Old 05-07-2016, 10:39 PM   #1
crewchief
Drives: gt86
86 air con burning smell
would any body have any idea about the intermittent burning smell coming from the ac unit while on recirculate, only seems to happen when engine is hot
the car is 2016 86gt does any body know the fix ,or why it happens?do not want to take the car to the dealer as they just fob you off with a bs excuse.....
crewchief is offline   Reply With Quote
Old 05-08-2016, 12:08 AM   #2
WELCOME to ye ol forum ...... @crewchief ........
hmmmm........what kind of burning smell .. ??
burning oil?
burning electrical wiring?
burning leaves?
burning plastic?
burning tobacco?
evaporating antifreeze?
other?
Do you have a video ...... (just kidding)......
Old 05-08-2016, 01:08 AM   #3
Impureclient
Drives: 2015 FR-S
Forgot burning rubber, humfrz.
Old 05-08-2016, 02:28 AM   #4
Can an FR-S ....... burn rubber ......??
MTpockets (05-09-2016)
Old 05-08-2016, 02:34 AM   #5
Yep. Snow tires and 70+ degrees lead to several inadvertent rubber burning incidents for me.
Old 05-08-2016, 04:16 AM   #6
OK, @Impureclient we will add burning rubber to the smell list ......
Old 05-08-2016, 06:27 AM   #7
FingerDiddle
Drives: Camry 08
If it's on recirculation, it could be shoddy plastic burning from the concentrated heat, could also be mildew burning due to the aircon being used on recirculation too often, only ever turn on recirculation if there's a bad smell outside.
FingerDiddle is offline   Reply With Quote
Old 05-08-2016, 06:45 AM   #8
crewchief
Drives: gt86
smells like burning tar but only for few seconds.. its not from under the bonnet.
no oil leaks cars done 3000 klms thought it might be a leak of engine coolant slow drip somewhere..only have the aircon on cold as i live in Australia
Old 05-08-2016, 07:01 AM   #9
FingerDiddle
Drives: Camry 08
I'd say fluid leak, though don't rule out mildew buildup.
Your best bet is to be assertive towards the dealership to fix it, otherwise sell it to me as a write off.
What colour is it?
Old 05-08-2016, 10:28 AM   #10
extrashaky
Drives: 2014 BRZ Limited
Manual or automatic?
Do you know what a burning clutch smells like?
The Following User Says Thank You to extrashaky For This Useful Post:
Tcoat (05-08-2016)
Old 05-08-2016, 12:18 PM   #11
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
If it were my car...
I'd first remove the cabin air filter, see if there's anything caught within the filter. Try running the hvac with that filter removed.
Next I'd remove the blower motor, check for foreign material lodged within it's squirrel cage. Also check housing above blower motor for same with motor out.
ToySub1946 is offline   Reply With Quote
Old 05-08-2016, 04:06 PM   #12
FingerDiddle
Drives: Camry 08
I'd do nothing, it's a 2016 model meaning he has it under warranty still.
Don't void your warranty.
Old 05-08-2016, 06:04 PM   #13
extrashaky
How exactly do you think he's going to void his warranty?
Old 05-08-2016, 06:24 PM   #14
driftguy
driftguy's Avatar
Drives: In between cars... 2018 Ninja 1000
Is it a manual transmission? Check the cam plate, backside of the engine on the passenger side. They're known for leaking oil directly onto the exhaust and the burning oil smells exactly like burning tar.
http://www.ft86club.com/forums/showthread.php?t=53949
driftguy is offline   Reply With Quote
Burning smell Riftur Engine, Exhaust, Transmission 9 04-13-2016 01:50 AM
Burning smell PLease help! Chase1996 Issues | Warranty | Recalls / TSB 62 11-02-2015 01:11 PM
Anyone smell burning outside the car? DarrenDriven Scion FR-S / Toyota 86 GT86 General Forum 115 01-13-2015 01:31 AM
burning smell when in reverse fito68 Southern California 8 12-30-2014 06:21 PM
Burning smell Boofneenee Issues | Warranty | Recalls / TSB 6 09-30-2013 06:28 PM
