| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: Asphalt 2013 FR-S 6MT
DIY OBD2/OFT Cutoff Switch
This DIY will show you how to hide your wires for OFT or other OBD2 devices, and install a switch to cut power to the devices when you aren't using them to limit power usage.
Tools/Materials needed:
![]() And the OBD extension I used can be found here. http://amzn.com/B00UR5XBMW On to the steps
OFT Stage 2 tune, OFH, Works AB-M, Perrin 2.75" Intake/Silicone inlet
Kartboy Short Shifter, WC Lathewerks knob, MTEC springs TSW Nurburgring, FIVE:AD aero kit, smoked Valenti Last edited by LaertesSon; 04-28-2016 at 01:00 PM. |
#2 |
Drives: 2016 ZC6
Do you have a larger pic of this shot? I have this connector and been thinking of this mod lately.
#3 |
Drives: 2014 SWP BRZ, MT
This is a very cool mod that I had planned to do myself, with a slight difference! Instead of running it to a switch I will be running it to an ignition switched power source so the OBD2 device comes on automatically when the car is switched on :p
The answer is racecar. Always.
#4 | |
![]() This might help clear it up.
Kartboy Short Shifter, WC Lathewerks knob, MTEC springs TSW Nurburgring, FIVE:AD aero kit, smoked Valenti |
#5 | |
#6 |
Drives: 2016 ZC6
| Tags |
| cutoff, obd, obd2, oft, switch |
| rev limiter / fuel cutoff | clayrush | Engine, Exhaust, Transmission | 49 | 07-25-2017 11:40 PM |
| Audio Cutoff Sub-woofer Install | srizzors25 | Electronics | Audio | NAV | Infotainment | 1 | 03-17-2016 04:18 PM |
| FS: Unichip, USB cable, 2 tune selector switch, Clutch switch | BII302 | Engine, Exhaust, Bolt-Ons | 6 | 04-13-2015 07:06 PM |
| 4350rpm rev cutoff after car crash | diodelphi | Issues | Warranty | Recalls / TSB | 9 | 02-26-2015 01:07 PM |
| How to replace turn signals with switch backs and its relay switch. | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-30-2013 11:42 PM |
