Old 04-26-2016, 07:45 PM   #29
Trefoil
Trefoil's Avatar
Drives: GBS BRZ Harrop SC/PTuning Header
Does it offer the same amount of cooling for oil as the Jackson Racing oil cooler? Does it improve over OE coolant heat exchange despite the extra load?
Trefoil is offline   Reply With Quote
Old 04-26-2016, 09:48 PM   #30
TkTk
TkTk's Avatar
Drives: 2014 TRD GT86 CUP, 2014 991 GT3
Originally Posted by OkieSnuffBox View Post
That looks like abrasion damage to the hose from rubbing against those brake ducts.
If that's the case, it isn't the fault of the hose.
I would think abrasion would take a little bit longer ? This was after three trackdays only.
TkTk is offline   Reply With Quote
Old 04-26-2016, 10:01 PM   #31
OkieSnuffBox
Drives: '23 BRZ Limited
Have you read any of the thread? FFS
It's quite clear that's from abrasion. How hard it was rubbing, etc, all come in to play.
If I take a hose and lightly rub it on smooth plastic, or roughly run it across concrete...........do you think they will degrade at the same rate?
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
TkTk (04-26-2016)
Old 04-26-2016, 10:01 PM   #32
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by churchx View Post
About the only thing i personally would be careful with, is how well thermostat works in cold winter weather, as after all, mine is mostly daily driven all year, including temps of -25C. But i guess, if there would have been any problems with thermostats of JR's oil rad kits, it would be reported already about older separate oil rad kit, hence probably my worries are groundless, and so far this kit looks very likely to get in future purchase list.
This shouldn't need a thermostat. It will rely on the coolant's thermostat to maintain temperature. The temperature of the oil should come up faster, and be more stable.
I've been advocating for a good setup like this for a long time now. Robiespec tried, Skunk2 tried, and ACE tried that I know of. All failed for various reasons.
Now I need to reconcile that price. I'm sure it's fair for what the part is, but for an NA Street car in eastern Canada, I'm not sure if I can justify it to myself. As the weather warms and I start driving the FRS more I'll monitor my oil temps more closely and see whats what.
I'm really glad to finally see a reputable company bring this to market. I had high hopes for Ace, but they just couldn't get the cost down. Skunk2's was an ill conceived disaster from the one person that posed about it. Seriously, it seemed like they didn't even look at the car when they designed it, just bought a rad and made something similar in size but with an oil cooler loop. And Robiespecs (is it Robispec?) ... well, that was covered earlier I'm the thread.
Old 04-26-2016, 10:50 PM   #33
CSG David
CSG David's Avatar
JR's testing parameters and standards are quite aggressive. The type of thermostat being used is used for OE markets as well, which have a very strict quality control.
Abrasion is bad thing. We've seen ill-routed lines puncture within a few days of use. Take exceptional time to route the lines accordingly so they do not rub on anything. This will ensure reliable performance.
I'm really glad to finally see a reputable company bring this to market. I had high hopes for Ace, but they just couldn't get the cost down. Skunk2's was an I'll conceived disaster from the one person that posed about it. Seriously, it seemed like they didn't even look at the car when they designed it, just bought a rad and made something similar in size but with an oil cooler loop. And Robiespecs (is it Robispec?) ... well, that was covered earlier I'm the thread.
Throughout the years, Jackson Racing has been on the pedestal for high standards and you can definitely see that their products have stood the test of time especially on this platform. If you research their history dating back to the 70s, you'll see that their heritage is quite solid and a strong reason why the OE markets work alongside with them on various projects. Their expertise also reaches out to factory race teams that you may have already seen on TV as well.
The Following 4 Users Say Thank You to CSG David For This Useful Post:
CxG (01-10-2018), funwheeldrive (04-27-2016), TkTk (04-26-2016), Tristor (03-27-2018)
Old 04-26-2016, 11:44 PM   #34
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
So, come on kings of DATA @CSG Mike @CSG David
Lets see some numbers! (please)
The Racers Line is offline   Reply With Quote
The Following 7 Users Say Thank You to The Racers Line For This Useful Post:
BigFatFlip (04-27-2016), byun (04-27-2016), Calum (04-27-2016), chaoskaze (01-02-2018), drewbot (05-15-2016), megamarines (04-27-2016), Tristor (03-27-2018)
Old 04-27-2016, 12:11 AM   #35
Ro_Ja
Drives: TOYOTA
Wow. I'm sold.
Ro_Ja is offline   Reply With Quote
Old 04-27-2016, 01:59 AM   #36
CSG Mike
CSG Mike's Avatar
Would you like to fund some testing?
I don't think data is necessary to demonstrate the benefits of a larger radiator and oil cooler, but if you insist, we're happy to oblige.
Rifle (04-27-2016), Tristor (03-27-2018)
Old 04-27-2016, 02:50 AM   #37
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Curious to about warm up times as well. I live in a climate that super cold, up to 0f or less.. Know it's an issue for some with oil coolers.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 04-27-2016, 03:03 AM   #38
CSG Mike
CSG Mike's Avatar
Take the amount of time it takes for your coolant to fully warm up, and add about 90-120 seconds. That's about how long it takes for the oil to catch up. This is pretty universal for warm-up times with oil-coolant type systems.
The Following 6 Users Say Thank You to CSG Mike For This Useful Post:
Bonburner (04-26-2018), Calum (04-27-2016), CxG (01-12-2017), mathcore.zt (05-05-2016), Rifle (04-27-2016), Tristor (03-27-2018)
Old 04-27-2016, 07:42 AM   #39
Calum
That Guy
Fuck. *Looks at bank account, FUCK.
The Following 8 Users Say Thank You to Calum For This Useful Post:
Brayden_23 (06-08-2016), CSG Mike (04-27-2016), Joveen (03-15-2019), mx5 2nr (05-04-2016), Stang70Fastback (04-27-2016), Teseo (05-03-2016), Tristor (03-27-2018), ZionsWrath (05-03-2016)
Old 04-27-2016, 07:49 AM   #40
Calum
That Guy
"- Thermostatically controlled via cooling system"
Well, you're not wrong. But your post makes it seem the oil cooler is thermostatically controlled, which would be counter productive to the faster warm up times.
Old 04-27-2016, 09:01 AM   #41
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Is the radiator sold separately?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 04-27-2016, 10:35 AM   #42
Jas1137
Drives: 2015 Firestorm FR-S MT
Does this kit fit with the JR C38 supercharger?
Jas1137 is offline   Reply With Quote
Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler Jackson Racing Engine, Exhaust, Bolt-Ons 0 04-25-2016 06:35 PM
Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. OkieSnuffBox Engine, Exhaust, Bolt-Ons 5 01-12-2016 12:26 PM
Jackson Racing Supercharger and JR Oil Cooler bobsacamenoh Engine, Exhaust, Bolt-Ons 20 12-12-2014 03:00 AM
Jackson Racing oil cooler for NA vs FI ayau Engine, Exhaust, Transmission 1 05-29-2014 12:04 PM
