Old 05-09-2016, 02:51 AM   #29
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
What OP described sounds normal for our cars at this point. I'd change your transmission fluid to something better though, all my shifting qualms basically went away immediately when I switched to motul at 22,000 miles. Now I'm at about 55,000 and about to change it again.
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
Old 05-09-2016, 11:55 AM   #30
TimmyC
TimmyC's Avatar
Drives: 2013 FRS
Originally Posted by RJasonKlein View Post
If you wrote that with a straight face, I'm pretty sure he meant that he changed the fluid after only 2,000 miles because he had read about particulate in the transmission oil on the magnetic drain plug.
Sorry, how often should you change the transmission fluid?
TimmyC is offline   Reply With Quote
Old 05-09-2016, 12:25 PM   #31
Keenercarguy
Mountain Runner
Subaru suggests 30,000 miles I believe, Toyota says something weird like 22,500 or something (I'm not sure if Scion is also weird that way): but it should be in your owners manual.
Old 05-09-2016, 06:57 PM   #32
zberz
Drives: 2015 Lightning Red BRZ
Yeah, this.
EDIT: I lied, it wasn't youtube, it was this: http://blog.modbargains.com/how-to-f...r-in-fr-s-brz/. Mine looked even worse.
zberz is offline   Reply With Quote
Auto gear slippage on 2nd n 3rd gear shantha Scion FR-S / Toyota 86 GT86 General Forum 2 11-19-2015 07:26 PM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 12:08 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
