Old 04-21-2016, 07:00 PM   #1107
johnmk
Fidei Defensor
Drives: 2015 Subaru BRZ Limited - Black
Exclamation
Originally Posted by Freddy@PTUNING View Post
just shipped out our first production GTX2867 turbo kit. Let me know if you have any questions.
Freddy
703.257.1728
freddy@ptuning.com
Mine, right?
I also got the PTUNING headers and 2.5" Perrin resonated exhaust. Install scheduled to begin 4/30, here in the Seattle area, completion probably in the first week of May.
The anticipation is real, it could even be borderline unbearable. Might need to see a doctor if this lasts a few more hours.
johnmk is offline   Reply With Quote
The Following 3 Users Say Thank You to johnmk For This Useful Post:
Freddy@PTUNING (04-22-2016), Steelscion (04-23-2016), tato.valverde (04-22-2016)
Old 04-21-2016, 08:43 PM   #1108
Deadpool_25
Drives: BRZ Limited
PTUNING Turbo Kit Owners Topic
Originally Posted by 20firestorm13 View Post
486/409 on a mustang dyno. Still have a lot of room but clutch isn't able to hold anymore. This was at 24lbs
Wow. What other mods have you done? Built motor I assume?
Edit: never mind. Just saw your build thread. Yup. Built. Very nice!
Build Thread
PTuning Turbo & Exhaust / JDL UEL Header / Delicious Tuning Flex Fuel / Eibach Pro-Kit Springs
Deadpool_25 is offline   Reply With Quote
Old 04-22-2016, 09:20 AM   #1109
Freddy@PTUNING
Freddy@PTUNING's Avatar
Drives: Honda S2000 & Acura RSX Type-S
Send a message via AIM to Freddy@PTUNING
Originally Posted by johnmk View Post
Mine, right?
Yes sir!
Freddy@PTUNING is offline   Reply With Quote
Old 04-26-2016, 03:19 PM   #1110
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
PTUNING Mechanical Turbo Oil Scavenge Pump Upgrade
For customers that are running our FRS/BRZ turbo system with the electrical turbo oil scavenge pump setup, we have recently released a mechanical turbo oil scavenge pump upgrade kit that includes all the components required for the upgrade. The mechanical pump setup is currently included in our PTUNING FRS/BRZ Turbo System.
You can find more details at the link below:
http://www.ptuning.com/subdir/partno...PKG-15000-PUPG
Kit Content:
- Mechanical Turbo Oil Scavenge Pump
- Billet Aluminum Pump Adaptor
- Billet Aluminum Oil Scavenge Sump
- SS Braided Oil Feed Line
- SS Braided Oil Return Line
- SS Braided Sump Breather Line & Filter
- Thermal Heat Shield Sleeving
- AN Fittings & Mounting Hardware
- Installation Manual
Mrc@ptuning is offline   Reply With Quote
The Following 5 Users Say Thank You to Mrc@ptuning For This Useful Post:
Guff (04-28-2016), Hicklinc (01-29-2018), kanundrum (04-27-2016), rb6freak (06-15-2016), tato.valverde (04-28-2016)
Old 04-30-2016, 09:18 AM   #1111
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Release an upgraded fuel system!
Element Tuning 10:1 Pro Comp Long Block, Ptuning SS GT3076R turbo kit, Exedy Stage 2 Clutch, and a bunch of other stuff
Darryljr11 is offline   Reply With Quote
Old 06-13-2016, 12:50 AM   #1112
kanundrum
Drives: 2013 Whiteout FR-S
Attended a Drift Event this past weekend for fun. Im am now hooked on getting a fluidic slide:
[ame="https://www.youtube.com/watch?v=uYdLNgUE9Gk"]Learning to Slide Drift Nirvana (Washington Circuit Summit point) - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=0Cx7QpLHlNM"]Learning to Slide Drift Nirvana (Washington Circuit Summit point) (Insi - YouTube[/ame]
The Following 6 Users Say Thank You to kanundrum For This Useful Post:
Guff (06-13-2016), jchudson13 (06-13-2016), M1K3 (06-13-2016), MooKz (06-13-2016), Mrc@ptuning (06-13-2016), rb6freak (06-15-2016)
Old 06-15-2016, 04:47 PM   #1113
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Kit Content:
Worth the upgrade for existing owners! Light weight, simple and clean. I do miss the scavenge pump sound though LOL.
rb6freak is offline   Reply With Quote
The Following 3 Users Say Thank You to rb6freak For This Useful Post:
Hicklinc (01-29-2018), kanundrum (06-15-2016), Mrc@ptuning (06-17-2016)
Old 07-17-2016, 09:03 PM   #1114
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
Checking things over today and noticed the turbo inlet hose is in contact with the exhaust. Anyone run into this?
Didn't get a chance to inspect closer for damage to the inlet hose.
skylinekin is offline   Reply With Quote
Old 07-18-2016, 11:29 AM   #1115
Freddy@PTUNING
It's supposed to be close but not touch. Take the intake out, rotate the coupler more towards the trans, then re-install the intake and make sure you hold it towards the trans while you tighten it to the direct injection sub-bracket.
Let me know if that doesn't make sense.
The Following User Says Thank You to Freddy@PTUNING For This Useful Post:
Old 07-18-2016, 12:24 PM   #1116
skylinekin
skylinekin's Avatar
Makes sense, will try adjusting it. Thanks for the quick response.
Old 07-20-2016, 10:04 AM   #1117
Freddy@PTUNING
No problem!
Old 07-24-2016, 08:18 PM   #1118
skylinekin
skylinekin's Avatar
Those who are doing track days with their Ptuning kit, any thoughts on an oil catch can setup or AOS?
Also, is the recommendation to use OEM spark plugs w/ the turbo kit?
Old 07-25-2016, 10:26 AM   #1119
Freddy@PTUNING
Radium dual catch cans have been popular.
Yes, we recommend using the OEM spark plugs.
Old 07-25-2016, 02:40 PM   #1120
mkivsoopra
+1
I have Radium dual catch cans on my car, and had 30+ track days on my setup using OEM spark plugs. Finally had to change the plugs recently due to misfire, but that's after 35k of hard miles.
mkivsoopra is offline   Reply With Quote
The Following 3 Users Say Thank You to mkivsoopra For This Useful Post:
Freddy@PTUNING (07-25-2016), Hicklinc (01-29-2018), kanundrum (07-25-2016)
ptuning, turbo kit
Full Blown Turbo Kit Owners Topic King Tut Forced Induction 2639 04-05-2026 10:31 PM
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
