Old 04-20-2016, 12:10 PM   #1
Kiriana
Maybe a little lower...
Kiriana's Avatar
Drives: 2013 Scion FR-S Silver
Broken Tein Street Basis
HELP!!!
Normally I would comb through the forums and get answers and I have looked but I really am just wondering rather the coil over or Springs are better. I bought a 2013 Scion FR-S last month and noticed really bad scrubbing on the left rear with the smallest of bumps or shift while driving. Ended up taking it to a local mechanic to have it lifted a bit and we discovered it is set properly but seems to be broken in some way so i am now in the market for either new coil overs or springs.
Kiriana is offline   Reply With Quote
Old 04-20-2016, 12:13 PM   #2
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Do you have aftermarket wheels by any chance? also how much are you lowered?
Instagram: trevor.parque
Old 04-20-2016, 12:18 PM   #3
Kiriana
Kiriana's Avatar
Yes xxr 530 I think and one the side not scrubbing is about a 1 to 1 and a half inch lift, but on the other side it is the same measurement underneath the car bit rubber to finder is lower.
Old 04-20-2016, 12:22 PM   #4
MisterSheep
Killed Scion
Your coilovers could be adjusted unevenly and one side could be lower than the other, or your spring/damper rates could be off causing one to travel further than the other
Old 04-20-2016, 12:27 PM   #5
Kiriana
Kiriana's Avatar
Old 04-20-2016, 12:29 PM   #6
Kiriana
Kiriana's Avatar
He made sure they were adjusted evenly and their is not way to adjust the damper on the coil overs i have from what i have found. There are newer models os my springs that can be adjusted and was considering buying those...
Old 04-20-2016, 01:29 PM   #7
stockysnail
Just the tip
stockysnail's Avatar
The car looks a little low with the wheel offset you have and less expensive coilovers. I would raise it up at least .5" and maybe 1" if it still rubs.
Old 04-20-2016, 01:34 PM   #8
Apex-Apex
Apex-Apex's Avatar
Maybe it's the angle but your caster looks funny.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 04-20-2016, 02:27 PM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
And if you are in market for new inexpensive ones, imho Tein Flex Z are worth considering. If you are mostly daily driving, most practical would be having them at least drop from height adjustment range. Of course, worth redoing alignment after their installation/adjusting height as wished.
MisterSheep (04-20-2016)
Old 04-20-2016, 02:30 PM   #10
MisterSheep
Killed Scion
another good question to ask is if you had an alignment done after install of the coilovers.
Old 04-20-2016, 02:38 PM   #11
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Broken how so? Lack of information really doesn't help with the post...
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
MisterSheep (04-20-2016), strat61caster (04-20-2016)
Old 04-20-2016, 03:31 PM   #12
MeisterR
MeisterR's Avatar
Drives: BNR32
Have they check the damper?
Is it leaking in any way?
You want to be sure you need new coilovers before tossing money to get new one.
You can also get new coilovers as an upgrade, but only if you are looking for a performance gain.
Jerrick
MeisterR is offline   Reply With Quote
The Following User Says Thank You to MeisterR For This Useful Post:
Old 04-20-2016, 05:34 PM   #13
CSG Mike
CSG Mike's Avatar
You could just get the broken damper repaired by Tein USA.
Old 04-20-2016, 07:00 PM   #14
Kiriana
Kiriana's Avatar
Thank you all for the help. Broken an in they cannot be adjusted I have had several shops try
Tein Street Basis coilovers Amuse_S2000 Brakes, Suspension, Chassis 8 12-21-2015 12:49 AM
Tein Street Basis dito Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 09-12-2015 08:40 PM
Tein Street Basis Owners! MikeMess147 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-12-2015 01:01 PM
FS; TEIN basis - best for street setup! hong Brakes, Suspension, Chassis 8 10-16-2014 02:58 PM
NY: F/S Tein Street Basis jammz Brakes, Suspension, Chassis 5 04-20-2013 10:31 PM
