Old 05-04-2016, 10:12 AM   #7141
brianhj
Drives: 2017 Camaro 1SS
Originally Posted by Rifle View Post
Make sure you upgrade the hoses to higher vacuum lines. Stock Radium lines hold 30psi vacuum and collapse under load of the 210. I replaced with 250psi 8AN race hose. Like $16 for 10 feet.
Link?
Sent from my LG-D851 using Tapatalk
brianhj is offline   Reply With Quote
Old 05-04-2016, 12:11 PM   #7142
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Originally Posted by brianhj View Post
Link?
Price has changed a bit. About $26 now.
http://summitracing.com/parts/sum-220786-b
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
The Following 2 Users Say Thank You to Rifle For This Useful Post:
brianhj (05-04-2016), stockysnail (05-04-2016)
Old 05-04-2016, 04:29 PM   #7143
brianhj
Do you know if that's the same size hose that fits on the supercharger elbow connections?
Old 05-04-2016, 04:37 PM   #7144
Rifle
Rifle's Avatar
I believe that's 6AN. I haven't had any issues with that collapsing though. I just know the catch can hoses aren't strong enough for the vacuum.
295WHP/220TQ
Old 05-05-2016, 01:48 AM   #7145
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
You could always just vent to atmosphere. Won't need to worry about things like vacuum. And valve fouling.
Unless you're in cali.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 05-05-2016, 02:11 AM   #7146
Rifle
Rifle's Avatar
My radium Catch can connects to engine PCV system. If you let it collapse, it over works the motor (in our case, the supercharger) if it leaks, it stalls the engine. So lol
295WHP/220TQ
Old 05-05-2016, 02:15 AM   #7147
riboyster
riboyster's Avatar
How does all vacuum overwork the SC? I've had my pcv nozzle on the SC capped off since install and venting to atmosphere through a home made catch can on the engine side.
I'm not arguing, just trying to understand what you mean.
Old 05-06-2016, 12:58 AM   #7148
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Arrow
So apparently these Superchargers are shipped pre-filled with oil. Brought her to life tonight with the tune and went to add oil before initial startup and saw that it was full. Is this typical?
Chad86 is offline   Reply With Quote
Old 05-06-2016, 01:37 AM   #7149
riboyster
riboyster's Avatar
I don't think they're ever supposed to be FULL. However if that's how it was shipped then you should be okay warranty wise
The Following User Says Thank You to riboyster For This Useful Post:
Chad86 (05-06-2016)
Old 05-06-2016, 08:50 AM   #7150
brianhj
Yes it's normal
The Following User Says Thank You to brianhj For This Useful Post:
Chad86 (05-06-2016)
Old 05-06-2016, 10:07 AM   #7151
brianhj
I don't think he meant it was filled to the brim, he just meant it already had oil in it and he wasn't expecting it to.
The Following 2 Users Say Thank You to brianhj For This Useful Post:
Chad86 (05-06-2016), riboyster (05-06-2016)
Old 05-09-2016, 07:06 PM   #7152
walletsr
Drives: 2014
Not sure why images arent loading here is the link https://goo.gl/photos/pKPiDEiNCDGc4pVm7
walletsr is offline   Reply With Quote
Old 05-09-2016, 11:12 PM   #7153
brianhj
Oh shit what happened?
Old 05-10-2016, 12:49 AM   #7154
Rifle
Rifle's Avatar
If I'm looking at this correctly... hole in the block. Cat in the overpipe.. which leads me to believe you had a catted header. Pushing more PSI than stock pulley? Bad idea to begin with. That back pressure would have been unreal... if not, then just pushing too much to begin with.
295WHP/220TQ
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
