Old 04-21-2016, 08:50 PM   #1
Thorpedo
The SquadWhisperer
Let's see your LAUNCHES!!!!!
I imagine there are quite a few of us with outside launch videos. If you have them, post them up!
OFH - Nameless catted/res front pipe - custom midpipe - TRD muffler.
245/40/17 RE71R
OFT launch control set to 5500
[ame]http://youtu.be/529p5pUiCjk[/ame]
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
The Following 3 Users Say Thank You to Thorpedo For This Useful Post:
DAEMANO (04-22-2016), gatorbushmen (04-21-2016), ollie (04-24-2016)
Old 04-21-2016, 09:16 PM   #2
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
grippy tires + low car + bad axle geometry = I'll pass
gatorbushmen is offline   Reply With Quote
Old 04-21-2016, 09:29 PM   #3
Thorpedo
The SquadWhisperer
You're right. I've only done ~400 launches, must be a terrible idea.
Old 04-22-2016, 12:54 AM   #4
renfield90
The Stig's German cousin
245/40/17 RE71R
Do you have 60' times?
In Lincoln in CS trim I pulled 2.1-2.2 60' on 245 Rival S. Launched around 5000 with lots of clutch slip and no wheel spin. Clutch didn't like that much but you have to avoid the torque dip and every time I spun my wheels was a bad 60.
On asphalt launching at 5k was an exercise in putting down parallel jet black strips at the start.
I personally plan to stock up on a spare axle for any prosolo events I do in STX.
Old 04-22-2016, 06:30 AM   #5
Thorpedo
The SquadWhisperer
That's exactly why i do a little wheelspin... I don't like the smell of clutch. I don't mind sacrificing a little time to reduce the beating it receives. Unfortunately I don't have 60' times. At one of our T&T events I might suggest they set the timing gear up for that though.
Old 04-22-2016, 01:30 PM   #6
renfield90
I've never smelled clutch, but I can tell after the 4th run that the clutch isn't quite as grabby.
I took the last CS trophy spot at last year's prosolo finale by just .110 (and the guy behind him was just another .024 back). Definitely would've lost a trophy and two positions if I hadn't been going for broke every run. For me every tenth is important and hardware considerations are secondary, hence the plan to carry a spare axle.
And for sure with a header and tune eliminating most of the torque dip, bogging down under 4000 isn't the end of the world like it is in CS trim (and that's my reaction to too much wheelspin, is to lift, but then you end up bogging). I'm hoping I can find a slightly more sane launch routine, but if I can't? Everything becomes a wear item...
Old 04-22-2016, 06:44 PM   #7
Silverspeed
Drives: 2014 FR-S
Be thankful for your good fortune. It does happen. More so to STX cars. We typically run lowered cars which larger footprints. I recently bought a spare from someone who blew one up (not an autocrosser, but still lowered with wider wheels/tires) and went to the Driveshaft Shop axles to avoid further carnage.
http://www.ft86club.com/forums/showt...ht=broken+axle
Silverspeed is offline   Reply With Quote
Old 04-22-2016, 07:24 PM   #8
Thorpedo
The SquadWhisperer
I didn't intend to imply that it never happens. I'm well aware of the examples of failures among STX/CS/Not-even-competing cars. They're quite rare by most peoples' standards. I have a spare axle that I keep with me, but it's silly to pretend they're made of glass. Generally, they last really well.
Old 04-22-2016, 08:21 PM   #9
Silverspeed
Drives: 2014 FR-S
I'm probably overly paranoid about the whole thing. On the positive side, I've never heard of one doing other damage to the car. It seems they tend to stay together even after breaking.
Old 04-23-2016, 10:30 AM   #10
stevesnj
stevesnj's Avatar
This car is not too delicate to launch, just have fun.
My 2016 Build thread
Old 04-24-2016, 07:30 PM   #11
ollie
ollie's Avatar
Drives: GT86
That was a really good launch with plenty of control. Thumbs up amigo
ollie is offline   Reply With Quote
The Following 2 Users Say Thank You to ollie For This Useful Post:
86kahl (05-12-2016), Thorpedo (04-24-2016)
Old 04-25-2016, 06:06 PM   #12
Thorpedo
The SquadWhisperer
Well damn, I was really hoping other people would post some links to theirs.
Old 04-25-2016, 06:36 PM   #13
renfield90
I don't run video. Aside from the ego boost of having a whole dozen people watch me drive on youtube, I've never gotten any value from it.
Here's spring nats pro from last year, when my codriver brought video:
[ame="https://www.youtube.com/watch?v=RocMberS9OM"]Manfred - Spring Nationals ProSolo 5-23-15 @ Lincoln - YouTube[/ame]
Pardon the average driving, there's a couple mistakes made and the car had (unknown to me at the time) a loose front left hub to control arm nut which resulted in the car not wanting to turn right. This was the first time at Lincoln with the CS TRD package, Konis, and 245 BFGs. Ended up making some large adjustments at nats and the car worked a lot better. /excuses
EDIT: launches in the video were as follows.
Left side: RT .532, 60' 2.247
Right side: RT .514, 60' 2.223
Note that .500 is a perfect RT and .499 is a red light.
Old 04-25-2016, 08:25 PM   #14
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Jesus, I'm assuming all that is wind noise and not something rattling to death right?
Nice video otherwise though haha.
Toyota Finance 86 Series Race Spec Car Launches in New Zealand Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 48 04-15-2016 12:23 PM
Nissan Skyline GTR R34 - Anti-Lag, LAUNCHES! JPxM0Dz Other Vehicles & General Automotive Discussions 3 03-19-2014 02:35 PM
Litchfield Supercharged BRZ Spec S with 280hp - Launches and Accelerations JPxM0Dz BRZ Photos, Videos, Wallpapers, Gallery Forum 1 01-22-2014 10:15 AM
Audi launches A3 Sedan commercials about Car Abstinence Raiden Other Vehicles & General Automotive Discussions 15 12-31-2013 09:18 PM
