| Northern California NorCal |
Evening Primrose
Help? Not sure where to start
In short,
On the highway in 4th, heard an odd noise, slow down as I'm making my exit, get down the gears proper to neutral before the light, no power. All my lights cut on as if I just turned on the car for the electronics only. Same thing continues to happen when I try to start it now. It'll click, the electronics come on, but the engine won't start. No issues this morning driving to work, really not sure what's wrong. [ame="https://www.youtube.com/watch?v=ow0EMCBYpOo"]BRZ 2013 won't start - YouTube[/ame] (better explanation.) No smells, no leaks, no smoke. Last edited by sftateofmind; 04-18-2016 at 09:42 PM. |
#2 |
Drives: FRS
Check battery connectors. It seems like either you connectors are loose or battery is almost dead.
| The Following User Says Thank You to svolo4 For This Useful Post: | sftateofmind (04-19-2016) |
#3 |
Evening Primrose
#4 |
[insert cool phrase here]
Drives: BRZ Premium
First thought, dead battery.
How's the weather been? Petty hot? Then again, who knows? Could be a failing alt, or starter, injections? Did you try jump starting it? Have a buddy and his car try it. If no luck, then could be a totally dead battery.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | sftateofmind (04-19-2016) |
#5 | |
Evening Primrose
Connections seemed fine, going to have a friend take a look. |
#6 |
[EUROBEAT INTENSIFIES]
Drives: 2015 Scion FR-S Steel
Battery or alternator. Check those two. I'm betting its probably just the battery going bad.
| The Following User Says Thank You to TheMedakaBox For This Useful Post: | sftateofmind (04-19-2016) |
#7 |
Drives: 99 impreza,13 brz, 22 maverick
I had the same problem a couple months ago. Turned out it my starter's stud holding the power line snapped off (guessing the tech overtorqued the nut when I replaced the transmission) so it wasn't getting power. Could also be battery
| The Following User Says Thank You to mou For This Useful Post: | sftateofmind (04-19-2016) |
#8 | |
Evening Primrose
I left it in the drive way while I went to watch the game. Came back and the battery has not seemed to drain one bit at all. Everything still cuts on without fault or more dimmed. I get one or two clicks as I try to start it before it gives up. |
#9 |
Evening Primrose
#10 |
Hi.
Drives: 14' Asphalt
What kind of noise did you hear?
That looks like it's in a limp mode/security mode on the ECU. I mean you can check for 12.7VDC on your battery and if thats present..take it down to auto parts store to be load tested. If it's 12.4VDC or less then you can start to suspect a alternator issue as that -normally- means 80% charge capacity is present. That would still start it. I'd think these would have a LVC cutoff of 11.5 which is around 20% capacity. Anything above that and it should still crank (i'm not 100% sure just a theory, i dont really wrench on new cars) 10.5VDC is dead. I still suspect your in some form of "protect" mode whether your fob is not communicating correctly, your ignition switch is faulty or your ECU is in protect from a serious fault. Try a hard reset of ECU, disconnect negative battery terminal. Those are good starting points
14' ZN6
92' RN80 81' RN38 "Shitbox" I like Toyota's IG: undefindedt |
| The Following User Says Thank You to undefindedt For This Useful Post: | sftateofmind (04-19-2016) |
#11 | |
Evening Primrose
#12 |
Evening Primrose
Update:
Jumped it this morning. Got a better response for it trying to start. Gave me hope twice before it killed out again back to just the clicks heard in the video on start. Going to check on that ECU reset later after work. |
#13 |
Evening Primrose
Disconnected my battery and no dice. Also the battery seems to be just fine. Doesn't sound like the alternator at all either. Not really sure what's going on.
When I get a jump it tries to crank before going back to two clicks again. |
#14 |
Hi.
Drives: 14' Asphalt
Time to scan for codes....
Also clicks as in like mechanical noise in engine bay? or clicks as in noise inside car? If clicks upon starting in engine bay, possibly issue with plunger not engaging starter gear properly? Bang on it with a hammer lol Not too hard.If your car is bumper to bumper though still; don't bang on it. Tell them to come get it...
14' ZN6
| Pushed start.. didnt start | im_topher | Engine, Exhaust, Transmission | 86 | 11-29-2015 09:57 AM |
| Battery dies, push start car in gear.... push start button | rhythmM | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-27-2014 06:06 PM |
| ECU: Where do I start???? | chiefshayan | Software Tuning | 11 | 07-17-2013 11:42 PM |
| Pop-Start with Push-Button Start | cmspooner | BRZ First-Gen (2012+) — General Topics | 5 | 03-22-2013 02:45 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 03:44 AM |
