Old 04-23-2016, 01:10 AM   #1
deuncos
Drives: AT Hot lava FRS
Catted UEL Header and Catless resonated/dual resonated front pipe?
Anyone have a catted uel header and catless resonated/dual resonated front pipe set up? I know that people usually do this the other way around, i.e. catless header/catted frontpipe, but just curious. If being specific, the JDL UEL catted header and the HKS dual resonated front pipe. Trying to see which would be more effective in keeping the noise down, a catted/resonated combo like JDL's ultra quite and nameless downpipe, or a dual resonated front pipe such as HKS and fujitsubo. Planning on pairing it up with a perrin 2.5 inch resonated catback.
deuncos is offline   Reply With Quote
Old 04-23-2016, 01:51 AM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Catted and dual resonated would be very effective, with a perrin resonated to back it all up, should be very tame and no rasp. Also important to note a common misconception is that cats quiet down the exhaust when in fact a resonator is much more effective, especially in the AT this is important to know if you want to prevent drone, as the AT FRS in drive tends to float around 1500-3000 rpm on very light acceleration throughout all gears which is a very drone rpm range for most exhaust systems.
@mav1178 has a good write-up of which front pipes were the quietest I believe.
If I had the choice I would do:
JDL Catted UEL
Nameless catted with helmholtz resonator downpipe
Perrin 2.5 inch resonated catback
You help with emissions quite a bit, and you get the advantage of cats and 2 resonators cutting out those harsh frequencies.
Old 04-23-2016, 09:30 AM   #3
cjd
cjd's Avatar
Drives: 2017 BRZ
I have a full JDL header back, but the ultra quiet over-frontpipe and resonated midpipe do surprisingly well given the rest of my setup. Fit on the over-frontpipe is awesome too.
Old 04-23-2016, 01:30 PM   #4
dustin_15halo
Drives: 2015 halo FRS
i have the catted ft86speedfactory header, with JDL ultra quiet frontpipe and ARK grip catback. My setup is really tame honestly. For me it's honestly too quiet haha. its basically only loud on cold start. When i added the JDL front pipe it was honestly only a bit louder then with stock front pipe
dustin_15halo is offline   Reply With Quote
Catted, resonated, or catless front pipe with Perrin Exhaust? brzbrad Engine, Exhaust, Transmission 19 07-03-2016 11:44 PM
[SOLD] Tomei Header (EL) and Invidia Front Pipe (Catless, Resonated) DSDtrilogy Engine, Exhaust, Bolt-Ons 13 01-04-2016 04:48 PM
FS: HSK Dual Resonated Frontpipe Migero86 Canada Classifieds 17 04-20-2015 07:28 PM
Nameless 2.5 (resonated/catless) op/fp combo Plxdjake89 Engine, Exhaust, Bolt-Ons 3 09-09-2014 10:40 PM
