Old 05-10-2016, 01:34 PM   #29
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by crewchief View Post
car is auto ..seen early threads of the same problem on the 86 no one seems to have an answer...its not mould... its a burning smell like tar for about 3 seconds then goes ....doesn't happen all the time but...driver reports... makes the driver light headed...gives a headache....seems to me like leaking engine coolant ...thought there would be a fix seems common problem with 86...
Tar-like burning smell is not coolant.
Coolant smells "sweet"
-alex
Old 05-10-2016, 04:09 PM   #30
Imrac
Drives: 13 SWP BRZ Prem
If it's a 2016, my guess is you don't have a lot of distance on the car. I still had random "burning" smells for 10,000 miles. The car has a lot of materials and left over machining lubricants that will burn off.
I would ignore it unless you see smoke or smell it constantly.
It could also be a brake slide sticking and dragging a pad for a little bit.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 05-10-2016, 09:15 PM   #31
Well, @crewchief, as suggested did you change the cabin air filter ... ??
It might have picked up something and is hanging on to it ...... to be released from time to time.
Surely, changing the cabin air filter doesn't jeopardize your warranty .... even in Australia .....
Old 05-11-2016, 06:55 PM   #32
sato
sato's Avatar
Drives: Dodge Patitas
Originally Posted by FingerDiddle View Post
only ever turn on recirculation if there's a bad smell outside.
So that means anytime I floor it, due to rotten egg and gas fume smell?
sato is offline   Reply With Quote
Old 05-12-2016, 09:14 AM   #33
crewchief
Drives: gt86
nothing wrong with filter no smell..... new
crewchief is offline   Reply With Quote
The Following User Says Thank You to crewchief For This Useful Post:
humfrz (05-12-2016)
Old 05-14-2016, 03:22 AM   #34
FX86
i also had that burning smell...resembled cigarette smoke to me but it went away after 15,000+ miles
Old 06-22-2016, 11:56 PM   #35
Ryan_86
Ryan_86's Avatar
Drives: 2016 Scion FRS - Steel
I swear I have this same problem, its a quick strong burning smell that lasts like 3-5 seconds, only seems to pop up when driving the car harder than normal and only when the re-circ is on. 2016 AT frs.
Ryan_86 is offline   Reply With Quote
Old 10-21-2017, 01:30 AM   #36
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
I have the same problem with a smell coming through my vents, whether the AC is on or not, or on recirculation mode, when I drive hard and long periods of time, and usually get 2 seconds of a smell through the vents when changing gears. I'm not doing anything I shouldn't be doing with the clutch or car. Brand new Arm & Hammer cabin air filter was installed, and I used lysol sprayed through the vents below the windshield that the blowers pull air from.
Sometimes I drive with the windows down and still get the a stale smell of some unknown heated material (not so much burning, just smells like someone tried to cook some dirt). I'm coming up on 18K miles and this smell lingers on my clothes and my hands and is starting to annoy the firetruck out of me. So tired of this smell.
I was hoping this was an easy fix, but it looks like I'm going to have to ask the dealership. They're probably going to charge me to inspect for this crap. I do want to check for that leak thing now that I'm seeing some threads about that happening. I have a manual 2017 model, so one would think that sort of thing was fixed. Maybe I try the lysol thing one more time, I really don't want to have to take it into the shop for something so silly.
Lakitu is offline   Reply With Quote
Old 10-21-2017, 12:49 PM   #37
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
I used to have this too, but didn't pay much attention to it - I was worried about something else, my synchros on 3rd to 4th gear. I had my transmission replaced under warranty and since then I have never had the smell come back.
carsebuco is offline   Reply With Quote
Burning smell Riftur Engine, Exhaust, Transmission 9 04-13-2016 02:50 AM
Burning smell PLease help! Chase1996 Issues | Warranty | Recalls / TSB 62 11-02-2015 02:11 PM
Anyone smell burning outside the car? DarrenDriven Scion FR-S / Toyota 86 GT86 General Forum 115 01-13-2015 02:31 AM
burning smell when in reverse fito68 Southern California 8 12-30-2014 07:21 PM
Burning smell Boofneenee Issues | Warranty | Recalls / TSB 6 09-30-2013 07:28 PM
