a set of b14’s. I just have a few questions before I buy them. In regards to alignment I bought a set of LCA’s for the rear and a set of camber bolts for the front. Is there anything else I need to support this suspension set? This is my daily driver and I plan to do my first track day in June. Also the set of wheels I’m picking up next week are 18x8.5 et 42. I don’t think I should have any figment issues but just confirming. Thanks guys!
Pinoy_FRS is offline
Old 03-09-2019, 02:16 PM   #246
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Sounds like you got everything you need and shouldn't have any issues.
Get the most front camber you can, -2.5 ideally (or more, I'd shoot for -3 at least but it depends on the driving you do) but with one set of camber bolts you may not get more than -2 to -2.2.
ineedyourdiddly
strat61caster is offline
Pat (03-10-2019)
Bilstein Damptronic pics. DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 202 10-08-2014 08:13 PM
Anyone ETA on Bilstein coilovers? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 01-31-2014 11:26 AM
Bilstein Damptronic on an FRS DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-10-2013 12:15 AM
All Bilstein and Muteki 10% off during month of July! Infamous Performance Brakes, Suspension, Chassis 24 07-31-2013 01:52 PM
Bilstein Shocks wahsaihin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-23-2013 03:12 PM
