Old 04-20-2016, 09:21 PM   #1765
BRZ'13
BRZ'13's Avatar
Drives: subaru
Having some issues with my set up.
Installed 265/35/18 achillies 123s rear tires this weekend and its rubbing on the quarter panel lip with 2 degrees camber
Wheels are miro111 size 18x9.5 et 40. When i park slanted on a driveway i can barely fit a credit card between the gap which makes me believe its not rubbing against the lip but there is certainly tire marks there
I am corner balanced if that helps. Not sure if i should add more camber or shave the lip down? Anyone shave theirs? I dont think the rears can be rolled. Looks tight.
BRZ'13 is offline   Reply With Quote
Old 04-21-2016, 03:59 AM   #1766
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
17x8.5 CE28 255/40 NT01
17 x 8.5j CE28 on 255 NT01..
Decided to ditch the Mach V wheels for track and use these instead.
Joe-G is offline   Reply With Quote
The Following 5 Users Say Thank You to Joe-G For This Useful Post:
DuMa (04-21-2016), DustinS (04-21-2016), Metabrz (04-27-2016), MisterSheep (04-21-2016), NABoxer (04-25-2016)
Old 04-21-2016, 09:27 AM   #1767
sqd
sqd's Avatar
Drives: '13 SWP GT86
Would a 18x9.5 +45 with 265/35 Pilot Sport Cup 2's fit in the rear on stock struts with Eibach springs? I have coilovers and they're installed in the front, but due to reasons I'm back to springs/stock struts in the rear temporarily. I have the stock wheels on right now, but wanted to mount my wheels before I have the chance to reinstall the coilovers in the rear.
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 04-21-2016, 10:07 AM   #1768
cjd
cjd's Avatar
Drives: 2017 BRZ
A recent shot with a bit of an experiment on the centering caps
Old 04-21-2016, 10:48 AM   #1769
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
I think you might be able to get away with it... But if your drop doesn't provide enough camber, you might have some rubbing issues...
If you have the wheels, why not put them on and find out?
Old 04-21-2016, 10:55 AM   #1770
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I think you might get away with it.. I'm unsure about the offset as I have 18x9.5 +40 on the rears with 255/35 MPSS and they fit quite nicely. Which Eibach springs do you have? That could help determine how low you are in the rear.
Instagram: trevor.parque
Old 04-21-2016, 11:01 AM   #1771
sqd
sqd's Avatar
I have LCAs too, so camber shouldn't be an issue
The car is in winter storage and the wheel are in my living room :p And my garage is a few miles from home. So I was just trying to get information first, if someone said it would absolutely not fit, I'd just leave the wheels at home until I got the coilovers on
I don't know what springs actually, haha. I was told when I bought the car that it had TRD springs, but the springs have the Eibach logo on them, so obviously they're Eibachs. No idea of the model though.
IG @squareddesign
Old 04-21-2016, 11:11 AM   #1772
MisterSheep
Killed Scion
Well, then I agree with @Joe-G if you have the wheels already why not just put them on and find out for yourself? Reading about your situation if your car is in storage then why are you worried about it fitting? It seems like you're answering your own questions here
Old 04-21-2016, 11:27 AM   #1773
sqd
sqd's Avatar
Haha I was just trying to figure out if someone knew for sure I am bringing the car out of storage this weekend, hence I wanted to know if I should bring the wheels with me or not. They won't fit in my other car, so that means I have to use a bigger one. I think this is way too offtopic now, haha
IG @squareddesign
The Following User Says Thank You to sqd For This Useful Post:
Old 04-21-2016, 05:12 PM   #1774
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
The Following User Says Thank You to mmmcambelsoup For This Useful Post:
DuMa (04-27-2016)
Old 04-21-2016, 06:21 PM   #1775
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
Originally Posted by malubawla View Post
18x9, 255/35/18
honestly a 225/45/17 looks a lot meatier than these wide but low profile tires
cyde01 is offline   Reply With Quote
Old 04-21-2016, 10:50 PM   #1776
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
you can roll the rear, mine is rolled flat.
your probably rubbing on the bumper-just trim it. or your tire will trim it for you.
Jive Turkey is offline   Reply With Quote
Old 04-26-2016, 10:44 PM   #1777
turbo_child
Drives: 2013 GT86
Hellaflush 😆🙌🏻 hah
It's only temporary for a car check with the authorities. I'll post how it looks on 265's in the sunshine in a bit to make up for this..
One of two Rocket Bunny GT86's in Norway..
turbo_child is offline   Reply With Quote
The Following User Says Thank You to turbo_child For This Useful Post:
olsonpg (05-01-2016)
Old 04-27-2016, 12:30 AM   #1778
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm, lol, THIS is the case, EVEN I would care about flushness too, even while being hater for flushness/stance/alike ..
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
