Old 05-09-2016, 12:57 PM   #43
gtslow
Drives: 2015 Halo FR-S
My prediction is that when we see the 17's on the dyno we see 5-10 peak horsepower, a massive reduction in torque dip and torque all throughout the power band. The car will feel like one with a header and a tune, and the media will sing its praises. Forum warriors will still cry that it doesn't have a factory turbo and it still rattles like a 25k Subaru.
gtslow is offline   Reply With Quote
Old 05-09-2016, 01:09 PM   #44
gtslow
Originally Posted by brandonblt2 View Post
Yes you need a tune. I won't necessarily void your warranty unless the dealership can prove that it caused the issue,
Good luck with that. It is one thing to slap on a catback or a drop-in filter, but if you put a non-factory tune in the car and you blow an engine you should full expect to kiss your warranty goodbye. Maybe you get lucky and you flash back to stock and they don't check your flash count, but I wouldn't count on that. Maybe your dealer is mod friendly and wants the check from Subaru/Scion so they don't investigate further, but again you would be lucky. At the end of the day you have to pay to play.
Old 05-09-2016, 01:25 PM   #45
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by Cole View Post
I didn't even know about the UEL removing the torque dip. Do I need a tune? Will my warranty be void if I install one? Will my car be too loud? What's the best brand to buy?
Obviously I meant from the factory, and not aftermarket options.
I have a Tomei but no tune yet as the car is under warranty.
Old 05-09-2016, 01:39 PM   #46
Cole
Not a troll
Cole's Avatar
woooosh
Cole is offline   Reply With Quote
Old 05-09-2016, 01:54 PM   #47
JD001
JD001's Avatar
Drives: Subaru BRZ
woooosh
Tomei, Milltek OP and Berk fast cat. The rest is standard and it only gets loud when pushing on.
Old 05-09-2016, 02:01 PM   #48
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
True I was referring to just the header itself but with the tune you are correct. Dealers will probably check the flash count on the ecu.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 05-09-2016, 02:04 PM   #49
brandonblt2
woooosh
To be fair the only people who knew you were being sarcastic, are those who know you. It is the internet after all.
The Following User Says Thank You to brandonblt2 For This Useful Post:
Tcoat (05-09-2016)
Old 05-09-2016, 03:33 PM   #50
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
My prediction
Optimistic post of the day.
ineedyourdiddly
The Following 4 Users Say Thank You to strat61caster For This Useful Post:
gtslow (05-09-2016), Hoahao (05-10-2016), JD001 (05-09-2016), Tcoat (05-09-2016)
Old 05-09-2016, 03:50 PM   #51
JD001
JD001's Avatar
Drives: Subaru BRZ
It whooshed over my head!
Old 05-09-2016, 03:51 PM   #52
You do not want Cole wooshing on your head!
JD001 (05-09-2016)
Old 05-10-2016, 01:32 AM   #53
fitcious
More Horsepower!
Actually- with 50 hp more it will be like a s2k. S2k has around same torque with 240hp. It drives very similarly normally but pulls hard when revved.
fitcious is offline   Reply With Quote
Old 05-10-2016, 02:28 AM   #54
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
It has been said time and time again these cars do not have a "flash counter" in fact many cars have been flashed back to stock and had warranty repairs with much success and I have yet to see a case where the dealership has figured out there was a tune on the car, it would take some serious ecu dismantling to even begin to notice it's been tampered with, which will never happen as it would take extreme disassembly of an ECUs code. Quite frankly after flashing back to stock with an OFT its a simple ROM so it leaves 0 footprint. As for ecutek after flashing back to stock the ecu becomes unlocked again and also leaves 0 footprint. I've used tech-stream before and it can't even tell the difference between an OFT rom and stock, nor is there any flash counter to be found. If you did research you would know this.
Old 05-10-2016, 02:29 AM   #55
FRSBRZGT86FAN
Yes you need a tune. I won't necessarily void your warranty unless the dealership can prove that it caused the issue, if you go catless it is illegal since you are tampering with a emissions device. Your car will be louder and depending on whether its catted or cattless will determine the overall loudness. Cattless will be louder vs catted but both will increase sound but it shouldn't be crazy loud. Most consider JDL, Tomei, Grupple-S, and HKS to be quality headers. The factory only sells the stock header you already have.
@Cole is being sarcastic I believe, but it leaves a good point a lot of people are completely clueless on the forum even though there are multiple stickies of the correct course of action if you go that route
Old 05-10-2016, 02:59 AM   #56
Now @Cole, you see what you did ...... you started a woooshing war ......
Cole (05-10-2016)
Horsepower Chase1996 Engine, Exhaust, Transmission 32 03-08-2016 11:26 PM
Who says we need more horsepower? LeeMaster Scion FR-S / Toyota 86 GT86 General Forum 36 01-11-2013 12:05 PM
Bolt on 6 horsepower for about $50. MillersOilsUS Engine, Exhaust, Bolt-Ons 29 01-10-2013 09:53 PM
6 horsepower, 4 lb-ft from an oil change MillersOilsUS Mechanical Maintenance and Tools 1 01-03-2013 12:21 PM
ft86.com has some serious horsepower! MrBRZ Off-Topic Lounge [WARNING: NO POLITICS] 2 03-22-2012 08:45 PM
