#1163 |
Drives: 2015 Subaru BRZ Pearl White
Well today was going to be the BIG day to install my E-Force open the box ------ no install manual . Of coarse They are closed today. I could use all the nice install online help but was hoping to use MY INSTALL GUIDE hope nothing else is missing. Could anyone post a pic of their parts list. Let's see how fast they send me one . I guess I'll try to do it (just went from 6-7 hours to ???) Glad the frige is full. :-)
#1164 | |
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
I believe that is the entire manual in PDF format. Those who actually have it could confirm. No fancy binder, but at least you can get started. |
| The Following User Says Thank You to Freude am Fahren For This Useful Post: | CSG Mike (04-24-2016) |
#1165 | |
Drives: 2015 CWP BRZ Limited
#1166 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
#1167 |
Drives: 2014 Porsche Cayman S
I am not sure who is in charge of their Quality Assurance, but I will take the job and get things back on track
![]() Sent from my XT1031 using Tapatalk
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
#1168 | |
#1169 | ||
Boost Creep
Drives: 2016 HyperBlue BRZ
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
#1170 |
Thank you to all the PDF file that Freude am Farhren sent a link helps a great deal. I'm about half way through the install. some of the pics for throttle body coolant hoses a little vague but going well. I added a larger radiator and oil cooler sorting that out with new brackets I should finish up by Thursday ( if work doesn't get in the way ) . Mike ( CSG Mike ) thank you very much for the offer by I'm going to make Edelbrock pony up ( get to get my Ecutek code anyway ) I'm still sure I made the right choice for Supercharging kit parts seem well thought out pre-formed hoses a nice touch.
| The Following User Says Thank You to Wraithrider For This Useful Post: | CSG Mike (04-25-2016) |
#1171 |
has anyone had issues with the coolant reservoirs? the reservoir with the SC kit is fine with coolant, i just need to open the cap to relieve the pressure for the coolant to show back up in the reservoir, but my coolant in the OEM reservoir is below the "low" marker. don't know if this is a stupid question but does the OEM reservoir level take precedence over the one that comes with the SC kit or does the other one essentially take over the "coolant level indicator" for the OEM. Thanks!
#1172 | |
| The Following User Says Thank You to BigFatFlip For This Useful Post: | JGalp (04-25-2016) |
#1173 | |
Boost Creep
| The Following 2 Users Say Thank You to Luftwaffel For This Useful Post: | JGalp (04-25-2016), Silverstar (08-24-2016) |
#1174 | |
#1175 |
That's normal for the SC reservoir, so don't worry about that. Mine does the same. My OEM reservoir was low too...I could not see any fluid, but when I started topping it up, it filled quickly. The level must have been just below the low marker. Most people say it is not a concern, as that exterior reservoir is not a key indicator for your coolant level. Go back a few pages in this thread for details.
| The Following User Says Thank You to paiceyfan For This Useful Post: | JGalp (04-25-2016) |
#1176 | |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
