Old 12-08-2015, 12:31 PM   #295
rx3
Yes, they are pretty fat. They are oval shaped (width: 40 mm; height: 20 mm).
I want to have an aluminum crossbar (L-profile) welded on those (the flat part can be welded onto those oval bars.)
(I'm getting KW competition coil overs and KW meanwhile told me that they'll install springs with a spring rate of 120 N/mm (12 kg/mm). I asked whether any softer would also be an option but they advised against it (racing slicks).
Because of it I think the chassis needs to be reinforced, but I don't want to add too much weight.)
rx3 is offline   Reply With Quote
Old 03-05-2016, 07:17 PM   #296
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
Originally Posted by rx3 View Post
Does anybody know whether there's a similar alloy bracket for the other side?
http://shop.namelessperformance.com/...rz-fr-s-gt-86/
Or what options does one have to get rid of that other heavy bracket?
Velox makes one for both sides, I don't know exactly how much lighter it is, but they claim to save over a pound with their driver side one: http://www.velox-motorsports.com/#!p...f-8a9b1e2f06b8
Mad_Mike is offline   Reply With Quote
The Following User Says Thank You to Mad_Mike For This Useful Post:
rx3 (03-28-2016)
Old 03-26-2016, 09:14 AM   #297
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
I weighted my SPL Parts and JRZ stuff
JRZ 12-32 front strut with quick disconnect and camber plate 7.3kg (I had to use a regular scale for humans, because too heavy)
JRZ 12-32 rear with quick disconnect 4.629kg
SPL Parts rear toe arm with lockout 0.834kg
SPL Parts rear traction arm 0.938kg
SPL Parts tie road end 0.507kg
SPL Parts rear LCA 1.643g
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
The Following User Says Thank You to MaximeT For This Useful Post:
Anthony (03-26-2016)
Old 03-26-2016, 12:33 PM   #298
MaximeT
MaximeT's Avatar
Originally Posted by SmartedPanda View Post
BRZ Spoiler weight?
1.580kg
The Following 2 Users Say Thank You to MaximeT For This Useful Post:
Anthony (03-26-2016), SmartedPanda (03-26-2016)
Old 05-02-2016, 07:16 AM   #299
Blokatos
Drives: MX5 Miata Mk2.5 1.6
One of the best threads in these boards! Great info and a lot of hard work.
I am def gonna join the add lightness wagon when I get my GT86.
In my Miata I have managed to shave off almost 100 lbs of weight while keeping all of its safety features and most of its comfort ones. Its a DD of course.
I have read many controversial posts regarding CF products for the 86 platform. So far, I have read that hood (aluminum) is not worth the hassle or the money, and the same applies for the fenders and possibly for the trunk. From whats it is posted in here, the savings are not substantial to justify the expense.
How about the roof and the doors?
CF doors 10.05 lbs http://seiboncarbon.com/store/produc...-use-only.html
CF roof 6.83 lbs http://seiboncarbon.com/store/produc...te-finish.html
I know its a ton of money but I am thinking that if and maybe the weight difference for the roof is substantial, it may worth a shot as it will give the added benefit of further lowering the already low CofG...
Blokatos is offline   Reply With Quote
The Following User Says Thank You to Blokatos For This Useful Post:
SuperTom (01-16-2020)
Old 05-02-2016, 07:20 AM   #300
MaximeT
MaximeT's Avatar
Most parts from Seibon are heavier than stock.
Custom door cards looks like a better option.
Old 05-02-2016, 07:30 AM   #301
Blokatos
I see although I haven't found how much a door weigh.
How about the roof? Stock must be a lot heavier than 6-7 lbs though...
Old 05-02-2016, 07:34 AM   #302
MaximeT
MaximeT's Avatar
Dunno, I think I have seen somewhere that the seibon roof is heavier than stock too.
Old 05-06-2016, 05:49 AM   #303
rx3
A fog light delete would only save 60 g on each side (120 g total). (They don't sell this car without fog lights here, so I thought this could be a potential savings. Unfortunately, it's not as much as I was hoping).
The Following 2 Users Say Thank You to rx3 For This Useful Post:
Blokatos (05-06-2016), MaximeT (05-06-2016)
Old 05-10-2016, 07:55 AM   #304
MaximeT
MaximeT's Avatar
I just found that for the roof part :
http://www.rhdjapan.com/pro-composit...6-zc6-brz.html
It says OEM is 5.7kg
Blokatos (05-11-2016), Grambi (09-15-2018)
Old 05-12-2016, 10:35 PM   #305
makesdrivingfunagain
Hi everyone, thanks for your contributions!!
I am not sure if the weight of the stock springs were stated in this post. But I just installed my braille 15lb battery and TRD springs. I weighed the springs just for the heck of it and found the TRD's weighed more.
Weight of stock springs 2.6lbs each (according to my scale) front and rear stock springs weigh the same.
TRD springs weight Front 3.6lbs Rear 4.8lbs
By switching to the TRD springs I gained 6.4lbs
Does, this sound about right?
If I had a bit more time I would like to produce an excel spreadsheet with all this data in this thread : )
Just FYI
makesdrivingfunagain is offline   Reply With Quote
The Following User Says Thank You to makesdrivingfunagain For This Useful Post:
8686 (05-13-2016)
Old 05-13-2016, 01:44 AM   #306
rustyfender
Drives: 2013 Frs
Stiffer springs means thicker springs. Thicker slrings means heavier springs
Sent from my SM-G930W8 using Tapatalk
rustyfender is offline   Reply With Quote
Old 05-13-2016, 12:21 PM   #307
Thanks I didn't realize that.. I was surprised, quite surprised..
Old 06-24-2016, 11:29 PM   #308
RCSlide
Drives: Ultramarine 2013 FR-S
Not necessarily, the spring could just have fewer coils or be manufactured in a way that produces a stiffer steel.
RCSlide is offline   Reply With Quote
diet, heavy, light, reduction, weight
So what is the official weight? brillo Scion FR-S / Toyota 86 GT86 General Forum 76 05-03-2020 05:11 PM
Official Weight Reduction Thread - Sort of... merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 77 10-07-2012 05:09 PM
2012 Geneva - Toyota GT86 in Black, Blue, White, Orange. Official weight & 0-60 Shown Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 124 05-28-2012 12:20 PM
Official JDM BRZ weight and MPG ayau BRZ First-Gen (2012+) — General Topics 50 02-08-2012 02:04 AM
