Old 06-12-2012, 12:22 PM   #267
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
He can drive. Oh and he won nationals on our shocks with his old STI.
Some camber in the back would help big time. I'm not sure the 16mm is too big just yet, but you have to get that alignment sorted.
- Andrew
agreed.....going here in few just to get it rechecked..at a different facility
Bill
Scooby South is offline   Reply With Quote
Old 06-12-2012, 04:13 PM   #268
Scooby South
Conedancer
As for the tires...they did get a bit hot...and greasy feeling with that much air in them... but pretty much came thru UN-scathed..
Old 06-14-2012, 09:35 PM   #269
Scooby South
Conedancer
the BRZ with the BBS....38.4 lbs...17x7, 235/40/17 RE-01r's about 1/2 tread..
The speedwagon gets the big shoes for now...till I can get the brakes swapped..... it does looooook SEXY..
Bill
Old 06-15-2012, 01:48 PM   #270
xwd
Let Jeff Cashmore drive your car, then you'll find out what it's capable of. He can adapt to pretty much anything in about 2 runs. I'm sure he'd be up for it to, he is usually itching to drive new model cars.
Phil (older school MKE autocrosser)
Old 06-15-2012, 09:34 PM   #271
Scooby South
Conedancer
feeling better about my alignment now..
Got some Camber bolts for some 'real' Camber...
-2.3 Camber front.. 0 toe
-.6 Camber Rear.. 0 toe..
Raybestas 616-1036
Did this.....VERY HAPPY...this will work till I get my suspension..
Old 06-15-2012, 09:35 PM   #272
Scooby South
Conedancer
Its a possibility..... just got my alignment done...I feel MUCH better now..
Bill
Old 06-16-2012, 03:27 AM   #273
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
We're you running camber bolts front and rear or just in front? Nice specs
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 06-16-2012, 05:23 AM   #274
Scooby South
Conedancer
just the front.....
Bill
Old 06-16-2012, 12:33 PM   #275
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
We're did you order the bolts from?
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 06-16-2012, 12:44 PM   #276
Scooby South
Conedancer
my local CarQuest had them...in stock..the are the same bolts as for a WRX..that I used..just give them that part number.. Raybestas 616-1036
Bill
Old 06-17-2012, 10:48 PM   #277
Scooby South
Conedancer
OK...Let me just say up front...HOLY SMOKES..this thing Responds to Alignment input.... and any kind of suspension tuning... With the camber sitting at -2.3 and 5.5 degrees of CASTOR... It planted the nose...and more or less could sit and spin on a dime... WOW... it 'tried' to go where I pointed it... it ROTATES and Pivots with the best of them...problem is...now the ass-end is loose, loose, loose... Course was a national style course...pretty open with lots of sweeps and transitions... The RE-01r's seemed to have absolutely NO GRIP in the rear @35 psi...the front was set at 40...I expected a marginal improvement in handling...what I got was a throttle on oversteer vehicle the skated all over the place..:/..I have never had a vehicle respond to minor tweaks like this one..... well I lowered the rear tire pressure to 28..*about as low as I wanted to take it...and ran in Sport mode on the traction control... it helped keep the rearend in check..however would not allow me to accelerate out of the corners like I wanted....bottom line is... This thing responds well to alignment tweeks...like no other... I ended up taking the Rear Bar completely off...it helped..but it was still twitchy under acceleration... With -2.4 degrees of camber...the wear pattern on the tires was about perfect...equal heat and rollover was right to the Arrow... now...IT NEEDS A FRONT BAR... I am hoping I can calm down the twitchyness with the coilovers... spring rates are going to be key to try to get the rear end planted so I can trust it to stick..almost like the rear stock spring rate is 'too much'... hard to believe I know.. but as twitchy as it was ...even with NO rear Bar...makes me wonder how it will respond to the Spring rates... more later..
Bill
The Following User Says Thank You to Scooby South For This Useful Post:
blu_ (06-17-2012)
Old 06-17-2012, 10:53 PM   #278
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
I think you are too use to Subarus. Thats a lot of front camber, which I know all the wrx's and sti's love and practically nothing on the back.
blu_ is offline   Reply With Quote
Old 06-17-2012, 10:59 PM   #279
Scooby South
Conedancer
you are probably correct...trying to get a WRX/STi to Turn is like putting a sign in the window of the local vet offering free Kittens...:/..it was 'always' a chore..:/ this thing...can spin like a top if need be..
Old 06-17-2012, 11:14 PM   #280
kanundrum
Drives: 2013 Whiteout FR-S
All of this looks simply amazing. Thanks for offering all your suggestions and input when it comes to tweaking the car.
My 2nd autocross event will be July 14th and between now and Then I have to setup the car.
By then I will be running the Dunlop Star Spec Z1's and should have alignment sorted out by then as well.
Looking at your alignment setup should I just go ahead and copy your homework ? Pretty much stock for now nothing on the car!
Or go with something a bit more conservative.
Subaru/Scion warranty and autocross Ribface Tracking / Autocross / HPDE / Drifting 55 06-17-2015 08:30 PM
Will you Autocross your 86? Ribface Tracking / Autocross / HPDE / Drifting 131 06-22-2012 05:48 PM
Which autocross class? jpdarty7 Tracking / Autocross / HPDE / Drifting 66 06-21-2012 05:53 PM
FR-S at a CA Autocross oneday Scion FR-S / Toyota 86 GT86 General Forum 57 03-26-2012 03:38 PM
