Old 04-20-2016, 09:06 PM   #575
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by Jmonty View Post
How is the Ace FP and Type A 350 with the stock catback as far as noise
http://www.ft86club.com/forums/showt...64#post2617064
The Following 2 Users Say Thank You to Calum For This Useful Post:
Bramick (04-20-2016), brzaapi (04-21-2016)
Old 04-21-2016, 12:22 AM   #576
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Originally Posted by Calum View Post
Thanks I have seen that post
Jmonty is offline   Reply With Quote
Old 04-21-2016, 07:53 AM   #577
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
....And what a good post it is for a youtube virgin.
I would say it is loud and obnoxious, but everyone already knows what i think.
CBE here i come. If my Q300 works quite well at changing the tone. My ACE FP might just go back on cause, ermm..... ....
........RacecaR.
But with my stock CBE, I am too much of a pansy to run the ACE FP.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
The Following User Says Thank You to brzaapi For This Useful Post:
Jmonty (04-22-2016)
Old 04-21-2016, 08:05 AM   #578
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Talk to me about your oil pan heat wrap... @Hawk77FT
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 04-21-2016, 08:15 AM   #579
Hawk77FT
Drives: GTS 86
I had it since I had my Hks header. Left it on.
Sent from my HTC_0P6B using Tapatalk
Hawk77FT is offline   Reply With Quote
Old 04-21-2016, 09:13 AM   #580
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
I wasn't really serious about the uel i know Ace is al about performance and i'm quite Happy with my JDL uel but still really curious how a uel from Ace would Look Sound and perform :p
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter
GT86meMR2 is offline   Reply With Quote
Old 04-21-2016, 11:11 AM   #581
churchx
churchx's Avatar
Drives: 2014 GT86
Hypothetical Ace's UEL might be slightly more effective due in general smooth bends/top velding, due at least half of cylinders having long enough runner for best powerband, but very probably it will be almost as expensive to make as normal EL. Ace's customers are prioritising best performance and are willing to pay premium to get it. UEL niche imho is for other customers, to whom subjective feel (from eg. sound) matters more then performance, hence will Ace's normal customers still justify high price of "not very best anymore" header? That looks like cutting sales of such header tenfold .. but it will still take as much time/efforts to design/test/setup manufacturing as ELs. Which may further increase it's price as not backed by economy of scale.
At the end, if you custom absolutely must have it and you are willing to pay very big price for one-off custom UEL, i guess you can make a deal with Ace to make you one (it probably won't have many prototypes and extensive track testing behind though). But i don't see much potential in it as another product in their lineup. Just something to brag about for having something unique one-off, not backing it by top performance.
P.S.
"Normal" UELs also have extra pro of usually fixing better torque dip vs "normal" ELs. So i might be too harsh on writing off most UEL buyers as form-over-function ones .. still, as dip is not an issue for Ace's headers, UELs don't have anymore such advantage. Just less performance in return for more preferable sound by customers' tastes.
Old 05-04-2016, 08:12 AM   #582
Reamer
Drives: 2015 FRS
Finally got my ceramic coated B-350 installed and dyno'd. I also have the ACE front pipe installed with a stock catback and unless you like a LOT of rasp I would avoid the front pipe. Being no cats and unresonated I should have known that though. Having said that, the build quality of both parts is top notch and it put 179.5whp down on dyno dynamics, also called the "heartbreaker" dyno for how low it reads compared to others. The only other engine mod is a grimmspeed CAI. I have a JDL ultra quiet front pipe on the way and then shortly after I will get a catback. Thinking about going with Agency Power.
Sent from my ONE E1005 using Tapatalk
Reamer is offline   Reply With Quote
The Following 2 Users Say Thank You to Reamer For This Useful Post:
CSG Mike (05-04-2016), Hyper4mance2k (05-05-2016)
Old 05-04-2016, 10:20 AM   #583
brzaapi
CAR-AHOLIC
brzaapi's Avatar
I have been a little preoccupied with installing my JRZ coilovers, but while i had my car in the air. I decided to add SPL rear LCAs, they install super easy. And the adjustability is great and easy to get to once installed. Plus you can use regular wrenches and not super skinny spanners.
Anyways, I also installed an Invidia Q300. The car sounds great with my current setup.
ACE 421 B350, Invidia HFC FP and Invidia Q300 CBE
But, I am very tempted to put the ACE FP back on and see what sounds i get. I prefer quieter exhausts, or at least ones that are not obnoxious in low to mid rpm range. But, dare i say that the car could use some more volume.
As i said my main concern right now is fixing my coilovers, but I will come back and post some video/audio clips to show the ACE and Q300 off, with the HFC FP and the ACE catless FP. I think with this CBE the Ace front pipe may work fine. I will report back when i have more.
Daily: Audi TT RS
The Following 2 Users Say Thank You to brzaapi For This Useful Post:
Calum (05-04-2016), new2subaru (05-04-2016)
Old 05-04-2016, 10:26 AM   #584
Reamer
Drives: 2015 FRS
You had the ACE FP on previously?
Old 05-04-2016, 10:44 AM   #585
OkieSnuffBox
Drives: '23 BRZ Limited
my JRZ coilovers,
That's what I'm saving up for at the moment.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Old 05-04-2016, 02:14 PM   #586
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Yes sir. A little earlier in this thread i posted some videos allowing everyone to hear the exhaust with the catless FP. It has the hollow angry bees sound, plus the stock muffler was falling apart and was getting louder on day to day basis.
Daily: Audi TT RS
The Following 6 Users Say Thank You to brzaapi For This Useful Post:
Bobster (10-28-2016), CSG Mike (05-04-2016), Jmonty (05-04-2016), new2subaru (05-04-2016), raven1231 (05-04-2016), Reamer (05-04-2016)
Old 05-04-2016, 03:24 PM   #587
Calum
That Guy
I'm awaiting video of the new setup... please.
The Following User Says Thank You to Calum For This Useful Post:
brzaapi (05-04-2016)
Old 05-04-2016, 03:28 PM   #588
Reamer
Drives: 2015 FRS
I remember those videos. I had already ordered the front pipe by then.
The Following User Says Thank You to Reamer For This Useful Post:
nsfwseriouslythisisporn
[REQ]BRZ Independent Fog Lights 1stGenBRZ86 DIY (Do-It-Yourself) Guides 3 04-17-2016 06:34 PM
What do I need for an independent tuner.. Shady195 Software Tuning 2 07-23-2014 09:04 PM
Subaru BRZ/Scion FR-S UEL Header by JDL -- Testing by Moto-East JPxM0Dz BRZ Photos, Videos, Wallpapers, Gallery Forum 13 05-08-2014 08:06 PM
Vortech Finale Review Video | Track Testing | Part 4 of 4 Dezoris Forced Induction 75 04-12-2014 12:45 PM
The Independent Review: Toyota GT86 Boxer-4 Scion FR-S / Toyota 86 GT86 General Forum 31 01-09-2012 06:22 PM
