Old 05-07-2016, 09:42 AM   #1
babydriver
Hit the road and I'm gone
babydriver's Avatar
Formula needed for estimating horsepower from RPM, gear ratio and accel time
Recently, I decided to purchase a custom tune for my FR-S using the OFT device. As part of the process, I made a datalog of a 2000-7500 rpm pull in third gear. This turned out pretty good for starters, with a quite linear gain in RPM through that range. There also is a time index graduated in tenths of a second. I thought about developing a formula to estimate the average WHP based on the more or less linear relationship between the RPM "curve" and the time index.
I can think of the following factors:
Engine RPM change vs. elapsed time index (obviously)
Overall gear ratio (transmission plus rear end)
Weight of vehicle
Tire diameter
If I can derive the rate of acceleration, then use the weight of the car, the number of turns made by the rear wheels at any given RPM, vs. the time needed to accomplish this, then average torque and horsepower ought to be able to be derived.
Before I go to the trouble of developing a formula, however, I wondered if there is such a pre-existing formula available. Has anyone worked this out already?
Thanks!
Slip, slidin' away.
Old 05-07-2016, 10:54 AM   #2
FRS Justin
Drives: 2013 Asphalt FRS
It doesn't quite work that way, as suspension efficiency will play a factor. I have all sorts of formulas that work off ET weight mph which will give you a VERY close hp estimate but torque is a whole other animal. I never found away to figure that as gear changes affect the formula. Here is a link to some very good calculators
http://www.wallaceracing.com/Calculators.htm
Look at this one.
http://www.wallaceracing.com/horsepower2.htm
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 05-07-2016, 11:08 AM   #3
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Just calculate the change in kinetic energy over time.
change_in_energy = 0.5*M*V2^2 - 0.5*M*V1^2. (where M is the mass of the vehicle in kg, and V is velocity in m/s with V1 being the starting velocity and V2 being final Velocity)
This will give you an answer in units of energy or Joules.
The amount of time it took to increase this kinetic energy is in seconds.
So the energy used is Joules per second or J/s (1 Joule per second is the definition of a Watt)
This is now a measure of Power (units of energy per second).
From there you can convert from J/s to hp with.
Horespower = E(J/s) * 0.001341
(Or 1 hp = 745 J/s)
You don't need the engine RPM, or the wheel speed, etc.
justatroll is offline   Reply With Quote
Old 05-07-2016, 03:29 PM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
Virtual Dyno?
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-07-2016, 04:21 PM   #5
babydriver
babydriver's Avatar
Originally Posted by Kodename47 View Post
Virtual Dyno?
Something like that.
If I calculate the result only in third gear, then there is no gear change to deal with. One less variable.
Slip, slidin' away.
Old 05-07-2016, 04:34 PM   #6
+1 to @justatroll. Don't forget to consider drag, or use second gear to minimize its contribution.
Old 05-07-2016, 05:08 PM   #7
cjd
cjd's Avatar
Drives: 2017 BRZ
Why would his clothes make a difference? Wait, wrong thread?
More seriously - sample rate will play a role here since the lower the sample rate, the longer you need to get good data. 3rd is probably the highest gear most people can wind out on public roads without too much risk...
Old 05-07-2016, 05:30 PM   #8
mrk1
Drives: Sterling BRZ Ltd
Virtual Dyno does what your looking for, however like anything including a real dyno its very easy to manipulate setting to skew the results.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 05-07-2016, 06:06 PM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
No, I meant Virtual Dyno: http://download.cnet.com/Virtual-Dyn...-75870487.html
.: Stealth 86 :.
Kodename 47 DJ:
Change gear ratio? Afdad120108 Engine, Exhaust, Transmission 61 08-17-2016 10:44 AM
FR-S Gear Ratio Comparison SpeedR Engine, Exhaust, Transmission 36 02-25-2016 09:34 AM
Gear Ratio Change Lunatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 06-26-2014 10:20 PM
Rear End/Gear/Differential Ratio fly2low Engine, Exhaust, Transmission 9 02-09-2013 11:53 AM
86,BRZ MT gear ratio Yobiwan Engine, Exhaust, Transmission 1 01-26-2012 02:40 AM
