go_a_way1
Old 05-06-2016, 10:52 PM   #3417
SlipperyBastard
Drives: 2014 6MT FR-S
Can you post a video?
I hope this works. Thanks for the help. If I know how to thank a post yet I would haha.
SlipperyBastard is offline   Reply With Quote
Old 05-06-2016, 11:58 PM   #3418
byun
byun's Avatar
Drives: 2015 BRZ CWP
Is that a shadow or is there a crack in the head of the bolt were it meets the flange?
byun is offline   Reply With Quote
Old 05-07-2016, 12:44 AM   #3419
SlipperyBastard
Just double checked and it is just a shadow.
The Following User Says Thank You to SlipperyBastard For This Useful Post:
byun (05-07-2016)
Old 05-07-2016, 01:02 AM   #3420
CSG Mike
CSG Mike's Avatar
That's the auto-tensioner working. Totally normal. It's actually the factory tensioner, and you'd see the same behavior on a stock car.
Old 05-07-2016, 02:00 AM   #3421
SlipperyBastard
The pulley I was talking about with the wobble is the idler pully after the tensioner in the direction of the belt. Sorry for the weird angle I was trying to get it to show the pully face as flat as possible.
Old 05-07-2016, 04:56 AM   #3422
CSG Mike
CSG Mike's Avatar
I see the wobble. That's not normal; replace it.
Old 05-07-2016, 03:10 PM   #3423
SlipperyBastard
Thanks a lot I will get right on that.
Old 05-09-2016, 04:28 PM   #3424
theparagon
theparagon's Avatar
Drove 1000 miles this weekend from DC to Charleston, SC and back. The supercharger performed great. Averaged over 31 mpg with mostly highway driving, for those of you interested in that sort of thing.
theparagon is offline   Reply With Quote
The Following 3 Users Say Thank You to theparagon For This Useful Post:
Hicklinc (05-11-2016), Jackson Racing (05-13-2016), SuperDave (05-16-2016)
Old 05-12-2016, 02:30 PM   #3425
asnatlas
Drives: 2013 - BRZ - SWP
Post
I'm looking at the following items:
JRSC C38 SuperCharger Kit
JR Oil Cooler Kit (JRSC version)
Radium Dual Oil Catch Can Kit
DW300c Fuel pump
ID1000cc Injectors
Anyone see anything wrong with this setup? Am I missing anything other then a EcuTek license and tune (still researching and debating).
I picked up the following items gently used:
ACT-XTSS clutch kit
EcuTek cable and dongle
Delicious Tuning Flex Fuel kit
asnatlas is offline   Reply With Quote
Old 05-12-2016, 02:33 PM   #3426
Hicklinc
Drives: N/a
DW300c Fuel pump
ID1000cc Injectors
I picked up a gently used ACT-XTSS clutch kit along with an EcuTek cable and dongle.
Pretty sure you dont need the injectors or pump
Sent from my SM-N910T using Tapatalk
Hicklinc is offline   Reply With Quote
Old 05-12-2016, 02:35 PM   #3427
asnatlas
Post
Crap, I forgot to mention that I picked up a gently used DT Flex Fuel kit to run E85 (which is why I would need the injectors and fuel pump)...
Old 05-12-2016, 02:39 PM   #3428
Hicklinc
Drives: N/a
I dont think you need injectors or a pump to run e85 unless your going high boost pulley which it is suggested to build the motor if you have the c38 but i could be wrong
Old 05-12-2016, 02:45 PM   #3429
_Se7en_
Drives: Whiteout Scion FR-S
FWIW...
I was recommended DW700CC injectors and DW300C pump with C30 and FF kit.
I will be running full exhaust setup. Will be seeing about 320whp.
1000cc seems like overkill but I guess depends on your hp target....
Sent from my SM-N920T using Tapatalk
_Se7en_ is offline   Reply With Quote
The Following User Says Thank You to _Se7en_ For This Useful Post:
Hicklinc (05-12-2016)
Old 05-12-2016, 02:49 PM   #3430
asnatlas
Post
Hmm, I spoke with a few people who stated that if I was going to run E85 I would need to upgrade the fuel pump and injectors. I am not planning on going with the high boost pulley until later once I build up the engine down the road.
The Following User Says Thank You to asnatlas For This Useful Post:
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
