Old 04-28-2016, 03:34 PM   #3753
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by Apex_BRZ View Post
I'm looking at the CSGarage Essex AP Racing Sprint kit again. I will be at Road America this weekend, and that experience will determine whether I go BBK or not. I feel I've done as much as I can to the car without going to a BBK setup.
So, my questions. The car currently has the Touge Factory Duct Kit. Is there an adapter available for the Sprint kit that will let me connect the ducting to put air into the rotors? The Endurance Kit has an adapter, will that work on the Sprint kit also?
Will this kit fit on Enkei RPF1 17x7.5 wheels? If not, what can I do to make it fit?
Are you experiencing fade? Always bleeding the brakes before and after a track day? Using the proper compound?
Old 04-28-2016, 03:38 PM   #3754
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
Yes, yes, and yes.
Apex_BRZ is offline   Reply With Quote
Old 04-28-2016, 03:40 PM   #3755
OkieSnuffBox
Yes, yes, and yes.
Do it. No idea on the adapter, or how large a spacer need for the 7.5 RPF1.
Old 04-28-2016, 03:49 PM   #3756
redlined600
redlined600's Avatar
Drives: Fr-s
Yes, yes, and yes.
What are your tire and brake pad compounds?
redlined600 is offline   Reply With Quote
Old 04-28-2016, 03:59 PM   #3757
Apex_BRZ
I'm really just looking for answers on the Essex kit here from Mike.
But here's the setup if you guys really want to analyze it. Not really getting fade technically, but I did melt/overheat the XP10 pads I used last year going down into turn 5 at RA (also using Pedal Dance). I stepped it up to XP12's this year all around. If that doesn't do it, I don't really want to juggle pads again (I realize pads like Endless and PMu99's will be better). I'll just step it up to the BBK like I should have done from the start.
Bridgestone RE-71R
Speigler Stainless Lines
KNS Titanium Shims
DBA T3 Rotors
TF Brake Ducting
Carbotech XP12 (Front/Rear)
Motul RBF600
The Following User Says Thank You to Apex_BRZ For This Useful Post:
CxG (04-28-2016)
Old 04-28-2016, 06:06 PM   #3758
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Bridgestone RE-71R
KNS Titanium Shims
DBA T3 Rotors
TF Brake Ducting
Motul RBF600
I know it's not the answer you're looking for, but for anyone else looking for a kickass track setup, our guy loves the PFC 08/13 compounds with titanium shims and RBF600.
GSpeed is offline   Reply With Quote
The Following User Says Thank You to GSpeed For This Useful Post:
Uplink (04-29-2016)
Old 04-28-2016, 06:53 PM   #3759
redlined600
Drives: Fr-s
OK, just trying to help
Old 04-28-2016, 07:00 PM   #3760
Apex_BRZ
It's appreciated! Didn't mean to make it sound rude.
Old 04-29-2016, 08:54 AM   #3761
OkieSnuffBox
PM
Old 04-29-2016, 09:09 AM   #3762
ZionsWrath
Thanks
ZionsWrath's Avatar
Shoulda bought the kit before you spent all that on replacement hardware but the answer to your questions is "get a BBK"
I ran stock with XP10 once I got "track rubber", not even serious rubber, RE11A. I saw a dramatic increase in pad wear. Bought the kit after that. If you are melting XP10 it is a no brainer.
Not sure on the wheel fitment but there is a thread on AP sprint wheel fitment and you can print the template and check yourself. If not fit you can do extended studs and spacer or obviously buy new wheels.
Thread: http://www.ft86club.com/forums/showthread.php?t=64282
Template: http://www.essexparts.com/storage/wy...l_template.pdf
The Following User Says Thank You to ZionsWrath For This Useful Post:
dp1 (04-29-2016)
Old 04-29-2016, 10:08 AM   #3763
dp1
driving smoother faster
Drives: Sold
If you have the funds, if you enjoy pushing the car on track, if you want to stop thinking about brakes on track, just get it. Doubt you need ducts, I don't have them. I'm on JRSC/Ohlins/Slicks/AP Sprint/XP12/Torque RT700 - slicks chirp in braking zones but brakes don't fade.
I use 12mm aluminum spacer to fit +45 enkei rpf1, just follow instructions above.
Get them through CSG to help them help us
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
ZionsWrath (04-29-2016)
Old 04-29-2016, 10:34 AM   #3764
OkieSnuffBox
Ducts are always a good idea for track use.
Lower temps = lower wear, and it also helps with heat in the hubs/bearings as well.
Old 04-29-2016, 10:52 AM   #3765
Apex_BRZ
Nah. Thought my learning curve would be a bit longer and I wouldn't need to worry about a BBK for a very long time. Could have, should have, etc. It doesn't really matter, and it's not a big deal. Moving forward, it's probably time to try something different.
It's not that I "need" ducts with the BBK, it's that they are already there and installed. If I can use them by just buying an optional adapter, I'll do that. If not...well then they'll be pulled.
Thanks for the template info, forgot about that! I'll make one soon and pull the wheels to see if it'll fit.
Old 04-29-2016, 10:58 AM   #3766
ZionsWrath
Thanks
ZionsWrath's Avatar
If you end up having to buy new wheels take a look at the Endurance kit it has an adapter for brake ducts.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
