Old 10-20-2015, 09:09 AM   #183
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
@tracerit I decided to crack it open again yesterday - there's no way to fully clear it, always a bit touch but you can tip it the filter upward a bit to minimize contact with that hump.
1Cor10:23 is offline   Reply With Quote
Old 10-20-2015, 04:43 PM   #184
tracerit
Drives: '13 SSM BRZ Limited 6MT
I also removed the black piece above the bumper and pulled it out to peek inside. My filter is also touching the air diverter but it's not squished in there or anything. I'll just rotste the filter when it comes time to clean.
tracerit is offline   Reply With Quote
Old 11-09-2015, 01:39 PM   #185
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
Im considering buying this cold air intake from perrin. Does the bumper needs to be remove in order to clean the intake every 8-10k miles?
Jfheisenberg is offline   Reply With Quote
Old 11-09-2015, 01:49 PM   #186
1Cor10:23
1Cor10:23's Avatar
@Jfheisenberg yes, this is the best way to service. You can probably get away with pulling back the top of the bumper but you risk misalignment when reinstalling plus tearing of foam.
Sent from my SM-N920W8 using Tapatalk
Old 12-27-2015, 04:19 AM   #187
akiranakayama
Drives: 2013 Subaru BRZ Limited (CBS)
Originally Posted by Sony View Post
The Review!
This wont be much of a review sound and performance wise as the car never left the garage. Unfortunately it's winter here and the roads are covered in salt. Also as you can tell my car does not have winter tires so it hasn't left the garage yet.
The install went fairly well, as I said previously I was working by myself in my garage. Of course this was easier for me as I (as you can tell) own my own garage lift which makes working on my cars far easier than most.
Any problems I had were due to ether my own stupidity or difficulty deciphering the pictures in Perrin's instruction manual. I would ask Perrin that maybe in the future they consider color printing their manuals, as the black and white pictures are hard to understand. I know this is added cost, but it would make installation MUCH easier and understandable. I think I had the same suggestion for their Cat-Back.
As I said before, if you want an easy intake install, look elsewhere. The aFe Takeda intake installs in about 15 minutes and is super easy. The Takeda however is not a true CAI and does suck hot air in from the engine bay despite having an intake spout pointing at the hole where the original snorkel used to come in. @2forme can back me up on this, he has logs of both the aFe and Airaid intakes and their intake temperatures.
All in all the install went fairly well, and the products fit and finish was good. I started the car and pressed the gas a couple times to rev the engine. The sound is pretty nice, when you first step on the gas it has a pretty cool POOF sound as the air accelerates through the filter upon tapping the gas. The filter is of good construction, although I do wish Perrin had offered a Dry Filter option as I am not a huge fan of oiling filters as they are messy. The filter has an inner metal cage to keep it's shape and prevent collapse. All the pieces fit together with little difficulty and I did not have any trouble getting everything lined up properly.
So far I would give this intake a good review but I have not been able to comment on performance yet as that will have to wait until a sunny day when I can go for a ride. I will also have Dyno's soon as I will be taking my car to @Kaizen Tuning for a retune. More info and further review to come then!
Thanks for reading!
-Trev a.k.a. Sony
[/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE]
Random question...
Is that a shared common underground garage? Like in an apartment or condo building? If so, it looks like the board allows tenants/owners to keep stuff in their parking spots? AND YOU HAVE A LIFT IN THERE? AND YOU CAN WORK ON YOUR CAR IN THERE?! Do you keep your tools in your spot? If so, aren't you afraid of theft?
So many questions!
2016 Scion FR-S
1991 Acura NSX
2012 Mazda Miata (Track)
2019 Triumph Bonneville Bobber
2007 Suzuki SV650 (Track)
akiranakayama is offline   Reply With Quote
Old 12-30-2015, 02:10 AM   #188
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
Originally Posted by akiranakayama View Post
Random question...
So many questions!
Haha, funny you should ask. It's a condo, there is no board, there is only 6 units and we are all wicked chill friends and run the Condo Association together, there is no outside management company. The garage is completely secured so there is no access to anyone from the outside so we all just keep our stuff in the garage. It's a pretty sweet arrangement but I will admit I did pay a very pretty penny for the privilege (close to half a mil). Totally worth it though, my neighbors are super chill and don't give any f***s about me working on cars in the garage. The building is inset into a hill and the garage is the basement of the building so the basement ends up with 14ft ceilings which is perfect for a lift. I have power run from my circuit breaker panel into the garage with a 240volt 30amp service that powers the lift and a second 120v 20a line that powers my compressor and other electric tools.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 03-28-2016, 04:37 AM   #189
tracerit
I was strolling around ft86speedfactory and noticed that the regular Perrin CAI is now CARB APPROVED!!!!! Now I'm feeling pretty bad about having just purchased the HKS intake duct just last month :/
http://perrinperformance.com/i-13324...-fr-s-brz.html
@PERRIN_Chris are all regular Perrin CAI's CARB approved retroactively or will there be a new batch being released?
Old 03-28-2016, 02:49 PM   #190
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
That's right, they're CARB approved now! This also applies to the intakes we've sold in the past since they are the same intake. If anyone needs a CARB sticker, send me a PM with your address, thanks!
PERRIN_Chris is offline   Reply With Quote
Old 05-02-2016, 04:56 PM   #191
Jfheisenberg
Hey guys, i just installed my perrin cold air intake. I actually forgot to add the air divider, is that necessary? i'll be taking the bumper out again to align it better so im just wondering if it should add the air divider or not.. please advise.!
@PERRIN_Chris
Old 05-02-2016, 05:02 PM   #192
PERRIN_Chris
You mean you forgot to add the two brackets to push the bracket away from the filter? I'd take the bumper off to add them, it could put pressure on the filter and maybe cause it to break eventually. Remember not to overtighten the clamp going to the filter! I see that happen a lot and the rubber on the filter breaks.
Old 05-02-2016, 05:57 PM   #193
Jfheisenberg
i meant to say that i did not used those two brackets because i forgot to add the air divider panel that goes behind the intake. In other words, there is nothing behind the cone right now.
from what i read that panel is called air divider, not sure if it needs to be there or not.
Old 05-02-2016, 06:35 PM   #194
PERRIN_Chris
OK got it, you'll want to put that diverter back for sure, it could make the MAF get some weird readings. At least you'll get some practice getting the bumper off!
Old 05-02-2016, 06:47 PM   #195
Jfheisenberg
ok thanks. Yeah i havent got any cel codes yet. Oh and yes , the bumper is a pain to take out, well taking the side markers makes it complicated
Old 05-14-2016, 04:43 PM   #196
LenA
Drives: 2015 Silver BRZ
Is intake only CARB approved if you use the stock hose and sound generator or is the silicon intake tube also legal?
For folks that report smoother takeoff from rest, is that likely due to better throttle response as Perrin dyno does not seem to show much low rpm torque improvement?
Thanks
Len
LenA is offline   Reply With Quote
PERRIN Silicone Intake Duct Review JoeBoxer Engine, Exhaust, Transmission 287 01-24-2018 10:01 PM
Perrin Catback Exhaust Installation and Review! Sony Engine, Exhaust, Transmission 316 01-24-2016 01:01 PM
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
cold air intake? carbonBLUE Engine, Exhaust, Transmission 72 09-30-2013 12:56 PM
REVIEW: FA20Club Tune, AFE Intake, and Perrin Pulley draggin_az Engine, Exhaust, Transmission 21 04-29-2013 04:58 PM
