Old 06-17-2012, 12:18 PM   #15
DEC1
Drives: '10 Infiniti G37 (pre-ordered BRZ)
Here you go!...sorry for the delay.
I didn't disconnect the battery...because I didn't want to lose all my radio presets and phone connection etc...not sure I would have lost them but didn't want to take the chance...make that decision at your own risk.
DEC1 is offline   Reply With Quote
The Following 10 Users Say Thank You to DEC1 For This Useful Post:
BabaYaga (02-25-2015), Choco (03-01-2015), DaJo (06-17-2012), Gaen (06-17-2012), matsayswhat (06-29-2012), Smokinbuffalo (06-17-2012), TheSt|G (10-19-2012), ts87 (06-12-2013), voyager2285 (02-14-2013), WRXGuy1 (06-17-2012)
Old 06-17-2012, 02:17 PM   #16
nibor33
nibor33's Avatar
Drives: SSM BRZ-L 6MT (gone)
I was going to do this but... That wire being exposed looks really "unfinished." Is this the final result or is there another cover?
Thanks
nibor33 is offline   Reply With Quote
Old 06-17-2012, 02:43 PM   #17
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Very nice, sir. :happy0180:
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 06-17-2012, 03:19 PM   #18
DEC1
Thanks
hahaha...unfinished? Every mirror like this out there has that wire...keep in mind how close I was when I took this shot. You can barely notice it otherwise.
It needs to be a little loose though..so you can adjust the mirror.
I could probably pull a bit of it in now that I'm adjusted and all set.
Old 06-18-2012, 02:13 AM   #19
nibor33
nibor33's Avatar
Yeah, the factory ones I've experienced (like VW, Audi) have the wires buried under plastic covers. I thought since this was a port installed option it would look completely factory installed. It's not a huge deal but definitely looks like an afterthought.
Old 06-18-2012, 11:22 AM   #20
Cudgel
Drives: 2008 Mazda3 GT Hatchback
I did this to my Mazda3 and I had to run wires down the A pillars and I also had to find wires to tap into. This one is sooooo much easier!
Cudgel is offline   Reply With Quote
Old 06-18-2012, 12:25 PM   #21
DEC1
I'd like to see if anyone that had theirs port installed looks any different...but really it looks fine to me and I'm about as fussy as they come.
The Following User Says Thank You to DEC1 For This Useful Post:
nibor33 (06-19-2012)
Old 06-18-2012, 04:51 PM   #22
jjdrivesajazz
Drives:
nice!
jjdrivesajazz is offline   Reply With Quote
The Following User Says Thank You to jjdrivesajazz For This Useful Post:
Ahz (11-04-2012)
Old 08-26-2012, 06:21 PM   #23
01s0uljah
Drives: SWP Subaru BRZ Sport-Tech 6AT
Just installed my AutoDim with Homelink but failed at syncing up my garage door opener..
I held down buttons 1 and 3 for 20 seconds. Then pressed and held the garage door opener remote with buttons 1 and no luck..
Any insight?
01s0uljah is offline   Reply With Quote
Old 08-26-2012, 07:00 PM   #24
cnk
Drives: '13 DGM BRZ Limited
I thought you were supposed to hit the button on the actual garage opener when synchronizing the homelink unit? Same way as when you are programming a new remote. Should be a button under the cover or on the back of your opener unit.
Old 08-27-2012, 04:48 AM   #25
jstans84
Drives: Scion FR-S
Hmm...I might just have to throw this on my FR-S...
jstans84 is offline   Reply With Quote
Old 08-27-2012, 07:50 AM   #26
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
Most other cars with powered RVMs have the wiring in some kind of tubing/cover, flexloom, etc.
I intend to add this to my car when/if it ever arrives. I'll probably use heatshrink tubing on the wires.
Admiral Ballsy is offline   Reply With Quote
Old 09-16-2012, 06:39 PM   #27
DaJo
FT86Club Vancouver
DaJo's Avatar
I've installed mine a while back; but lately I've been hearing rattling noises from the mirror, so I took it off...
It appears that the aluminum piece (Screw Plate) that slides under the "U" clip is stripped?
I can't tighten the two screws into the screw plate tightly...it just free-spins no matter how many times I turn it.
I may have to order another one; but I forgot if this Screw Plate comes in the "adapter" package or if it comes with the mirror.
(Is there a part number JUST for that plate or do I have to order in the whole package?)
Does anyone have a picture of theirs so I can compare?
The piece is letter "I" (Screw Plate) in the diagram.
Thanks in advance!
2000 MR-S 5MT
2010-2012
The Following User Says Thank You to DaJo For This Useful Post:
choi0706 (10-18-2012)
Old 09-23-2012, 07:35 PM   #28
nightfire
Drives: 2013 SWP BRZ Limited manual
Anyone know how to actually sync the homelink with the garage door opener? Just got my BRZ with the homelink mirror and I have no clue how to sync it. Looked in all of my BRZ documentation and it doesn't even mention anything about the homelink mirror :/
nightfire is offline   Reply With Quote
Homelink mirror ? FRS not an option - so does BRZ part fit ? rikdrt1 Scion FR-S / Toyota 86 GT86 General Forum 5 06-12-2012 11:00 AM
How to install Homelink mirror? Grimlock Electronics | Audio | NAV | Infotainment 10 06-10-2012 06:07 PM
Nav auto dimming when headlights on speedracer38 Electronics | Audio | NAV | Infotainment 1 06-06-2012 12:59 AM
Auto Dimming Homelink/Compass Mirror Part Number R0ME0 BRZ First-Gen (2012+) — General Topics 5 04-19-2012 12:19 PM
question about tinted windows with auto dimming mirror... Norcalmav23 BRZ First-Gen (2012+) — General Topics 13 04-06-2012 07:37 PM
