#281 |
Drives: 2014 FRS JRSC'd
E85 is difficult enough to cold start right now, I can only imagine what e100 would be like. I wish e98 was available besides by the drum.
#282 |
Drives: 2013 FRS / 2013 427 Vert
As much as I have enjoyed my tuned, bolt on set up, both on the street and many track days, I was finally ready for some boost. For my application I decided the Jackson Racing high boost setup was the ideal choice.
Special thanks to the following for making this happen: CSG Mike for a great package deal and bailing me out with an emergency delivery of a Jackson Racing oil cooler when we discovered the Robi Spec Combo needed to be replaced. Rev Works in Orlando for a flawless install HRI Tuning (James) for custom dyno tuning the car to my specific requests. Absolutely perfect street manners and great power numbers from a conservative by choice tune. The powertrain mods at this point are: Jackson Racing High boost kit + oil cooler ID 1000 injectors FB Walbro 485 fuel pump FB Radiator HKS catless header and front pipe Ultimate Racing 3" cat back In two weeks of post install driving I am really pleased with the fact that the car drives perfectly but with just so much more power. The only thing I am going to change is to raise the rev limiter back up to 7400 because the 7K ceiling is a nuisance. I will update this post with pictures and more perspective when I have a little more time but for now
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
| The Following 3 Users Say Thank You to Deep Six For This Useful Post: |
#283 |
Drives: 86
#284 |
[SIGPIC][/SIGPIC]
| The Following User Says Thank You to Deep Six For This Useful Post: | juliog (01-30-2016) |
#285 |
Taking Corners
Drives: 2014 FR-S Whiteout Monogram
Since I only have access to 91 octane, would be possible to install the HBP to increase my low end boost and then also install a wastegate to vent at 9 PSI so that I don't overboost for my gas on the high end?
I mean I understand I'd have to still get retuned as the boost curve would shift, but would this work? |
#286 | |
#287 |
Drives: 2015 BRZ
I finally got my high-boost pulley installed
Running the JRSC with HBP, Delicious flex fuel & DW 700cc injectors, and completely stock exhaust. I'd like to thank @CSG Mike and Zach @DeliciousTuning for all their advice & help. Car really MOVES now! Logged about 11psi at 7000RPM and 14.5 at 7700. Really moves the power band down a bit so I almost feel like I have some torque. And it's not loud at all. With the stock header & cats, you really can't tell anything is different. The only clue that I've got anything is my Jackson Racking license plate ![]() Got a DW300c fuel pump on the way but the stocker seems to handle the load fine for now. And I'm only at 50% ethanol with my first fillup, so I'll probably see a bit more umph down the road... Mike & Zach!-Mark |
#288 |
Drives: subaru
HBP has arrived. Waiting on fuel pump now. Should have it tuned and ready to go by the 15th! Will post dyno graph. Expecting at least 285whp on 94 & 12psi
| The Following User Says Thank You to BRZ'13 For This Useful Post: | CSG Mike (04-03-2016) |
#289 |
Drives: subaru
Finished tuning the brz today. Made 270whp on the HBP running 94. Dyno graph to come!
For comparisons: Car made 255whp on 9psi on 94 175whp with EL pt-tuning headers (pt-tuning claims 200whp on 93 lol) and nameless downpipe&overpipe 150whp baseline bone stock on 94 Dyno is super low reading compared to the other results iv seen (hence 150whp baseline on 94) Gained alot throughout the mid range (15-30whp/tq) but higher end was knock limited due to fuel. Was going to run E90 next to get 320whp but i am going to ditch the FA20 and do an LS swap instead. Far more reliable with more room to grow. |
#290 | |
Drives: '15 FRS
| The Following User Says Thank You to VitViper For This Useful Post: | Jmonty (05-01-2016) |
#291 |
Drives: subaru
Yes its on a dynapack! But i think on any of the dynojets etc i can clear 300whp no problem. Just didnt want people thinking the HBP is not worth it. Gained way more in the mid range then i thought
| The Following User Says Thank You to BRZ'13 For This Useful Post: | CSG Mike (05-01-2016) |
#292 |
Drives: '15 FRS
I just recently installed Jackson's HBP, tuned by Bill yesterday at Delicious Tuning:
e60: 293 WHP on mustang Dyno. I can post the dyno sheet later today when I get a chance if anyone is interested. I'm not sure what he issue was but according to Bill it seemed as if I was maxing out around 10.5 psi. |
#293 |
Drives: '15 FRS
To followup, after contacting Jackson Racing. They told me that the lower psi is due to me running c38 supercharger. If I was on the c30, it would be around 12 psi which is what the c30 would need to make the same power as the c38 on 10.5 that I was maxing out at.
| The Following User Says Thank You to whatevervu For This Useful Post: | kevin.nguyen (11-17-2016) |
#294 | |
Drives: 2016 Scion FR-S
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing BRZ | Parikh1234 | Member's Car Journals | 31 | 12-29-2015 10:26 AM |
| Why no high rpm boost for Phantom ESC? | stevo585 | Forced Induction | 11 | 02-11-2014 08:51 PM |
| Jackson Racing FR-S | Unleashed | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 11-18-2012 03:29 PM |
