Old 04-19-2016, 12:44 PM   #1
BDotG
BDotG's Avatar
Drives: Asphalt 2013 FR-S
Thoughts on license plate mounted wing
Hiya folks,
I saw the Revolution Japan GT Wing
and I really love the style and looks of it for some reason. Anyways, this wing retails for about $2500USD, which I think is insane, so I am tempted to build my own.
I started mocking it up with poster board last night after doing some cad drawings and I am liking how it looks so far (I should note that I am only building the legs and mount, the blade will be purchased elsewhere.)
My questions are, how effective would this be? The way I have designed mine it will use a solid mount system of 1/4 aluminum from both sides of the trunk with 1/4 bolts to ensure it isnt going to rip off. The backing plate inside the trunk will secure in a few different places to add some rigidity to the back of the trunk. The way the legs wrap up over the trunk will position the blade right over the top similar to where a normal wing would sit.
I've heard quite a few arguments for an against this style of wing, but nothing relating to 86s. Any engineers want to chime in before I waste my time haha.
BDotG is offline   Reply With Quote
Old 04-19-2016, 01:08 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Define "effective"...
Any wing not directly bolted to the chassis of the car is not effective for racing purposes.
The nice thing about this wing is that it does not involve drilling holes in the trunk. However, keep in mind how flimsy the stock license plate holes are, and how only two holes are supposed to keep in check downforce in excess of 300lbs if you go fast enough.
-alex
wparsons (04-20-2016)
Old 04-19-2016, 01:12 PM   #3
Zed
Drives: 2013 Subaru BRZ Limited GBS
Zed is offline   Reply With Quote
The Following 6 Users Say Thank You to Zed For This Useful Post:
BDotG (04-19-2016), HAWAIICALIVEGAZ (04-20-2016), jbsali (04-28-2016), PresiO. (04-20-2016), wparsons (04-20-2016), YamahaR86 (04-20-2016)
Old 04-19-2016, 02:06 PM   #4
BDotG
BDotG's Avatar
-alex
Truth. I would be planning to drill an additional two holes and increase the hole size to 1/4" so that plus a reenforced backing plate I figure would be pretty solid, I just worry about the trunk as a whole. I honestly don't think id ever get in a situation where the car is going to be producing that much down force in Autocross, sprinted canyon drives, or even the random track day, but Im not sure. Maybe it's just for looks I guess. *shrug*
Old 04-19-2016, 02:11 PM   #5
mav1178
mav1178's Avatar
http://aprperformance.com/racing-pro...ustable-wings/
Use the data as a reference point.
At 80MPH the APR GTC200 wing produces almost 80lbs of downforce at 0 AoA.
Imagine your mounting point, now mount 80lbs of weight on there.
Go up to 120lbs for 12 degrees AoA.
Go up to 200lbs for 12 degrees AoA to simulate 100MPH.
Now see how much your trunk flexes, and whether you want to buy a new trunk later or not.
This is just the GTC200. Larger wings with more complex elements could produce more downforce.
Bottom line is, if you want a wing, mount it on top of the trunk. Less chance of deformation and more area to spread out load.
-alex
Old 04-19-2016, 02:24 PM   #6
stevesnj
stevesnj's Avatar
Even with no wing our cars have enough down force. So adding this would be just for looks or if you want the air pressure to slow you down with this on. A wing like this is detrimental. Mounting this in that spot will bend that metal. I think this is made for CF trunk lids.Is your car a DD? Or you setting it up as a track only car?
My 2016 Build thread
Old 04-19-2016, 03:16 PM   #7
danny_d19
danny_d19's Avatar
Drives: Whiteout RBv1 FRS
danny_d19 is offline   Reply With Quote
The Following User Says Thank You to danny_d19 For This Useful Post:
Clipdat (04-20-2016)
Old 04-19-2016, 03:18 PM   #8
BDotG
BDotG's Avatar
Thanks for the input folks! Guess other options will be explored.
Old 04-20-2016, 12:59 AM   #9
Poodles
Drives: 2015 Series.Blue
When done properly, they work. Seen em on MKIV Supras a couple of times, they only install them for track use and remove them on the street.
Old 04-20-2016, 01:10 PM   #10
wparsons
wparsons's Avatar
Have a look at the reinforcement "plate" used for this wing and see if you'd want to just hang it off the back of the trunk
http://speed.academy/scion-frs-volte...g-gt-toyo-r1r/
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
BDotG (04-21-2016), Createddeleted (04-20-2016)
Old 04-20-2016, 09:22 PM   #11
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Do it!!!!
Race car bro!
Old 04-20-2016, 10:48 PM   #12
ARTBRZ
Aloha!
ARTBRZ's Avatar
ARTBRZ is offline   Reply With Quote
Old 04-22-2016, 08:59 AM   #13
Ashikabi
Ashikabi's Avatar
I'm all for big wings and they do(when properly designed) create down force which is beneficial at higher speeds. The people who think they look silly always say they are worthless/just for show etc but like was said above... The APR wing makes 80lbs at 80mph. Voltex uses a wind tunnel for testing so their products are legit hence the monster price tag. HOWEVER if you don't put it in the right place with the right angle it won't do much if anything(or you just won't know if it is or not since you may get lucky). The license plate mount is clever as fuck but I could see it trying to deform. A backing plate will likely help but be prepared to replace your trunk just in case. Good luck!
Old 04-22-2016, 09:15 AM   #14
ZionsWrath
Thanks
ZionsWrath's Avatar
If your car is a DD and weekend show car that is totally the wing to get.
If you actually want it functional I'd say no
The Following User Says Thank You to ZionsWrath For This Useful Post:
wparsons (04-22-2016)
Fender mounted wing mirrors Khorne Cosmetic Modification (Interior/Exterior/Lighting) 15 12-18-2020 09:34 PM
FS: tow hook/side mounted license plate frame Since1967 Canada Classifieds 4 06-12-2015 06:16 PM
Beatsonic license plate mounted backup camera? normancw Electronics | Audio | NAV | Infotainment 3 01-28-2013 05:08 PM
[For Sale] Rho-plate Tow Hook Mounted License Plate rack pizzahead20 Canada Classifieds 0 08-23-2012 12:06 AM
