Old 04-27-2016, 10:21 AM   #1
FRSure
Drives: Toyota
CarJoying Head Unit
I have a 2014 Scion FRS and I'm planning to get a carjoying head unit.
It's not the Toyota Model but the Universal model..
I'm wondering if this is how you wire it and if it is compatible?
This is the head unit
https://www.carjoying.com/android-5-...rt-revers.html
Because it is a universal model..
I need the harness.. This is the harness
https://www.carjoying.com/joying-har...ess-cable.html
__
Because it is a double din and not toyota universal unit..
I would need the double din dash kit..
http://www.carid.com/american-intern...pn-ttr992.html
__
What other modification would I need?
And would the installation process go like this?
Remove Headunit -> Repin toyota harness from Pin 9 to pin 8 -> Connect toyota harness to the car harness -> Plug into new headunit -> Screw everything back in
Or can I just get this harness??
[ame="http://www.amazon.com/Wiring-Harness-Adapter-Toyota-Adaptor/dp/B00ZIBBK78"]Amazon.com: Wiring Lead Harness Adapter for Toyota ISO Stereo Plug Adaptor: Automotive[/ame]
FRSure is offline   Reply With Quote
Old 06-17-2016, 07:02 PM   #2
Peter_Chung
Drives: 2013 86 GT Black
Hi FrSure,
How did you go? Did you install the HU into you're car?
Peter_Chung is offline   Reply With Quote
Old 06-17-2016, 07:04 PM   #3
Peter_Chung
Im keen to know if you install that particular HU in your car? Was it easy enough?
OEM BRZ Head unit shdobxr Audio/Visual, Electronics, Infotainment, NAV 10 11-06-2015 12:43 PM
new head unit mrnibbs Electronics | Audio | NAV | Infotainment 3 06-04-2015 07:58 PM
BRZ Head Unit Into STI iamdaspoon Electronics | Audio | NAV | Infotainment 2 05-23-2015 03:06 PM
FS: BRZ OEM Nav Head Unit Griever423 Audio/Visual, Electronics, Infotainment, NAV 2 09-23-2014 03:02 PM
head unit in GTA excited86 Electronics | Audio | NAV | Infotainment 1 06-18-2012 07:42 PM
