Old 05-07-2016, 12:45 PM   #1
dallenj
Drives: Grey FR-S
Precision 6262 Turbo
I am getting a precision 6262 turbo for a turbo kit I am getting built for me. some of the options I can get is a ported s cover. it doesn't cost any extra. I just want to know the advantages and disadvantages of a ported turbo inlet.
dallenj is offline   Reply With Quote
Old 05-07-2016, 05:15 PM   #2
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
The turbo is good for 700hp so depending your hp goal I don't think it'll matter much.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 05-07-2016, 07:01 PM   #3
mrk1
Drives: Sterling BRZ Ltd
Ported covers will move the surge line of the compressor map farther left, do you need that on your setup? if so then your good to go. Other wise the S Covers are large and bulky. I would assume the non ported option is the E Cover which is smaller, little easier to work around in the engine bay.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
Coheed (05-14-2016)
Old 05-07-2016, 07:09 PM   #4
FRS Justin
Drives: 2013 Asphalt FRS
It will make power between 4200 and 7000rpm depending on your hot side and kit. It will come on like a freight train from 5500 to 7000rpm. Depending on what your power goals are and type of use the car will be used for their could be better choices....
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 05-08-2016, 02:13 PM   #5
dallenj
Drives: Grey FR-S
It is either the ported s cover or a non ported s cover.
Old 05-08-2016, 02:14 PM   #6
dallenj
Drives: Grey FR-S
The car will be a drag car. I want as much power as possible
Old 05-08-2016, 02:19 PM   #7
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
My 5558 is capable of over 500hp, will spool faster than a 6262, broader powerband, and does it all with the 3" compressor housing / 2" outlet.
You don't need "as much power as possible" to make a quick 1/4th 86. You can't just throw parts at it and hope it works. Take 10 steps back and set yourself some power goals before you start blowing money on parts that are just going to hurt your 1/4th times.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZoomTX For This Useful Post:
FRS Justin (05-08-2016), nickw14 (05-11-2016)
Old 05-08-2016, 02:22 PM   #8
dallenj
Drives: Grey FR-S
The hot side will be a T3. 83 A/R with 3" V-Band discharge
Old 05-08-2016, 02:28 PM   #9
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Why such a big housing on a T3 manifold? You're asking for more lag for no reason.
Precision turbos don't even really get going until 20+ psi. You'll spool it slower, make less boost at a specific RPM level, and overall make less power throughout the powerband where it counts early in the run.
Here is a hint. In the 1/4, the race is over before you even hit the 1/8th mark. You need to focus on good 60ft times and keeping your car in the powerband as much as possible before the 1/8th. Going too big of a turbo with too big of an A/R housing size is going to kill your times, even if you may make more peak power than the 86 next to you. Take some time and review the dyno thread, see where these cars actually make power on 55-67mm turbos, and go from there. You're not going to run good times making all your power past 6k RPM.
The Following User Says Thank You to BRZoomTX For This Useful Post:
Old 05-08-2016, 02:30 PM   #10
dallenj
Drives: Grey FR-S
I was also looking at a 5931e but a friend of mine who has a turbo brz recommend the 6262 for my build.
Old 05-08-2016, 02:33 PM   #11
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
I updated my post a bit, but yeah. You really do not need a turbo that big. Get your car running with a smaller, more applicable turbo for what you're looking for (good 1/4 times).
From there you'll find most of your time improvement will be in the suspension and fighting for traction w/ a driver mod, and not so much needing to upgrade the turbo / run more power.
Kris86 (05-11-2016)
Old 05-08-2016, 02:36 PM   #12
dallenj
Drives: Grey FR-S
My goal is inbetween about 450 to 500hp. That should get in the 10 with a proper suspension set up. I thought the 5931 was a good choice, but I was listening to someone with experience with a turbo 86 that said the 6262 was the way to go.
Old 05-08-2016, 02:38 PM   #13
dallenj
Drives: Grey FR-S
Just so you know my anti lag system is a shot of nitrous to boost my 60' times as soon as my turbo is spooled the nitrous will shut off
Old 05-08-2016, 03:11 PM   #14
FRS Justin
Don't listen to your friend, hes got you way off course. If 10s is all you want run a 5858 And you don't need nitrous...Good God I hope you have deep pockets if you try all his Nitrous and 6262
710whp
The Following User Says Thank You to FRS Justin For This Useful Post:
BRZoomTX (05-08-2016)
Perrin Crank Pulley, Precision Turbo PW39 Wastegate - SOLD Amir Ghadiri Engine, Exhaust, Bolt-Ons 7 02-07-2016 08:59 PM
SOLD Precision Turbo tumbla.jr Engine, Exhaust, Bolt-Ons 2 05-21-2015 10:15 PM
Invida n1 exhaust motiv overpipe injen intake precision 4854 turbo for sale Anthony7515 Engine, Exhaust, Bolt-Ons 7 09-16-2014 10:28 PM
9 SEC -PRECISION 6466 SUB-ZERO MOTORS FT86 CUSTOM TURBO KIT , ENGINE BUILT 600WHP+ SUB-ZERO Forced Induction 44 07-09-2014 09:44 PM
