Old 04-20-2016, 10:55 PM   #379
nickg
Drives: 2014 Whiteout FR-S Manual
Originally Posted by gkubed View Post
What LCAs can you get for ~$200?
SPC are the only new ones I think. Theyre around $220 IIRC
Sent from my XT1575 using Tapatalk
nickg is offline   Reply With Quote
Old 04-20-2016, 11:17 PM   #380
Kaotic Lazagna
Drives: GR Corolla
Got my Whiteline for about $200.
Old 04-21-2016, 06:49 AM   #381
Tor
Tor's Avatar
Drives: Toyota GT86
SPC. 229$
Tor is offline   Reply With Quote
Old 04-21-2016, 01:21 PM   #382
n0thing
Drives: Subaru BRZ
How does this compare to the original, albeit discontinued, Control Master Type Flex?
n0thing is offline   Reply With Quote
Old 04-22-2016, 05:08 PM   #383
gkubed
gkubed's Avatar
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
Any of you guys running Flex Z's with 18x9.5 +45 wheels and 265's?
gkubed is offline   Reply With Quote
Old 04-25-2016, 08:51 AM   #384
blackpolarbear
Drives: 2015 frs
Just throwing this out there, but has anybody played with max lowering these coilovers? And maybe pics?
blackpolarbear is offline   Reply With Quote
Old 04-25-2016, 09:22 AM   #385
Kaotic Lazagna
Drives: GR Corolla
Front max out completely. Even one or two rings removed. Rear are maxed out in shock length, and have either half or an inch of threads left for pre-load (was really trying not to mess with that, but had to in order to even out the drop).
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
stock (06-24-2016)
Old 04-25-2016, 03:01 PM   #386
blackpolarbear
Drives: 2015 frs
I'm assuming you're running LCA's as well? Any other suspension mods?
Old 04-25-2016, 04:49 PM   #387
Kaotic Lazagna
Drives: GR Corolla
Whiteline rear LCA. No other suspension mods outside of that.
Old 04-28-2016, 07:52 AM   #388
SG02WRX
SG02WRX's Avatar
Drives: SWP WRX HATCHBACK
Question
I'm trying to search for solution to this. I plan to purchase a set in the future. Sometimes I carry things in my trunk, a guitar case most of the the time. I feel when the case moves or shfits, it will Just break or bend these tips. Can these tip/knobs be removed? Or is there a solution to where the knobs are not part of the trunk space. TIA
SG02WRX is offline   Reply With Quote
Old 04-28-2016, 02:21 PM   #389
banane63
banane63's Avatar
Drives: BRZ Club blanc perle
I have the EDFC motors, that's make a bigger risk to broke something with wild things in the trunk...
I put U shapped metal plate around it, screwed on the body of the car with screws for metal. I put some plastic protection around it.
Collecteur et frontpipe Supersprint full décat - Catback Remus
Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons
banane63 is offline   Reply With Quote
The Following 3 Users Say Thank You to banane63 For This Useful Post:
CSG Mike (04-28-2016), CxG (05-24-2016), SG02WRX (04-28-2016)
Old 04-28-2016, 02:26 PM   #390
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
if you put the Subaru OEM all-weather trunk liner in the trunk:
http://subaruonlineparts.com/subaru-...ay-p-1338.html
The knobs are protected by the liner (i took the rubber cover off the knobs). don't cut holes in the liner. The liner will just deform slightly to accommodate the knobs. It's unnoticeable as there's some space between the liner and the wall due to a lip.
shiumai is offline   Reply With Quote
The Following 8 Users Say Thank You to shiumai For This Useful Post:
aegisdrgn (05-08-2016), CSG Mike (04-28-2016), CxG (05-24-2016), Josue Cafe FR-S (06-01-2016), n0thing (04-28-2016), oldgunfan (12-18-2016), SG02WRX (04-28-2016), TofuJoe (08-14-2016)
Old 04-28-2016, 05:12 PM   #391
shiumai
shiumai's Avatar
added photos
Old 04-28-2016, 05:55 PM   #392
SG02WRX
SG02WRX's Avatar
Originally Posted by shiumai View Post
added photos
Thank you Shiumai. Im sure you've help more people than just me.
Hows the fit of the tray?
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 03:44 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 03:22 AM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 03:12 PM
25% Off Tein Street Flex's!!! RallySport Direct Brakes, Suspension, Chassis 0 12-31-2014 04:52 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
