Old 04-23-2016, 08:35 PM   #1
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Transmission upgrade
I'm in the market to upgrade my junk factory MT transmission and ready the car for a built motor at the same time. I've found a company that sells custom bellhousings to pair block to trans but sadly no one talks nor offers a swap that isn't an old v160 that is overpriced even used. Where are our options? This car has been out for far to long.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 04-23-2016, 10:26 PM   #2
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
There are a couple gearsets available already, and more coming. I have a tremec but it's a custom fabbed bellhousing. Maybe this winter I'll pull it out now that I know it works and have it copied into cast units. I have an fa20 to v160 adapter plate for sale if anyone wants to make the mounts and stuff themselves
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 04-24-2016, 03:28 AM   #3
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Spencer Fab is working on a transmission swap for the fa20. They've yet to release any solid details but its definitely in-progress. As for gear set swaps, Velox and PAR Engineering are the only two real options, but neither set fixes the crappy synchros. Best waiting for a new swap to come out that isn't a v160, as they are so expensive it just isn't worth it.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 04-24-2016, 03:49 AM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I was just about to say, spencer fabrication on Facebook has been posting pics they are working on a built trans swap for the FR-S, however I'm pretty sure that's going to be a sequential dogbox type of sort of setup.
Old 04-24-2016, 08:05 AM   #5
FRS Justin
Drives: 2013 Asphalt FRS
Mark at Spencer fab and I talk about everyday and the swap is coming along nicely... Just a few more details to work out and it will be a done deal. The trans will be a normal trans with options to be face plated. I'm not sure how much he wants to release about it but the trans will be rated at "EDIT" UP TOO 575 wtq. and a direct bolt in. I feel comfortable saying it should be in the testing phase in less than 30 days, if not on the market for sale. When it comes out I will have 4 original trans for sale lol as that bad boy is going in my car!!!!!!
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 04-25-2016, 01:18 AM   #6
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Originally Posted by FRS Justin View Post
Mark at Spencer fab and I talk about everyday and the swap is coming along nicely... Just a few more details to work out and it will be a done deal. The trans will be a normal trans with options to be face plated. I'm not sure how much he wants to release about it but the trans will be rated at 575 wtq. and a direct bolt in. I feel comfortable saying it should be in the testing phase in less than 30 days, if not on the market for sale. When it comes out I will have 4 original trans for sale lol as that bad boy is going in my car!!!!!!
575tq... No guesses what it is off the top of my head, but it does sound promising. Plenty for any FA20 build. Almost makes me want to not continue my swap, but I'll wait for others to test it out before I know for sure.
Hopefully the ratios are similar to ours, or at the least slightly longer. Shorter ratios in the trans versus a stock trans would suck.
Old 04-25-2016, 03:59 AM   #7
FRS Justin
Ratios are a lot longer I'm super excited about that. The trans has been around for over 30 years so it's tried and true I ran them back in the late 80s and 90s with a V8 beating on them flat foot shifting down shifting you name it I did to this trans......I think first gear is around a 2.80 to 2.90 ratio and can go to a 3.95 if you desire, I do know you will have options on gearing. Also I should mention the tq rating is also a option from 330 up to 575 my bad for not being more clear on it in a earlier post....
710whp
Old 04-25-2016, 08:50 PM   #8
mrk1
Drives: Sterling BRZ Ltd
Synchro's naturally won't like high rpm, any trans. There is an inherent "wait" for synchro's to do there job. The higher the rpm the more work "synchronizing" speeds the synchro needs to do. This wears them out.
Everyone thinks HP/TQ is what kills everything but RPM's can be BRUTAL.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 04-26-2016, 05:20 PM   #9
HAWAIICALIVEGAZ
HAWAIICALIVEGAZ's Avatar
Drives: HONDA, TOYOTA
My motor is stock right now but I'd like to upgrade the teams eventually as well to prepare for a higher HP motor setup..
Sent from my SM-G935V using Tapatalk
HAWAIICALIVEGAZ is offline   Reply With Quote
Old 04-26-2016, 06:47 PM   #10
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
I know everyone hates synchros, or the az6 synchros more in general but here is a good read on synchros from jack's transmissions. I have only heard good things on how these guys can get synchros to work better than they did from the factory, the way they should work. It's good info, and I will see if it works since they will be working on my trans in June.
http://www.jackstransmissions.com/pa...o-blueprinting
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 04-26-2016, 08:31 PM   #11
mrk1
I have no proof but I'm willing to say a lot of peoples problems with synchros are probably from ham fist shifts and not a fault of the hardware. Look at YouTube comments these days, if your not pulling the shift knob off your not shifting hard enough. I think we all have that one friend who shifts like the trans owes him money.
Take care of your trans and most trans will take care of you.
The Build Thread
Old 04-27-2016, 08:47 AM   #12
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
You can always sell a kidney and get a hollinger
Gear_One_Performance is offline   Reply With Quote
Old 04-27-2016, 03:07 PM   #13
Ooo, this is great stuff. I'll be working on mine at around the same time. Let's share notes.
Old 04-27-2016, 07:53 PM   #14
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Really good news there, appreciate the info.
I understand, but meh. I had my trans replaced under warranty because the synchros started grinding from 3rd > 4th shifts after about 2k miles, but I bought it pre-owned with 26k. This was before the turbo went on. Who knows what the last owner did to it. I definitely don't shift "hard" or "fast", so I'm convinced the failure wasn't my doing. I intentionally babied it, and it did not grind when I bought it. Not to mention I short shifted at 7k 99% of the time. Good vid of how slow I shifted this car here
My 3rd -> 4th shifts I do with my middle finger lol. Not hard to shift this trans, but I do agree a lot of the faults are likely caused by the owners... Still, Subaru will warranty failed synchros so they're aware there is at least some kind of issue. I've owned so many cars, and this is the only car I've ever dealt with a failed synchro on.
Automatic Transmission (AT) Information and Upgrade Thread wlfpck Engine, Exhaust, Transmission 95 06-01-2021 10:40 PM
Next Upgrade? Luftmeister Tracking / Autocross / HPDE / Drifting 12 04-07-2014 04:25 PM
How to upgrade an AT FRS transmission? CodyFRS Engine, Exhaust, Transmission 13 12-06-2013 11:56 AM
HU upgrade briang0901 Electronics | Audio | NAV | Infotainment 15 11-05-2012 11:17 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
